Old 10-23-2002, 11:42 AM   #1
itsmywifescar
Member#: 15682
Question Weird water pouring noise at startup! 97 Impreza Outback Sport
I have a '97 Impreza Outback Sport and have noticed a strange noise when I first drive off after starting the car. It sounds like water pouring or draining. I suspect that rain water is pooling somewhere under the hood maybe and it is pouring out as I drive away. Anyone experienced this? Or is it possibly the sound of coolant starting flow?
I have also found some evidence of a water under the back seat (when you flip it up). It appears that water is leaking somewhere from rain and running down the frame rails and sitting beneath the seat. Any ideas for where to check for leaks?
itsmywifescar is offline   Reply With Quote
Old 10-23-2002, 06:28 PM   #2
jcblack
Member#: 3711
02 WRX Wagon
Silver Platinum
I had a 97 obs for 2 years and seem to remember the same sound and I've heard it in other cars. I think it has to do withthe A/C. have you been using it?
jcblack is offline   Reply With Quote
Old 10-23-2002, 10:36 PM   #3
Mandrich
Member#: 27002
2014 Impreza WRX
Gray
Default Re: Weird water pouring noise at startup! 97 Impreza Outback Sport
Though I have found no evidence of leaks, I also hear that noise regularly. I would think it's got something to do with the coolant as I only tend to hear it when the car is cold.
HTH,
Mark
(00 OBS)
Mandrich is offline   Reply With Quote
Old 10-23-2002, 10:47 PM   #4
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 XV, '99 RS
Check you A/C condensor drain hose. It's located on the passenger side firewall in the engine compartment close to the bottom of the car. If it gets clogged (with bugs, dirt, leaves, whatever) the water from you A/C gets trapped in the condenser unit in the dash, once it gets too full it overflows into the passenger side and usually ends up under the seat. The water you hear sloshing around is the same water you find in the car later.
The hose is black rubber, about 3/4" diameter and about 6" long. It points towards the ground.
Opie is offline   Reply With Quote
Old 10-24-2002, 03:54 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
that or your coolant is low and the noise you are hearing is the fluid moving back into the heater core.
jeremy
looking for stock rims for 97 impreza outback sport Doob Canada Region Forum 1 10-27-2005 11:19 PM
Question on pricing for a 97 Impreza outback sport, needs waterpump. mysubaruimp Private Vehicle 'For Sale' Classifieds 4 10-15-2005 05:36 PM
FS: FL: 97 Impreza outback sport 5speed - low price thodi Private Vehicle 'For Sale' Classifieds 0 04-24-2004 12:56 PM
Guaging Intrest - 97 Impreza Outback Sport Braknstuf Private Vehicle 'For Sale' Classifieds 1 10-07-2003 10:56 AM
97 impreza outback sport questions... greyrain743 Newbies & FAQs 5 10-11-2001 12:47 PM
