Vancouver Impreza Club
Closed Thread
Old 10-24-2002, 04:19 PM   #1
MrJaemz
Member#: 18211
1997 Impreza 2.2L
Yellow
Question Sway bars worth the $ ?
Hey guys,
My car is a lot of fun to drive, but it rolls around on corners way too much now, since I got sticky tires. I'm assuming if I get front and rear sway bars that I'll have less body roll and sharper handling? Has anyone installed the Whiteline Sway Bars? I'm heading to the Vancouver area in a few weeks and was planning on a trip to PDM Racing to get them... if they're worth it...
How 'bout strut tower braces? Do they do anything significant?
Thanks,
James
MrJaemz is offline
Old 10-24-2002, 04:34 PM   #2
youthanasia
Member#: 1883
2013 R60S All4
Buy it if you need it, if you don't, then just save your money for something else. It's one of these mods that can drastically change your car's behavior, specially in low traction situations. Know how it changes your car's dynamics. Then make your decision.
youthanasia is offline
Old 10-24-2002, 05:03 PM   #3
MrJaemz
Member#: 18211
1997 Impreza 2.2L
Yellow
Default good point, but...
Ya, I've read a bit about how sway bars affect understeer, oversteer, turn-in, cornering, etc. I can live with re-learning how my car handles as long as the body roll is gone. That's my main concern. But perhaps I'm looking for a bandaid solution for a bigger problem: the stock mushy suspension setup. Remember, I have a Impreza L Sedan, not an RS. The stock suspension was obviously never intended to be driven the way I drive it. I'm hoping for some advice from someone who's "been there, done that".
James
MrJaemz is offline
Old 10-24-2002, 05:28 PM   #4
RC
Member#: 941
2000 S2000
nice car
well
the bigger the swaybar u go the less grip u will have, but of coz less body roll
if u are looking for better turn in and feel
try to play with the camber setup a bit
tower bar only make the car's frame stronger as result of that suspension will work better, so u get a better feel of the car
of coz it is all up to u
RC is offline
Old 10-24-2002, 05:43 PM   #5
MrJaemz
Member#: 18211
1997 Impreza 2.2L
Yellow
Default less grip?
Sorry for the ignorance...
Why would I have less tire grip with a bigger sway bar?
James
MrJaemz is offline
Old 10-24-2002, 05:55 PM   #6
Ken
Member#: 34
2005 WRX STi
World Rally Blue
I'm on low profile 17"s in the summer with the stock rear sway bar and find the handling acceptible. I just keep playing with the front/rear tire pressure to get the right characteristics without having to splurge for a 18mm. bar, or whole new v5/6/p1 suspension kit - although new suspension would help with body role. But there are those that like an aggressive setup with a 20-22 rear sway bar.
Ken is offline
Old 10-24-2002, 06:41 PM   #7
UltraGucci
Member#: 17438
Thumbs up Sway Bars....I got em
MrJaemz,
I would not call it ignorance ( in reference to RC).
Bigger sway bars do not give you less grip. End of story.
Bigger swaybars reduce the amount of body roll on a car and thereby reducing the amount of roll weight that is forced over the sidewall of the tire and helps to keep a larger contact patch of tire on the road.......increased grip.
The rear swaybar alone on the Impreza car line make a HUGE difference in the way the car handles.
If you go with the 22mm swaybar (Whiteline) from PDM with the upgraded links, you will notice that the car is a lot more tossable. It will exhibit a little more oversteer which is more fun and a lot faster way to go through a corner (at the expense of the more safer understeer).
Adding both a front and rear bar will eliminate even more body roll but you may not eliminate all the understeer that most people want rid of.
The stut bars:
The front strut bar is mainly for show. I have heard that with the short distance that the front strut towers are from the firewall greatly increased the torsional strength of the chasis, therefore we really don't 'need' a bar unless we are building a racecar or want one for show. (I have one, and it sure does look nice. And I can take corners in more control.....at least I think so )
Rear strut bar is a VERY GOOD ADDITION. The rear towers can do with some help in the strength dept. Therefore I highly recommend the purchase. Easy install, just don't over tighten the 3 strut bolt on each side.
FYI I have:
22mm front bar (Whiteline)
front HD links (Whiteline)
Front strut bar (Whiteline)
24mm rear bar (Whiteline)
rear HD links (Whiteline)
rear strut bar (Whiteline)
Rear HD swaybar bracket (Whiteline)
Eibach springs
The ride is really smooth and corners really well, NICE AND FLAT.
I installed everything myself (with advice from i-Club members)
Everything was bought from PDM - Very good guys there........free plug
I would recommend playing with camber and toe settings and tire pressures as these are cheap and very easy ways to modify the way your car handles.
If you have any other questions, just fire them my way.
Overall the rear swaybar is the BEST place to start.
later,
UltraGucci
UltraGucci is offline
Old 10-24-2002, 06:56 PM   #8
MrJaemz
Member#: 18211
1997 Impreza 2.2L
Yellow
Thanks UltraGucci
I like hearing advice from someone who's got first hand knowledge - nothing replaces experience!
James
P.S. Does the rear strut tower brace go in the trunk? (I'm too lazy to go outside and look at my car )
MrJaemz is offline
Old 10-24-2002, 07:02 PM   #9
UltraGucci
Member#: 17438
Default strut bar
Yes it goes in the trunk.
I have pictures of most of the stuff at home.
I will try to post them when I get hoem from work.
later,
UltraGucci.
