Closed Thread
Old 05-31-2014, 03:37 PM   #51
AkRsWagon
Member#: 227477
2015 WRX Limited
Galaxy Blue
Originally Posted by Subi Speed View Post
In the video the low beams were unplugged. I'll see if there's any other media available.
Cool, missed seeing the video link. I think pics at night of that would be very nice, of both just the DRL's and then also with the high beams on.
AkRsWagon is offline
Old 05-31-2014, 06:27 PM   #52
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
Someone actually posted a way to rewire the C lights as a DRL? I would love to make a plug in harness, but it would take a lot of of time.
No, I haven't seen anything yet (surprisingly). I was kinda hoping to see something here since you guys have the fine lighting segment for the new model on lock. But I would definitely pay loot to have a plug-and-play solution, and seeing as my STI order won't even be here until October... I'm patient, lol.
nightdown fox is offline
Old 05-31-2014, 06:29 PM   #53
thisisbrock
Member#: 22064
2015 WRX
CBS
http://forums.nasioc.com/forums/show....php?t=2631558
like this?
thisisbrock is offline
Old 05-31-2014, 07:38 PM   #54
Subi Speed
Member#: 387955
2015 WRX
Actually it wasn't supposed to have a question mark. It was supposed to be a period. Oops.
I need to take the vehicle home a couple of weekends to see if any plugs could be made.
Originally Posted by BrownDog40 View Post
I would be interested in a true retrofit, painted inside to black and hopefully a stronger C-light outline.
It would be in a retrofit in the sense that a kit could be purchased. We wouldn't be doing a swap with core charge. :-(
Originally Posted by NJsub98 View Post
trying to understand those DRL replacement bulbs..since ( i think) the factory DRL bulb functions as both the DRL and high beam, do these replacement bulbs have '2 levels' of brightness as well or is the DRL brightness the same as the high beam essentially meaning the high beam doesnt exist anymore? thanks.
That's correct. The DRL resistor, lowers the output voltage. Hence a dimmer DRL. We're fortunate that it isn't a Pulse Width Moduated DRL setup. At least I'm pretty sure it's not. Someone please correct me if I'm wrong. Else we might have issues with some of the LEDs not getting a clean power resulting in flickering or a short lifespan. Anyways, you've got it right. There are not two levels of brightness with this setup. The 2000lm output is what the manufacturer thought the sweet spot was between not blinding people as a DRL and being a functional high beam (put more light down the road at a point higher and wider than the low beams). It's nice that with the WRX the low beams DO NOT turn off. Therefore usable light with the high beams on is the sum of the low beams and high beams.
Originally Posted by Redeemed77 View Post
HID retrofit!!! Yes, me me....uhh ugh....ME!! Also the C LED mod for a more uniformed look and to have them turn into the DRL's along with your DRL mod already. Overkill...is just right lol
I am getting some sample pieces of a new product that would light up the entire C light in a uniform manner. It would also have an option to function as a turn signal.
Subi Speed is offline
Old 05-31-2014, 08:57 PM   #55
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The DRL is still a conventional resistor setup (already unplugged mine).
Mulder is offline
Old 05-31-2014, 09:07 PM   #56
Redeemed77
Member#: 378138
2015 WRX
CWP
YES!!!!!!!! Turn signal too....YES YES!!! DRL?
I know you don't want to do the core swap thing but a complete system (blacked out like the Limited trim) with what I mentioned plus HID's....would be a GREAT product IMO. WINK WINK....ELBOW...ELBOW....COUGH COUGH....lol
Redeemed77 is offline
Old 05-31-2014, 09:18 PM   #57
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
Cripes. I've been searching google and the forums for days looking for this. Fail on my part. Thanks guys.
Old 05-31-2014, 10:26 PM   #58
NJsub98
Member#: 381467
2015 WRX Limited 6mt
Hey Subi Speed.. any answer to my question from the last page? Does your LED drl/hi beam bulb basically have 1 brightness setting hence making the high beam no longer existing?
NJsub98 is offline
Old 05-31-2014, 10:30 PM   #59
Ultimateone
Member#: 48025
15 Mustang GT
Just an FYI, I dont think LED's in the base/premium n the C lights light up bright enough in the daytime to really work for DRL's. There basically has to be more leds or some sort of tubing to make them brighter.
Ultimateone is offline
Old 05-31-2014, 10:33 PM   #60
AkRsWagon
Member#: 227477
2015 WRX Limited
Galaxy Blue
Yes, he answered that in a couple post up. It is just 1 brightness setting for it all. Curious to see a comparision picture for this though of the high beams vs LED. Has me a bit hesitant on doing this given 20hrs of darkness in the winter here...
Old 05-31-2014, 10:43 PM   #61
NJsub98
Member#: 381467
crap sorry..didnt see my post quoted..thanks....other question, isn't it illegal to not have a high beam technically?
NJsub98 is offline
Old 06-01-2014, 07:10 AM   #62
Redeemed77
Member#: 378138
2015 WRX
CWP
Yup, that's why I hope they find a solution for that. Light mods will have to wait till something worthwhile comes along. A "fix all the gripes"....added HID, getting all yellow light out (maybe not the fogs as explained here), DRL/C LIGHT FIX, and blacked out housing would be FANTASTIC!
Time will tell...
Old 06-01-2014, 12:57 PM   #63
Subi Speed
Member#: 387955
2015 WRX
This weekend the vehicle is with our tuner. I'll see if I can split the setup down the middle with OEM bulbs on one side and aftermarket on the other. Do some pictures and GoPro stuff another weekend though.
