Old 06-24-2014, 11:31 PM   #1
silversurfer05
Member#: 366241
2005 05 4eat built
psm
Default HELP HELP 4eat in limp mode after build
i did some research but didnt find anything that i have not tried yet. just did a full engine build with stg 2 cams and upon the first drive, the trans feels as if it starts in first and goes to third at roughly 8mph.... before the build everything was perfect, solid shifts, all gears were working and felt like butter.
what would cause this if the trans wasnt touched? 120k on trans but how would it go bad while it wasnt used?
silversurfer05 is offline   Reply With Quote
Old 06-26-2014, 10:21 AM   #2
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
Have you tried shifting it manually through the gears?
WRX_02_227 is offline   Reply With Quote
Old 06-26-2014, 06:28 PM   #3
silversurfer05
Member#: 366241
2005 05 4eat built
psm
yes and it wont change gear when i try
Old 06-26-2014, 09:16 PM   #4
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
Recheck all your harness connections and make sure you connected the trans fluid cooling lines back up correctly.
Any CELs?
Old 06-26-2014, 10:57 PM   #5
silversurfer05
Member#: 366241
2005 05 4eat built
psm
i have the p0778 2-4 brake duty code but everything was working previously and i checked all the connections and they are good but i did find a plug by the brake pedal but no where to plug it in to
Old 06-27-2014, 08:05 AM   #6
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
http://engine-codes.com/p0778_subaru.html
Google "p0778 subaru" and a bunch of stuff comes up.
By any chance, did the trans fluid pan get dented or anything during your build?
Old 06-27-2014, 08:31 AM   #7
silversurfer05
Member#: 366241
2005 05 4eat built
psm
looks fine to me and ive been googling this for 2 weeks lol
Old 06-28-2014, 03:29 AM   #8
silversurfer05
Member#: 366241
2005 05 4eat built
psm
bump..
Old 07-03-2014, 12:58 AM   #9
silversurfer05
Member#: 366241
2005 05 4eat built
psm
bumpp
Old 07-31-2014, 11:03 PM   #10
imprezive tek
Member#: 290942
01 WRX
Did engine go in smooth? No gap between trans when bolting up? Just wonder if the oil pump my of got damaged?
imprezive tek is offline   Reply With Quote
