Old 10-22-2002, 04:31 PM   #1
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Default Link plus map for ludespeed stage II?
Looks likely that Ill be installing my stage II kit this weekend. Ive been tuning it with my link NA on stock injectors and done fairly well so far. Just wondering if anyone has a turbo map for 440cc injectors that they'd be willing to share with me? Much easier to have a place to start from.
Thanks
-B
ps sorry for the x-post but I didnt realize there was a ecu forum yet
Midwayman is offline   Reply With Quote
Old 10-22-2002, 05:20 PM   #2
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
I have a Ludespeed stage II (6.6psi) with RC 440cc injectors and LinkPlus. Exhaust is 2.25'' stromung from the downpipe back. I'll go get the map and send it to ya. What's your e-mail address? Also after you look at it and run it, can you let me know where you think it can be improved (read: map is conservative)?
-Chav
Chav is offline   Reply With Quote
Old 10-22-2002, 06:05 PM   #3
Delicious Tuning
Member#: 1990
Well this site looks like they are going to be storing MAPS on thier site in the near future. Just thought I would pass along the info if people would like to start storing MAPS in there.
http://www.wrxhackers.com/modules.php?name=Downloads
~Bill
Delicious Tuning is offline   Reply With Quote
Old 10-22-2002, 06:05 PM   #4
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
You have PM
I have
Ludespeed stage II
440 rc injectors
UDP
Excedy flywheel and clutch
stromung 2.25" catback
Cobb street cams
Thats about it for fueling affecting mods.
Old 10-22-2002, 10:55 PM   #5
Chav
Member#: 3269
RSTi
Sent.
-Chav
Old 10-22-2002, 11:09 PM   #6
milkman
Member#: 8066
Y2K RSt
Sedona Mars Red Pearl
[quote]Originally posted by Midwayman
[b]You have PM
UDP
Did you find it hard to correct for the voltage drop with the UDP, also what type of FPR are you running?
milkman is offline   Reply With Quote
Old 10-23-2002, 12:27 AM   #7
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
[quote]Originally posted by milkman
[b]
You have PM
UDP
I have a stock FPR.
As far as voltage correction, I havent noticed any issues. The UDP is a pretty constant % less charge. Maybe Ill datalog the voltage and see if anything happens I havent noticed.
-B
Old 10-23-2002, 03:10 PM   #8
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Is Chav's map working out well Midwayman?
You two have a very similar setup.
Graham
Graham is offline   Reply With Quote
Old 10-23-2002, 03:16 PM   #9
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Ill let you know if I manage to get it all on this weekend.
-B
Old 10-23-2002, 09:40 PM   #10
Chav
Member#: 3269
RSTi
I just did some more tunning today and I realized that my entire map is very conservative. I can run 5 degrees more timing in the first 3 rows with out a problem. For some reason I can't run more than 14 degrees of advance in the 5th row. It pings horribly if i try. The car is running super rich too (a/f target of 91).
-Chav
Old 10-24-2002, 03:25 AM   #11
Delicious Tuning
Member#: 1990
Hey Chav,
Sounds like you are nailing down the MAP pretty damn well. I will tell you the timing you have is about right. The max I have found that you can reach below 6000 RPM's is 15 degree's on 91 octane and 9.7:1 compression. Anymore and you are on the verge of pinging. So you are right on line for a good MAP, with your car being at 10:1 compression.
Just letting you know that you are hitting your limits of 91 octane. Though on 100 octane it is a totally different story.
Old 10-24-2002, 12:59 PM   #12
Chav
Member#: 3269
RSTi
Skywalker,
Yea, I have come a long way with this last map. It is really good to know that I'm supposed to be at the limit! I was starting to think that my plugs/fuel lines weren't up to the task. Thanks again Bill! You Rule!
-Chav
Old 10-24-2002, 02:37 PM   #13
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
You on 91 then chav? 93 is the standard up here. Ill send you the NA map I was using if you want a look at it.
-B
Old 10-24-2002, 02:46 PM   #14
Delicious Tuning
Member#: 1990
The fuel lines will be good up to about 350 Hp to the wheels, beyond that you will need to rerun all the fuel lines from the gas tank. That sucks...
Though if you drop down to another step colder plug, you will get more timing advance. I am to the point where I should get another step colder plug, but I need bigger injectors also. I am getting near the 300 Mark on 91 Octane and 10 PSI.
link plus map for a stock 2000 impreza 2.rs? erice1984 Engine Management & Tuning 6 01-29-2005 12:34 AM
link plus maps for special setup erice1984 Engine Management & Tuning 0 01-20-2005 01:48 AM
Looking for a Tech 3 map for Ludespeed Stage 2 subaru kym Normally Aspirated with bolt-on Forced Induction Powertrain 1 02-18-2004 03:40 AM
Need Tech 3 Map for Ludespeed Stage 2, plz :) subaru kym Southern California Impreza Club Forum -- SCIC 6 02-18-2004 03:30 AM
ludespeed stage II link map? Midwayman Engine Management & Tuning 0 10-22-2002 03:19 PM
