Old 10-24-2002, 01:47 AM   #1
Jake Steed
Member#: 24756
2002 WRX sedan with
scratch marks and dirt
Default VF series turbo size compared to Mitsubishi..
I was wondering how big the various VF series turbos are compared to the Mitsubishi turbos.
For example is a VF34 around the same size as a 16G? Also, does anyone know how many CFM's they flow?
Jake Steed is offline   Reply With Quote
Old 10-24-2002, 02:10 AM   #2
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
This is from www.wrxworld.com
Stock Turbo 360CFM at 14.7PSI
IHI VF-22 435CFM at 18.0PSI
Small 16G 505CFM at 14.7PSI
Large 16G 550CFM at 14.7PSI
20G 650CFM at 14.7PSI
AVO 450HP 630CFM at 20.0PSI
AVO 500HP 740CFM at 23.0PSI
I'm running the new AVO 500HP turbo. Just intalled, tuning right now, dyno number soon. 24psi at 8k RPM is pretty sweet though.
-Jeff Sponaugle
sponaugle is offline   Reply With Quote
Old 10-24-2002, 07:23 AM   #3
VetteVert
Member#: 5961
2005 STi
CGM
Make sure to post a new thread with the info
VV
-Jeff Sponaugle
VetteVert is offline   Reply With Quote
Old 10-24-2002, 08:23 AM   #4
Austin
Member#: 7089
2016 STi
-Jeff Sponaugle
So, what you're saying is... I'm *not* going to be passing you this Sunday?
Those AVO's are bolt on, internally gated, right? Any problems so far controlling boost?
Austin is offline   Reply With Quote
Old 10-24-2002, 12:13 PM   #5
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Well..... Yea. Thats the plan at least. I just put in the 3 bar map sensor so I can run 24-25psi with the link correctly. booohhahahaahah.
It's no autocross turbo, but at the track it should be pretty rocking.
Yes, the AVO is a direct bolt on (actually it did require a bit a work, just a few minor tweaks). Internally wastegated, and no problems with boost yet.. but then again I'm running 22+ psi, so I might not notice it is creeped at lower psi. This is not a turbo to run at 16psi... it is less efficient there than at 20..
Jeff
Old 10-25-2002, 12:35 AM   #6
annointed
Member#: 5960
FXT [email protected] 93 oct
NSX 450 whp SC'd (93 oct)
Also, FWIW, the 18G compressor wheel flows 600 cfm @ 1 bar (which is 14.5 or 14.7 psi, depending on the source)
annointed is offline   Reply With Quote
Old 10-25-2002, 01:05 PM   #7
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Updated
AVO 320HP 429CFM at 17.5PSI
AVO 400HP 572CFM at 17.5PSI
18G 600CFM at 14.7PSI
Anyone with the SR30/40/50 numbers?
Old 11-13-2002, 03:51 PM   #8
scottm1978
Member#: 13284
so what is the spec for a VF30?
Updated
scottm1978 is offline   Reply With Quote
Old 11-13-2002, 05:42 PM   #9
BamBooI
Member#: 10945
2006 Evolution IX
Someone make some dsm turbo ready uppipe and downpipe please!!!!! Big 16g!
BamBooI is offline   Reply With Quote
Old 11-13-2002, 11:08 PM   #10
DanMan
Member#: 5009
24 psi! What is the compression on your motor jeff? 8:1 or 9:1? Also, do you know if the pistons/rods are forged? I mean... man, that's a lot of air you're pushing.
Also, what are your thoughts on running such a large turbo off of a rather restrictive inlet hose? How large is the inlet on that turbo compaired to your VF22 (outside diameter, i'm sure its tapered to the edge on the inside).
And finally, where are you seeing the onset of boost and when do you see full boost? Once again, seems like a lot of turbo for a stock style uppipe and downpipe.
Thanks Jeff!
Dan
Jeff
DanMan is offline   Reply With Quote
Old 11-13-2002, 11:29 PM   #11
BamBooI
Member#: 10945
2006 Evolution IX
Thanks Jeff!
Dan
He has a Sti swap I believe and he is not running stock up and downpipes...
Old 11-13-2002, 11:32 PM   #12
tuca33
Member#: 24303
2002 Impreza WRX
What are the numbers for the VF34??
PE1818 and PE1820?
Thanks
Tuca
tuca33 is offline   Reply With Quote
Old 11-13-2002, 11:50 PM   #13
DanMan
Member#: 5009
Yes, I know. And he's still running a perrin uppipe and a BPM downpipe which still follow the stock design.
Dan
Best Place to buy a vf series turbo??? disque71 Newbies & FAQs 8 09-24-2004 09:37 PM
Best Place to buy a vf series turbo??? disque71 Normally Aspirated with bolt-on Forced Induction Powertrain 2 09-24-2004 06:40 PM
Anybody in MI looking to sell a VF series turbo? Hondaslayer Mid West Subaru Owners Club Forum -- MWSOC 11 10-31-2003 09:12 AM
Whats needed to run a VF series turbo? Impreza25RS Normally Aspirated with bolt-on Forced Induction Powertrain 13 01-12-2003 01:17 PM
which of the aps sr series turbo can compare to a garrett t3/t4 STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-25-2002 07:47 PM
