Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 10-23-2002, 01:25 PM   #1
key master
Member#: 27515
2003 Impreza 2.5 RS
Platinum Silver Metallic
Question Can the rear LSD diff from 03 WRX be used on a 03 RS 2.5?
The subject pretty much says it all. I can't believe the LSD isn't an option for Impreza RS 2.5 buyers... I would have paid extra for it. Well, I'm now wondering if it can be bolted in using the WRX part? I have an automatic by the way.
In other words, what's the best way to get a LSD (limited slip differential) into the rear of my car? I'm more interested in the rain/snow perspective and not really autocross performance.
Thanks,
-Jim
key master is offline   Reply With Quote
Old 10-23-2002, 03:08 PM   #2
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
Nope, not unless you replace the front diff too.
The ratios are different.
4.11 (RS)
3.9 (WRX)
Now a LSD out of a 98-99 MIGHT be possible, but that is a whole different story and body.
DDMan is offline   Reply With Quote
Old 10-23-2002, 03:41 PM   #3
key master
Member#: 27515
2003 Impreza 2.5 RS
Gotcha.
Well, on my other car (a Chevy), you can bolt up a different ring to the differential and make it any ratio you want. Is that not the case with Subaru differentials? If it is possible, I would think one could unbolt the RS 4.11 ring from the old diff and bolt it onto the WRX diff with the old WRX 3.9 ring unbolted and discarded.
Possible? The only way I see that not being possible is if they are different sizes...?
Thanks for the response,
-Jim
Old 10-24-2002, 03:44 AM   #4
kaos200
Member#: 2692
Originally posted by key master
Gotcha.
-Jim
your right, the Ring/pinion CAN be swapped, BUT I dont know if axles are different. As sometimes they were between the 2.5s that had/didnt have LSDs
kaos200 is offline   Reply With Quote
Old 10-24-2002, 10:59 AM   #5
IggDawg
Celebrity Guest Star
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
You'll need the driveshafts too. They're different on the LSD and open diff.
-IggDawg
IggDawg is offline   Reply With Quote
Old 10-24-2002, 11:47 AM   #6
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Only the MY00-01 RS came with an LSD.
IT should bolt right up.
Impreza Rider is offline   Reply With Quote
Old 10-24-2002, 12:00 PM   #7
IggDawg
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
just remember, need the driveshafts too. not just the diff.
-IggDawg
Old 10-24-2002, 04:09 PM   #8
oem
Member#: 330
Default WRX rear diff
The rear diff of a WRX is actually a 3.5 the transfer gears in the transmission are 1.1 to 1 making it compatable with the front 3.9
oem is offline   Reply With Quote
Old 10-24-2002, 06:56 PM   #9
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
He also said that he has an auto RS so his ratio is 4.44:1
-Wes
RebelINS is offline   Reply With Quote
Old 10-25-2002, 07:46 PM   #10
Porter
Member#: 486
2004 Forester XT
bug spattered
He needs a rear LSD out of an older STi v4 or v5. It should bolt right in... though he may need new rear axles due to the spline difference.
Porter is offline   Reply With Quote
Old 10-25-2002, 09:54 PM   #11
Kikin
Member#: 170
2006 Forester XT
Regal Blue Pearl
Also he can use one out of an auto Forester S 01. They have the 4.44 LSD.
Kikin is offline   Reply With Quote
Old 10-29-2002, 12:32 PM   #12
key master
Member#: 27515
2003 Impreza 2.5 RS
Thanks for the GREAT information all!!
-Jim
Old 10-29-2002, 03:36 PM   #13
Porter
Member#: 486
2004 Forester XT
bug spattered
Ya, the rear LSD out of a 2000-2001 auto 2.5RS, auto Forester, or manual STi v4 or v5 will ALL work.
03 wrx aero parts on an 04 2.5 RS?? digi Interior & Exterior Modification 10 12-24-2003 02:47 PM
RS 2.5 Front Diff...open or LSD? Prophet Normally Aspirated Powertrain 4 12-13-2002 05:58 PM
Can 02 WRX rear brake section can be used on a 96 L model? SONofSAM Brakes, Steering & Suspension 2 10-29-2002 12:47 PM
Has anyone installed STi Strut tops on a '02 RS 2.5? ThinkTank Brakes, Steering & Suspension 5 07-15-2002 03:46 PM
Backfiring on Brand New RS 2.5 csmetana Technical Forum Archive 15 09-21-2000 12:28 AM