The OLM DRL / High Beam definitely puts out some light vs the SMD or Plasma 9005 bulbs you usually see on the market. A lot of those bulbs are deceiving as they sum up the wattage of each individual LED chip and sell them as 50W or 80W bulbs. This doesn't equate to more light on the road most of the time. They also don't work well with the reflectors in most casings. What little light they do project, isn't focused properly at all.
I'm always looking for interesting options out there. Will be sure to post up the findings.
-Chris
Old 06-01-2014, 01:29 PM   #64
Redeemed77
Member#: 378138
2015 WRX
CWP
^Thank you for putting in the time to do things the right way, while "white light" is visually nicer I'm the type that tries to keep things functional so white for the sake of white is not the goal so I appreciate your outlook on mods.
Old 06-04-2014, 01:37 AM   #65
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
With the risk of sounding stupid......
So when you replace the stock DRL bulbs with the OLM bulbs, your DRL is running at high beam intensity all the time now?
Just trying to clarify this because I'd really like to get these. But if this means running a DRL that is at high beam intensity all the time, it does not sound like a viable or safe solution.
The stock DRL is the high beam at "half" brightness which I'm assuming is to not blind people with high beams all day long.
Granted my assumptions on being "safe" are not scientific and I do not know what this bulb looks like at full brightness in the day. More than happy to be wrong about it. I'm just going off of the times I'm blinded by people with horrible lighting setups even in the day time because of their HID kits.
Don't want to be that guy just to get a better looking setup.
And thank you for all the write ups and info. It's been an amazing help understanding the new platform.
hail2theTheif is offline
Old 06-04-2014, 07:47 AM   #66
NJsub98
Member#: 381467
im reluctant for the same exact reasons
NJsub98 is offline
Old 06-04-2014, 10:12 AM   #67
Willbo
Member#: 386070
2015 WRX Limited
I'm basically ordering a full light kit. License plate, dome lights, DRL/high beam, glass fog light upgrade, LED fog lights. Total cost $296.70. Free shipping. I have a Limited due in next month and don't need the headlight or C light upgrade.
I'm going to unclip the DRL. I want the better bulb for the high beam function.
Willbo is offline
Old 06-05-2014, 04:32 PM   #68
Subi Speed
Member#: 387955
2015 WRX
Lightbulb
There is a note on the bottom of the product that you might want to turn your lows on in the hours of dusk for this reason. While it's bright outside everyone's eyes have adjusted accordingly.
I will continue to see if there are more solutions out there. Wiring the PWM dimmer could possibly work.
Definitely a solution to the above.
Old 06-06-2014, 12:09 PM   #69
Subi Speed
Member#: 387955
2015 WRX
Here is the HID kit install for base model and premium model WRX's.
http://youtu.be/PmfOCS3-oJs
Old 06-06-2014, 01:24 PM   #70
daverup
Member#: 3708
2015 WRX Ltd Sedan
ISM
Originally Posted by sc00ter View Post
Wow! I'll admit that the glass lens with the 55w bulb looks great. I'd have to revert my thinking on a glass lens being a bad idea if it really is as strong as you say it is.
Although an upgraded fog light with a glass lens and a higher watt halogen bulb sounds great, do not buy the Subispeed part. I tried putting these in today.
I found that the default adjustment is pointed up and the adjusters are incapable of maintaining a level or downward angle. The adjusting mechanism is poorly constructed and results in the reflector jumping up and down in the case.
In addition the reflector pattern in these lights is more a floodlight than a foglight.
To top it off the 55W halogen bulb was overheating the case in the very short time I was attempting to aim them.
The 19W stock foglights are a better solution than these things.
daverup is offline
Old 06-06-2014, 03:13 PM   #71
3n1gm4
Member#: 227728
2015 WRX (base)
Wow, instead of coming on here bashing one of the few companies actually R&D'ing the '15 try talking with them first. They seem to make plenty of parts and plenty of people haven't had an issue with them.
3n1gm4 is offline
Old 06-06-2014, 03:52 PM   #72
pwong26
Member#: 386021
Great work so far on the WRX. I'm curious, do you offer Relay Harnesses with the HID Kit? I noticed that you didn't use one on the video.
pwong26 is offline
Old 06-06-2014, 08:31 PM   #73
Subi Speed
Member#: 387955
2015 WRX
Hello! As always, you can give us the opportunity to look into the product. Every product does have a chance of failure. You did state that you won't return them though. We could give you a return label?
Prior to putting this on our site, the setup was used on our vehicle for about a week. We've switched from stock, to these, to the OLM projectors, and back again for all sorts of testing.
This lamps is not just used with the WRX platform so it's been in production for a couple years from this manufacturer. Is it possible that it was adjusted out of range?
V/R,
Chris
We could look into having a relay harness on hand, but with the low current draw of these HIDs we haven't had too many requests. If they were a 55W ballast, we'd start to recommend the use of a relay. The Subaru's electrical system isn't like the Hyundai Sonata. We've had no reports of ECU issues with this platform or the similar FR-S.
Old 06-06-2014, 09:37 PM   #74
Willbo
Member#: 386070
2015 WRX Limited
Subispeed,
Did you find any of this to be true when you installed the glass fogs? I ordered these (haven't arrived yet) and just want to know if it was user error or a legit issue with the housing. I also ordered the LED fog light bulbs. Will these work with the glass housing?
Willbo is offline
Old 06-06-2014, 11:05 PM   #75
Subi Speed
Member#: 387955
2015 WRX
Subispeed,
Actually I've been thinking about this for the last few hours. He said that it was adjusted from the factory all the way up.
The lamps are actually marked which side is the top. I believe the customer installed them upside down =(. As they tried to "lower" them, they were actually raising them. Eventually with enough torque on the adjustment, it basically gave way. We've sold hundreds of these for other platforms and never had a report that one was pointed to the sky.
This is the only explanation I can think of without getting the part back.
Closed Thread
