Welcome to the North American Subaru Impreza Owners Club Thursday July 2, 2015
Old 10-23-2002, 05:20 PM   #1
codean
Member#: 10186
Default Utec boost reading, how good is it?
Looking at some of the logs that I took I never reached over 14.1 psi. However my boost gauge is reading higher (15-15.5 psi). So which one should I trust more. The utec or my gauge.
BTW. My gauge is a 52mm defi link hooked up to the BOV line.
codean is offline   Reply With Quote
Old 10-23-2002, 05:49 PM   #2
SpeedRacer-X
Member#: 27028
My Defi V1 gauge is 1PSI off...
Shawn
SpeedRacer-X is offline   Reply With Quote
Old 10-23-2002, 06:19 PM   #3
8Complex
Member#: 922
04 FXT
Red
Always trust the sensor... it's much more accurately calibrated then a mechanical gauge is.
Old 10-23-2002, 09:15 PM   #4
jjunior887
Member#: 16738
2015 WRX Limited
CWP
I'm having the same problem with mine, I was reading 14 or so stock now I'm reading about 1.5-2 psi higher than the Utec is seeing.-James
jjunior887 is offline   Reply With Quote
Old 10-24-2002, 04:43 PM   #5
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Default Re: Utec boost reading, how good is it?
Trust the UTEC... but make sure you've gone through the MAP calibrations in the manual.. a deltadash works GREAT for that.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 10-24-2002, 04:45 PM   #6
JenisonWRX
Member#: 6049
02 WRX & 99 RS
the stock sensor uses absolute MAP ... no reason to distrust it.
unless its a bad sensor
JenisonWRX is offline   Reply With Quote
Old 10-24-2002, 05:55 PM   #7
jjunior887
Member#: 16738
2015 WRX Limited
CWP
anyone around Northern Va have a Delta Dash I could borrow for a few minutes?-James
Old 10-24-2002, 06:09 PM   #8
radwrx
Member#: 12501
My OEM boost guage is spot on with the UTEC.
-Mike
radwrx is offline   Reply With Quote
Old 11-28-2002, 07:48 AM   #9
sdecker
Member#: 14717
2002 WRX, WR Blue
Complete n00b Racing
Bump for more info...
My UTEC reads consistently 1-2 psi less than my stock boost gauge. For now, I'm going to use the numbers that the UTEC shows...
I have a dyno appointment with Nathan this Saturday, so I'll try to get the definitive answer from him.
Anyone else have any info?
Scott
sdecker is offline   Reply With Quote
Old 11-29-2002, 12:10 AM   #10
pace
Member#: 11606
2004 Pilot
1995 Miata
Like Jorge said, you need to calibrate your MAP sensor via the Gradient and Intercept constants as described in the manual. The stock values supplied with the unit are for a sea-level calibration, and as such your MAP will report low readings at any elevation above sea-level.
Once your MAP is calibrated it will report manifold pressure that is zero-referenced at your specific elevation. This information was gleaned through my observation of it zeroing at -4.5psi up here at 8000ft, and my subsequent experimentation with the calibration process.
Statements like "the stock sensor uses absolute MAP" are somewhat misleading. The UTec provides a functional transformation that translates the absolute MAP voltages to a relative PSI reading, using the Gradient and Intercept constants. These PSI readings only appear 'absolute' for Gradient and Intercept values that were configured at sea-level. Essentially these two constants provide you with a mechanism to zero-reference your specific MAP sensor at your specific location. Once calibrated, the MAP PSI values you see in the logs will then corroborate your relative boost readings shown on your gauges.
-Pace
pace is offline   Reply With Quote
Spec c roof vent, how good is it? plucebo Interior & Exterior Modification 95 03-31-2011 08:58 PM
spec c roof vent, how good is it? plucebo Newbies & FAQs 3 03-16-2006 07:14 AM
Praxis system. How good is it.? dntouch Brakes, Steering & Suspension 10 08-30-2005 03:49 AM
emanage how good is it? marek Engine Management & Tuning 2 08-28-2003 11:48 PM
G Tech....how good is it?? mattman_4444 General Community 5 11-07-2002 02:29 PM
