Old 06-21-2014, 10:33 AM   #1
veel86
Member#: 308550
2006 Wrx STi
Default Logging LC-1 DB Innovate Wideband
What comm to usb cable are people using to log a/f? The one I have doesn't work correctly.
veel86 is offline   Reply With Quote
Old 06-21-2014, 11:24 AM   #2
JonnyV2889
Member#: 197384
2006 WRX Ltd
I've been successful with staples serial to USB. Still yet to get my plx PCB working successfully.
JonnyV2889 is offline   Reply With Quote
Old 06-22-2014, 06:29 AM   #3
veel86
Member#: 308550
2006 Wrx STi
Plx PCB?
Old 06-22-2014, 08:54 AM   #4
JonnyV2889
Member#: 197384
2006 WRX Ltd
Plx PCB?
Sorry, it's Pololu not PLX.
http://www.pololu.com/product/391
Here's more info
http://www.romraider.com/forum/viewt...=4299&start=45
Old 06-22-2014, 08:11 PM   #5
Subiesaurus Rex
Member#: 188552
PM SKIMSTI 4 help
installin your Downpipe!
What do you mean by "doesnt work correctly"? I am trying to get my new MTX-L wideband (innovate) working with AccesstunerRace currently. I have had success getting the gauge to communicate with the Logworks software but cant seem to get it to output anything to the ATR software. I am using the "Belkin F5U257 USB to Serial Cable Adapter".
Subiesaurus Rex is offline   Reply With Quote
Old 06-23-2014, 12:12 PM   #6
veel86
Member#: 308550
2006 Wrx STi
When I plug in my wideband to my computer it throws all my data off and doesn't log a/f
Old 06-23-2014, 12:27 PM   #7
JonnyV2889
Member#: 197384
2006 WRX Ltd
Does logworks show correct data?
Old 06-23-2014, 07:31 PM   #8
veel86
Member#: 308550
2006 Wrx STi
I can't get it to connect to log works either.
Old 06-23-2014, 08:08 PM   #9
JonnyV2889
Member#: 197384
2006 WRX Ltd
Either a driver or setting issue. What is the baud rate set to? Is windows trying to use the same com port for multiple devices? Try 9600 for the baud rate. I haven't put log works on my new laptop so I can't confirm. Try it without logging the ecu.
Old 06-23-2014, 08:16 PM   #10
veel86
Member#: 308550
2006 Wrx STi
Well when Romraider tells me to select a com port for the wideband it gives me no comport options.
Old 06-23-2014, 08:16 PM   #11
veel86
Member#: 308550
2006 Wrx STi
I'm not sure what a baud rate is either.
Old 06-23-2014, 08:20 PM   #12
BB2006LGT
Member#: 367150
BB2006LGT is offline   Reply With Quote
Old 06-23-2014, 08:30 PM   #13
JonnyV2889
Member#: 197384
2006 WRX Ltd
What is your operating system? You need to get log works working before romraider ever will.
Old 06-23-2014, 08:43 PM   #14
veel86
Member#: 308550
2006 Wrx STi
Okay
I have windows 7
Old 06-23-2014, 09:06 PM   #15
JonnyV2889
Member#: 197384
2006 WRX Ltd
Okay
I have windows 7
I think it should be 19200, not 9600.
http://www.digi.com/support/kbase/kb...ltdetl?id=3418
You need to know what com port it is, different on every machine. You can change it's number to a higher one to be sure standard com 3/4 isn't having conflicts.
PS you're changing "bits per second"
Old 06-24-2014, 07:57 AM   #16
veel86
Member#: 308550
2006 Wrx STi
Thank you for posting that link.
I'll follow those steps after work tonight.
Old 06-26-2014, 12:38 PM   #17
veel86
Member#: 308550
2006 Wrx STi
I'm sorry for the delay guys I will try to get it done tonight.
Old 06-26-2014, 09:57 PM   #18
veel86
Member#: 308550
2006 Wrx STi
In my "Device Manager" I do not have a Com Port tab.
I have a universal serial bus controllers tab, and SD hot adapters tab. Their are others but they don't seem like they would be relevant.
Old 06-27-2014, 08:33 AM   #19
JonnyV2889
Member#: 197384
2006 WRX Ltd
There should be a "ports" option. Try plugging in your tactrix to see if it appears. With nothing connected to mya win8 laptop I only show two BT coms. Maybe you don't have anything active and it's not giving you the option.
You could try this if you're comfortable.
https://learn.adafruit.com/how-to-fi...ports/overview
Old 06-27-2014, 08:36 AM   #20
veel86
Member#: 308550
2006 Wrx STi
Ah okay, thats a good idea I will try again.
