Old 10-22-2002, 12:25 PM   #1
Visceral
Member#: 16367
2006 Subaru WRX STi
Default UTEC at track (road)
I'm going to be running my car at Watkins Glen this weekend with the UTEC and the Stage 2 93 Octane map. Should I do anything to increase my margin of safety for running at the track?
Thanks,
Mike
Visceral is offline   Reply With Quote
Old 10-22-2002, 02:47 PM   #2
2000vfr800
Member#: 15599
Wear a helmet?
2000vfr800 is offline   Reply With Quote
Old 10-22-2002, 04:25 PM   #3
TurboXS
Member#: 4143
2002 WRX Wagon
WR Blue
Default Re: UTEC at track (road)
Thanks,
Mike
Make sure that you have gauges installed (Boost and EGT at a minimum) and use them. Make sure boost is where it should be - 16-16.5psi max in 4th gear - and if EGTs go above 860C/1550F (measured BEFORE the turbo) start to take it easy.
Use higher octane race gas like VP103 unleaded race gas or similar (or at least mix some in with your 93 octane pump gas). You will run effectively richer, which means you will run cooler. Also, consider turning on the ECT correction in the UTEC. Maybe add 0.5% fuel if ECT goes above 95C. Both of these things will slightly decrease peak power, but should keep your engine running cooler and should significantly reduce the risk of engine damaging detonation.
If you plan to track your car regularly and have not already done so, consider replacing your uppipe with a catless uppipe.
Good luck!
Mark
TurboXS
TurboXS is offline   Reply With Quote
Old 10-22-2002, 09:41 PM   #4
Visceral
Member#: 16367
2006 Subaru WRX STi
Have the helmet covered.
Thanks a lot Mark.
Subie at track (not mine) Ekliptix Member's Car Gallery 3 12-01-2001 01:36 AM
in reno at track wrxken Member's Car Gallery 9 09-25-2001 02:30 PM
WRX at Track Day shiv Bay Area Impreza Club Forum -- BAIC 18 02-27-2001 05:37 PM
Patrick's crash video used at track weekend NeedaScooby General Forum Archive 3 01-05-2001 12:49 AM
What about a BAM w/vendors at Track Day? SFsube Bay Area Impreza Club Forum -- BAIC 8 08-10-2000 12:54 AM
