Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 10-22-2002, 05:59 PM   #1
GregUnd
Baaleted
Member#: 11800
Default How come our O2 sensor does NOT adjust A/F ratio?
I was reading and suposebly the O2 sensor's job is to tell the computer how much oxygen is in the exaust and allow it to adjust the A/F ratio....... I was always told that our ECU's do not do this? I knew that the O2 sensor was there to read how much oxygen was in the exaust but I did NOT know that the ECU was supposed to adjust the a/f ratio.... Mebe our ECU's DO adjust the a/f ratio and mebe this is why the cut out raises EGT's????? Help, i'm kinda nervouse now....
GregUnd is offline   Reply With Quote
Old 10-22-2002, 06:28 PM   #2
GregUnd
Baaleted
Member#: 11800
Coming out of HowStuffWorks.com
"When the oxygen sensor fails, the computer can no longer sense the air/fuel ratio, so it ends up guessing. Your car performs poorly and uses more fuel than it needs to. "
Old 10-22-2002, 06:50 PM   #3
Sam2
Member#: 15265
2002 WRX Wagon
WR Blue
You have to know about open -loop and closed-loop and when you're in which. before you know the answesr to what you ask.
Sam2 is offline   Reply With Quote
Old 10-22-2002, 06:53 PM   #4
GregUnd
Baaleted
Member#: 11800
Please explain....
Old 10-22-2002, 07:14 PM   #5
Sam2
Member#: 15265
2002 WRX Wagon
WR Blue
There's too much to cover for a post-it note. Study, my friend, study. Probably about a dozen sensors all figure into how much fuel to squirt in the next squirt.
http://www.ecutek.com.au/oem_data.htm
http://www.eiccd.cc.ia.us/~dhanan/ep2/NOTES7.TRP.html
http://members.shaw.ca/costall/ECUprimer/index.html
Old 10-22-2002, 07:15 PM   #6
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
I might get this backwards.....so if I do....someone say so....
Closed loop is when your ecu is taking readings from the O2 sensor and making fine adjustments to the mix to get it as close to stiochiometric as possible. This usually takes place when you're cruising down the highway.
Open loop is when the ecu is pretty much just dumping fuel into the engine based on MAF/MAP, TPS, and other sensors readings. Usually when this is taking place, you will run rich.
This happens when the car is cold.....also when you dump it....and around town, especially if you are on and off the gas. I doubt the ecu really would benefit from going into closed loop mode around town.....too much erradic throttle adjustments and such.
So....driving around in Houston.....you're rarely going to get into a steady closed loop mode for any length of time.
I'm pretty sure that's right. anyone agree/disagree with what I said.
josh
Legacy777 is offline   Reply With Quote
Old 10-23-2002, 12:40 AM   #7
JohnGalt00
Member#: 17035
02 WRX
I'm far from an expert on this as well, but AFAIK, you're on closed loop all the time below 60% TPS, or below some RPM like 4000.
JohnGalt00 is offline   Reply With Quote
Old 10-23-2002, 09:51 AM   #8
jmott
Member#: 6713
2007 Prius
brown
Default Re: How come our O2 sensor does NOT adjust A/F ratio?
the ECU can adjust the air fuel ratio, but it only does this work at idle and part throttle, because the 02 sensor cant react fast enough for operation at WOT. this is true of pretty much all cars.
at idle, if the car sees the engine running a bit rich, it will prescribe a correction factor (say, -5) to lean the car out and get it to the proper air/fuel ratio.
then, at WOT, it will apply that same correction factor to the static WOT fuel maps.
this works pretty well, but its correction abilities are limited. For instance, STI injectors put it out of range for this system to work at WOT.
jmott is offline   Reply With Quote
Old 10-23-2002, 09:53 AM   #9
jmott
Member#: 6713
2007 Prius
brown
your actually in closed loop most of the time. only when you get on it does it switch to open loop, for the reason I described above
josh
Old 10-23-2002, 11:50 AM   #10
D_REX
Member#: 8945
MY02 WRX
Just wondering why we use WB O2 sensors to measure A/F ratios for WOT tuning. If they don't react fast enough for an ECU to make corrections based off of their readings, how can we expect them to ract fast enough to tell me I need more fuel at 5Krpm etc.?
I've been looking at getting one of these DIY WB O2 sensors to use when I'm tuning, and this thread just brought this question to light.
Later,
Dustin
D_REX is offline   Reply With Quote
Old 10-23-2002, 11:53 AM   #11
jmott
Member#: 6713
2007 Prius
brown
Later,
Dustin
The problem of a human looking at a run over the rpm range, making adjustments, then trying again, is different than a car making adjustments in real time as a driver does whatever it is a driver does.
it seems like it might be possible to try and duplicate the mind of the tuner in an ECU that could tune the car after a few WOT passes or something. But then should that ECU do stuff like turn the car off if it sees you are running way to lean at the moment like a dyno tuner would? etc...
Old 10-23-2002, 11:59 AM   #12
D_REX
Member#: 8945
MY02 WRX
I'm refferring more specifically to the use of data logging (The tech edge stuff has data logging now) to dtermine your A/F ratio at an RPM and make adjustments based on that value. This would be the simplest possible implementation of closed loop control. Now I can see much more complicated algorithms using trends to determine needed adjustments, similar to your long term fuel trim but on a much more micro level.
If we cannot reliably use a WB O2 sensor to determine our A/F ratio at a given point then I want to identify that, and ideally quantify the error (be it a time shift or value shift), so that I can work around it.
How come our neighbour Canada can have Universal Healthcare but we can't?? maramaralula Political Playground 208 08-19-2009 11:26 PM
How to extend o2 sensor without wasting 30$ on extension? Un0RiGiNaL Normally Aspirated Powertrain 21 05-16-2009 05:45 PM
Damaged my O2 Sensor - does it matter? cwepruk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 10-09-2006 09:36 PM
BWAHAHAHAHAHA, how come OUR mods can't do this?! rogue Off-Topic 16 12-02-2005 12:30 PM
how to install O2 sensor, fuel filter and air control valve Suladed Service & Maintenance 4 11-11-2001 10:30 PM
