Old 06-27-2014, 01:46 PM   #1
A7x411
Member#: 354532
2004 STi
Default Where to buy STI front axles?
I have a 2004 STI and when installing coilovers ripped the outer boot on the front passenger side axle. I have been looking online for a new one but can really only find WRX ones. Does anyone know where to buy STI axles other than the dealer bc I don't want to spend $400 on an axle right now.
A7x411 is offline   Reply With Quote
Old 06-27-2014, 03:16 PM   #2
jam007
Member#: 174706
2008 LGT-B
Replace the boot, it's a lot cheaper and the OEM axles are way better.
jam007 is offline   Reply With Quote
Old 06-28-2014, 02:35 AM   #3
A7x411
Member#: 354532
2004 STi
Okay. Do you know where I can get the oem boot? And what is everything I would need to replace the boot? Never done it before and I've been told once the boot rips the inside gets contaminated and it's no good.....
Old 06-28-2014, 06:42 AM   #4
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
If you drive in deep sand call it contaminated. Much better to keep your oem axle - hear lots of replacement problems. And costs more.
Visit your local Subaru dealer, kit costs $40 includes a silicon boot, grease and bands. Get a new axle nut ($4). Ask them for a nasioc discount.
You'll need to remove the axle, and then take apart the CV joint.
Breaker bar or impact gun
32mm socket and torque wrench good to 160 ft lbs (for the axle nut)
assortment of box end wrenches, ratchet and hand tools
Search nasioc for how-to. Done this job x2 and helped a friend replace his and took us a couple hours taking our time.
mhoerath is offline   Reply With Quote
Old 06-28-2014, 11:56 AM   #5
A7x411
Member#: 354532
2004 STi
Alright I'll just do that then. Thanks!
Old 06-28-2014, 01:11 PM   #6
ToneWrx02
Member#: 239095
2002 Wrx
That or EMPI axles from rockauto
ToneWrx02 is offline   Reply With Quote
Old 06-28-2014, 01:59 PM   #7
A7x411
Member#: 354532
2004 STi
Those are wrx axles not sti ones
Old 06-28-2014, 09:08 PM   #8
Andrewxxcarlson
Member#: 316415
2006 WRX
Btw, second thread I've seen you mention your torn boot while takin off stock suspension...
Next time unbolt the endlink from the control arm, it'll allow for more play.
Andrewxxcarlson is offline   Reply With Quote