PS- get the springs from PDM.....(Eibach) they are dirt cheap and aren't too stiff. If your shocks are in reasonable shape they should be okay for a few years.
Gotta go.
Old 10-24-2002, 07:28 PM   #10
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
Default Re: Sway Bars....I got em
Bzzt. Wrong. Sway bars reduce the independence of the suspension, so they can reduce grip on the tire opposite the jounce'd tire. Think about it for a minute, guys -- why doesn't the WRC run a 10000mm sway bar? Because there's such a thing as suspension tuning, and it doesn't include the statements "bigger is better" and "I need to eliminate body roll."
There is so much misinformation in this thread that it really should be locked. You guys need to try a search, or at least read Mike Shield's site at www.spdusa.com for a primer.
Necromancer is offline
Old 10-24-2002, 07:29 PM   #11
Ooter
Member#: 20395
87 VW "TSD" Golf
Past 2002 & 2003 BRP TS
I'm another supporter of the rear whiteline 18-22mm swaybar with brackets and links. Made a huge difference on my TS even with the stock suspension and RE92 tires.
PDM - definitely the place to go if you decide to go ahead with it.
Doug
Ooter is offline
Old 10-24-2002, 07:37 PM   #12
alexs001
Member#: 8096
1998 Impreza 2.5RSTi
Rally Blue Pearl
I got the FHI 20mm rear sway bar and the difference is amazing. Now might not be the best time to make such a change to the suspension as the bad weather season is fast approaching and you'll still be adjusting to the change when there's snow on the ground.
Car looks excellent, btw. How do I never see you around town?
alexs001 is offline
Old 10-24-2002, 08:00 PM   #13
Urthling
Member#: 24782
2000 2.5RS
Default Bzzt
I will quote Necromancer "so they can reduce grip on the tire opposite the jounce'd tire", in other words the inside tire that does almost NOTHING in a corner.
To blow it out of proportion with a 10000mm bar......!!!! come on
To tune a car for better handling for the street and less body roll, use a suitable size bar 20-22mm is a good bar to use in this case. Any thicker and you get into other aspects of tuning.
Dude asked about how it changes the car Roll) and increased grip. the rear sway bar helps in both cases to a point.
it is called balance.
Bzzt my ass
a moderate bar helps
Urthling is offline
Old 10-24-2002, 08:06 PM   #14
warlord225
Member#: 24729
1993 Legacy gtb- sti
black wagon
my setup
3 deg front camber
2 deg rear camber
stiffer front sway bar 22mm
murder on tires but great handling
warlord225 is offline
Old 10-24-2002, 09:15 PM   #15
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Default Re: Bzzt
Oh, since when does the inside tire never hit any drops?
And if you're not using your inside tire to set the car into a turn, you've got a very interesting driving style and I'd rather not share the track with you.
Well, if it's true that "bigger sway bars will not give you less grip, end of story," then 100mm gives you at least as much grip as 20mm, and 10000mm maybe even more so. Heck, why not just pull a live axle out of a 1959 Bel Air and stuff it in the back of the car? People need to think about their statements before they write manifestos.
Yup, and for stock Impreza L sedan suspension, a decent road setup is 19mm (stock) front / 18mm back. Stiff roll bars on soft suspension is one of the common problems of poorly done mods. Usually because people run out of money before they can set things right with the proper dampers.
Anyway, what the original poster needs to do (as he would have discovered if he had done a search) is to forget the swaybar for now and purchase a used 2.5RS suspension for roughly the same price. That will get him the proper dampers and springs to tune the handling more towards a road setup. Last time I checked, "body roll" isn't a meaningful excuse for poor lap times.
In 4 years of tuning my '97 L, you'd think I'd have tried these things.
Old 10-24-2002, 09:23 PM   #16
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Also, James, keep in mind that most aftermarket bars for the Impreza are designed for the JDM WRX, which has even stiffer stock suspension settings than the North American 2.5RS. (specifically springs -- the dampers are virtually the same, but the car rides taller overall)
Anyway, PDM knows what they're doing and won't set you the wrong way. I do think that if you are going aftermarket, though, you should consider a real suspension package instead of something that only gives you the illusion of good handling. Too many wrecked modified cars have only proven this point.
The suspension forum has lots of good info for you. And lots of bad info, too. Whom do you trust? Your own brain. If it doesn't make sense, it probably isn't right. Nuff said.
Old 10-24-2002, 09:44 PM   #17
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
And this thread closure has been brought to you by common sense. Necrodork has lots of common sense. That's why he moved up from the Bay area to Vancouver, and then from Vancouver to Japan!
Kidding aisde, take what Joe has said about tuning and suspension. Go read Mike Shield's website. Do a search, especially in the ARCHIVES of i-club.
LaterZ!
Darren!!
Penphoe is offline
Closed Thread
2002 WRX is changing to 21mm front and 22mm rear sway bars worth it? JoeTX Brakes, Steering & Suspension 2 11-09-2005 10:07 PM
Front sway bar worth it in my case? dman918 Brakes, Steering & Suspension 24 10-05-2004 09:40 PM
Front sway bar worth it? treybomb Brakes, Steering & Suspension 12 03-16-2004 11:11 AM
Is a front sway bar worth getting? JayByRd724 Brakes, Steering & Suspension 32 12-18-2003 01:34 AM
Adjustable sway bar - worth extra $$? BruceC Brakes, Steering & Suspension 5 09-09-2001 05:54 PM
