Old 10-23-2002, 12:08 AM   #1
gooter80
Member#: 25519
Steel Grey
Default need help with my stock/morette lights!!
well i just took out my morette headlamps cause i sold them. now i put the stock ones back in until my jdms arrive but they dont work properly. first off when on low beam, the high beam blue light on my gauge cluster is on but only about half lit. no fogs on under low beam either. then when high beams are supposed to be on, the lights shut off completely. i have no idea whats going on. anyone have any idea??
ps sorry if this is in the wrong forum
thanks!!
gooter80 is offline   Reply With Quote
Old 10-23-2002, 05:10 AM   #2
Turbo X
Member#: 26249
02 Impreza WRX
And they're RHD too , right? should kept your Morrette...
Turbo X is offline   Reply With Quote
Old 10-23-2002, 07:46 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I'll take a guess here and assume your Morettes didn't have the plug-in harnesses so the factory wires had to be cut and spliced to install them? Obviously they were not reconnected properly and that is why you are having problems now. I can't help you without seeing the car, you need to go over the wiring and fix whatever is connected incorrectly. If you didn't do it yourself and you aren't familiar with how it is wired, try enlisting the help of someone in your local area with the proper skills.
You don't specify your location but if you happen to be in the NYC/LI area I may be able to help you, if so PM me. Otherwise I suggest you make a post in your regional area forum and ask for help.
Old 10-23-2002, 07:54 AM   #4
500hpwrxsti
Member#: 22459
2002 WRX GT40R
700AWHP but whos counting
Hey guy,
I have morrettes on my scubie and I didnt have to do any cutting of wires. Those are direct bolt in and direct plug in. I guess someone didnt know what they were doing when installing them. I have no answer for you on how to rewire them without looking at it.
500hpwrxsti is offline   Reply With Quote
Old 10-23-2002, 10:10 AM   #5
gooter80
Member#: 25519
Steel Grey
well actually my morettes do have the adapter harness so they are completely plug and play. in fact i put them back in last night to see if i could figure out what the problem is and they worked perfectly. thats why i cant undersand what is wrong when i put the stock ones back in....
Old 10-23-2002, 10:17 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Check your headlight fuses, you may have blown one and this could possibly cause some strange behavior. Other than that just make sure the connectors are seated properly into the headlights, and that none of the pins on either part (headlight or harness connector) are damaged or bent.
Edit-
Actually re-reading what you said if the Morettes still work ok then the fuses are probably good but check anyway. More likely something happened to the stock lights to cause this. Pay close attention to the male connector pins inside the connectors on the stock bulbs, be sure the bulbs themselves are still good.
Need help wiring my GC Morettes XanRules Electrical & Lighting 3 11-02-2009 03:31 PM
Need help with my Hella lights. SkirtBoy Off-Topic 2 12-09-2005 01:17 PM
Really need help with someone's Boost gauge light theory ST1Ddope Interior & Exterior Modification 7 03-08-2005 12:26 AM
I need Help with my install! HELP! mrubino83 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-08-2004 01:11 AM
Need help with my side lights (pics inside) dorifto88 Electrical & Lighting 3 10-08-2003 02:09 PM
