Old 05-28-2014, 02:59 AM   #1
DGMWRX13
Member#: 341072
2015 WRX
Default 2015 bluetooth will not connect
I can not connect my galaxy s5 to the bluetooth radio tried everything and nothing works, anyone else having this problem and possibly even find a solution? ty
DGMWRX13 is offline   Reply With Quote
Old 05-28-2014, 04:19 AM   #2
Guzzi 1
Member#: 338666
2014 Impreza Limited
SWP/Blk Leather CVT
Have you tried using the SWC's to pair? Pairing it up with the HU knobs doesn't seem to work. (Actually it works for the streaming music portion but not the phone portion.) Go in and delete whatever is there and begin from again.
John
Guzzi 1 is offline   Reply With Quote
Old 05-28-2014, 07:57 AM   #3
DGMWRX13
Member#: 341072
2015 WRX
Yea I tried that and deleting everything also still nothing.
Old 06-02-2014, 11:29 AM   #4
Nate l
Member#: 392488
Possibly reflash the phone. I have seen a few phone not link cause the Bluetooth protocols weren't installed correctly. Your S5 might also have a newer bluetooth version than the car. may have to see if you can update.
Nate l is offline   Reply With Quote
Old 06-02-2014, 01:07 PM   #5
dharel0bs11
Member#: 258998
2011 Outback Sport
Blue Pearl/Steel Silver
First make sure you delete any existing phone from the radio. Then when you go to add your phone back, use the steering wheel controls and follow the voice prompts. When adding the phone, change the passkey from the default of 1234 to 0000. Give that a shot and see if it works.
dharel0bs11 is offline   Reply With Quote
Old 06-04-2014, 09:16 PM   #6
ggta
Member#: 58421
2006 wrx stg3+??
gray
The default passkey seems to be the issue when pairing with the GS5. Change the passkey to 0000, like dharel0bs11 stated and pair both devices.
ggta is offline   Reply With Quote
Old 06-05-2014, 12:36 AM   #7
just slothing
Member#: 391935
2015 wrx
I had to reset the passkey to 0000 as well to get it to work. Why it works, no idea, but it does.
just slothing is offline   Reply With Quote
Old 06-06-2014, 10:56 AM   #8
Disk
Member#: 364449
figure this out? mine says it's paired but will not "connect" for phone or music audio. Tried deleting all phones, tried changing passkey
Also with the usb provided with the galaxy the display reads 'check device'
never had issues with my iphone and the car. I'm assuming this is due to the USB 3.0.. Has anyone gotten the s5 to play audio through the car with the usb? or bluetooth.. I can't stand radio for my 1.5 hr commute.
Sidenote dealership told me to try a different cord because their phone worked just fine... but it was an iphone. thanks dealership.
Disk is offline   Reply With Quote
Old 06-06-2014, 05:33 PM   #9
3n1gm4
Member#: 227728
2015 WRX (base)
I reset my HU passkey to 0000 then connected it through the HU then the steering wheel. it was a beating!
3n1gm4 is offline   Reply With Quote
Old 06-06-2014, 06:06 PM   #10
sc00ter
Member#: 117767
2015 WRX
CWP
For what it's worth, the S5 is still currently on 4.4.2 which is known to have some major Bluetooth issues. I experienced this when trying to pair my Nexus 5 to my STI. Luckily some ROM developers were able to fix the Bluetooth hiccups in a patch and I used that to get the phone to pair/stream properly.
They've fixed these in the new release of 4.4.3. However, since the S5 won't likely be getting this update for some time I'd suggest looking at other ROM solutions that may have Bluetooth fixes.
Also, even after getting the phone updated, it took an additional 5 tries to get it to pair correctly through voice commands/steering wheel controls. But once it paired I never had an issue afterwards. Not sure if this helps you or not but good luck!!
sc00ter is offline   Reply With Quote
Old 08-02-2014, 12:57 PM   #11
subienoobie2029
Member#: 260706
2015 WRX Sedan
so i was having the exact same problem for the past two days since i got the car... and i tried the 0000 passcode.. WORKED LIKE A CHARM. i wanted to kick myself for not trying that earlier LOL we need to pass this info along
subienoobie2029 is offline   Reply With Quote
Old 08-02-2014, 09:55 PM   #12
t0FUTurKeYyYy
Member#: 394416
2015 STI
crystal white pearl
I also had the same issue with my '15 sti + my galaxy S5. I also just changed the password to 0000 and it ended up finally working.
t0FUTurKeYyYy is offline   Reply With Quote
Old 08-06-2014, 05:50 PM   #13
linuxdream
Member#: 394907
2015 WRX STI
Galaxy Blue
Passcode as others have said. Not sure if anyone else had this issue but there is a significant lag on answering calls. The phone will ring through the speakers 1-2 more times before the call actually picks up. Very annoying.
linuxdream is offline   Reply With Quote
Old 04-09-2015, 07:30 PM   #14
KahaluuYETI
Member#: 395297
2015 WRX Base
WR Blue
This has worked for me also, resetting the password to numbers 0000 was the key, nothing else worked but this thank you guys.
KahaluuYETI is offline   Reply With Quote
Old 05-03-2015, 06:24 PM   #15
Los Angeles Sub_02
Member#: 410317
2015 WRX
Use the audio setup through the steering wheel controls. I almost lost my mind trying to use the HU ones. The phone would pair, but wouldn't auto connect after turning off the car. My old phone was still paired through the steering wheel controls, deleted the old, paired the new and we're back in business. Using the steering wheel worked on the first attempt, I tried the HU maybe five times.
Los Angeles Sub_02 is offline   Reply With Quote
Old 05-12-2015, 03:39 PM   #16
musicman132
Member#: 420091
2015 WRX
WR Blue
I could not get my galaxy s5 to work, my Iphone 5 from work connected right away.
It wasn't until I read this post and changed my passkey to 0000 that my galaxy connected. Now everything works great!
musicman132 is offline   Reply With Quote
