Old 10-23-2002, 07:06 PM   #1
Dakken
Member#: 24570
wrx 13.51@98 1/4
1.72 best 60ft
Default Stock tuning
hey guys
I'm going to be getting an Sti scoop and intake...
I'm looking to find out where/how to tune my engine which is totally stock (Silencer removal..yes!!! and possibly grounding it this week) to its best... what would the best thing to do be?
Thanks
Scott
Dakken is offline   Reply With Quote
Old 10-24-2002, 04:31 AM   #2
Delicious Tuning
Member#: 1990
Do you have any kind of piggy back or engien management in your car? If you don't I don't believe there is anything out there to tune a Stock ECU yet.
IF you don't there is nothing you can do except drive the car around hard for a short time after a ECU reset. This will cause the ECU to notice difference in air flow and adjust for it. That is about all you can do.
Delicious Tuning is offline   Reply With Quote
Old 10-24-2002, 03:01 PM   #3
Dakken
Member#: 24570
wrx 13.51@98 1/4
1.72 best 60ft
With the ECU reset, is alot of power lost for a period of time? or will it go back to stock and "Learn" that theres more airflow and run better that way? I dont know much about car computers as you can see. haha
Old 10-24-2002, 03:11 PM   #4
Delicious Tuning
Member#: 1990
No problem...
The ECU reset will set go back to the base map for the WRX. Which is a good starting point for the WRX. From there, since you added the intake, the car will readjust differently to that mod. It will notice more airflow and therefore either need to add more fuel (more then likely) or pull timing (doubtful).
The other suggestion is to put everything on and don't do an ECU reset, because it will notice more airflow and start adjusting anyway. So either way will work.
I am not sure if you will notice a big difference or not but you might with the intake. The hoodscoop I would doubt you will notice anything from that. Could be wrong though.
Old 10-24-2002, 06:33 PM   #5
Dakken
Member#: 24570
wrx 13.51@98 1/4
1.72 best 60ft
I just figured there might be a way to make even a totally stock engine run better
thanks guys
Stock tune ok with catless uppipe, stock DP and aftermarket catback? ilikebmx999 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 12-19-2009 02:09 AM
bugeye, downpipe, stock tune...=ok right?? 02boxer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 03-24-2008 11:51 AM
flash back to stock tune? conrad87 Commercial ECU Reflashes 2 03-01-2008 12:08 AM
Stock tune stijatt Newbies & FAQs 2 01-14-2008 01:22 AM
Stock Tune 07 STI Datalog Boxer4u Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 12-04-2007 02:23 PM
