Old 06-23-2014, 01:27 AM   #1
victork
Member#: 374526
Default used viscous coupler question
Im pretty sure a worn rear wheel bearing i just replaced had something to do with my viscous coupler going bad because when i turn in or out of a parking space its hopping and making a sound as if something was lose and binding periodically.
Anyway, i have the original tranny set aside still after upgrading to the 04 tranny but it looks like the clip is in there in pieces and theres some chipped teeth on the gears inside the diff.
THE MAIN QUESTION: the VC from the old tranny was smooth when i took the tranny out but should i not use it because there was some metal floating around or can i clean it good some how and re use it? The bearing on the outside of the VC is still smooth
victork is offline   Reply With Quote
Old 06-23-2014, 02:44 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
the diff had NOTHING to do with killing the bearing
and the 04 trans wasnt any sort of 'upgrade' regardless of what anybody thinks
fantasy
Old 06-23-2014, 11:27 AM   #3
victork
Member#: 374526
I dont think the diff wore the bearing, i think the bearing had some part of the VC going bad because the tire on that wheel is worn more than the others showing there was drag on that wheel.
Old 06-23-2014, 11:38 AM   #4
victork
Member#: 374526
I could be wrong lol can i clean that VC from the original 108k mi tranny or should i not use it because there was some metal floating around? I dont know how durable they are in terms of withstanding some possible debree in there...
Old 06-24-2014, 02:06 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
i dont think you should be playing with any of this because you dont know what the hell you are doing
the viscous coupler is SEALED and not servicable
Old 06-24-2014, 12:55 PM   #6
drewmob
Member#: 214192
2003 WRX
It's probably fine to use. Every trans I've drained has had some degree of metal shaving.
Ignore the douchebaggery. That guy doesn't think through issues before trolling.
drewmob is offline   Reply With Quote
Old 06-24-2014, 06:18 PM   #7
victork
Member#: 374526
I never said anything about taking it apart stay out of my thread a hole. I meant clean what i can thats exposed because theres small chunks of a few teeth off the gears in the diff... i think im gonna use it seeing as it was good when i pulled that tranny and i have access to a lift to do it myself
Old 06-24-2014, 08:43 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
FULL
****ING
STOP
the OP is 100% talking about taking things apart
it is GLARINGLY APPARENT he has no bloody clue as to what he is doing and had NOT done any research at all on this
I have seen this before, here, many times since i joined the board in 2002 so i am in no way trolling anybody or anything
if you are too ****ing stupid to see this, i am NOT
the OP obviously does not know what he is asking or wanting
I CAN NOT HELP THAT.
I CAN CORRECT HIM.
AND I DID.
PISS OFF
Old 06-24-2014, 09:18 PM   #9
victork
Member#: 374526
Pretty much all i wanted to know is if more experienced people think i should toss the VC because there was pieces of gear floating around. i did do some research and i do realize the VC is phase 2 and only phase 1 can be rebuilt. Phase 2 is 99 up or 99-07 and cant be rebuilt. It does however look like pieces can get in the gears that are exposed in the middle of the unit. I really dont wanna be in a internet tough guy match so im gonna carry on
Old 06-24-2014, 09:21 PM   #10
victork
Member#: 374526
And yes, i was talking about taking my spare original tranny apart because thats where the VC is and i wanted to see how easy it is amd its easy
