Old 10-23-2002, 02:31 AM   #1
Danny619Boy
Member#: 27573
2007 STI Limited
Satin White Pearl
Thumbs down Turbo timer install
I tried to install the blitz turbo timer but i couldnt so i put everything back together but now my engine check light is on and my car idles funny. it goes up and down and its really bugging me. anyone know whats going on?
Danny619Boy is offline   Reply With Quote
Old 10-23-2002, 02:45 AM   #2
MMBOOST
Member#: 24140
02 Impreza WRX
http://www.logmapper.com
The only critical things you touch for install are you ignition near the ignition switch and the RPM line to the ECU for an auto timer mode. I'm going to guess you have the blitz TT which has an auto timer. If that's the case, then I would guess you mangled the RPM line to the ECU. I would re-check how you put it all back together, esp. to the ECU.
jason
MMBOOST is offline   Reply With Quote
Old 10-23-2002, 02:58 AM   #3
Danny619Boy
Member#: 27573
2007 STI Limited
Satin White Pearl
i just unplugged some plugs. i have no clue on the installation of a turbo timer. i though by reading the instructions i could do it but i couldnt so im gonna have a shop do it. should i just go to the dealer and have them check out the problem?
Old 10-23-2002, 04:10 AM   #4
MMBOOST
Member#: 24140
02 Impreza WRX
I wouldn't go to a dealer about this. Who knows what they'll accuse you of . Get it installed at the shop.
I was going to say to try this after you get it installed at the shop, but it can't hurt to try it now. Reset your codes by unbolting the negative line from your battery. Step on the breaks for 15 seconds. Wait a few minutes. Put the negative back on the battery. This generally gets rid of non-recurring CELs.
If the CEL and symptoms return try it again after the shop installs. If the symptoms are still around after that, go to the dealer or come back to us
jason
Old 10-23-2002, 04:18 AM   #5
Danny619Boy
Member#: 27573
2007 STI Limited
Satin White Pearl
Thanks for the info. ill get back after i try out you method
Turbo Timer installed gossamer_monster New England Impreza Club Forum -- NESIC 0 05-05-2001 04:02 PM
turbo timer installation ? initialWRX North West Impreza Club Forum -- NWIC 1 05-04-2001 12:45 PM
turbo timer install? jacklock New England Impreza Club Forum -- NESIC 5 05-04-2001 12:24 PM
turbo timer install vtec_this Normally Aspirated Powertrain 6 03-10-2001 09:12 PM
Turbo Timer installer in Seattle RA North West Impreza Club Forum -- NWIC 0 01-01-2001 11:50 PM
