Old 10-24-2002, 11:01 AM   #1
suprasingle
Member#: 21733
1998 supra
wht
Default just how bad does car run with stock ecu and sti injectors
will it build boost,idle rough, or does it just run good but pig rich
randy
suprasingle is offline   Reply With Quote
Old 10-24-2002, 11:07 AM   #2
jmott
Member#: 6713
2007 Prius
brown
it can learn to idle
but its going to run very very rich in open loop mode (which is what happens when you floor it)
jmott is offline   Reply With Quote
Old 10-24-2002, 12:54 PM   #3
bliz
Member#: 12065
08 evo x mr
wicked white slow pos
it will run pig rich,when i had mine sti injectors in,one time i could not go past 4rpms,then after a while the car ran so so,then the car would not let me go past 5rpms so i took them out.im running 10-12psi on stock injectors with a t3/t4 turbo.still pulls harder than stock did at 16psi.
bliz is offline   Reply With Quote
how will my car run with if i unmarry my cobb AP??im running stage 2 now SOCIOPATH Engine Management & Tuning 10 08-11-2006 10:35 AM
Bigger cams running with stock ECU? BOXRPWR Built Motor Discussion 3 06-11-2006 11:49 AM
Mumbles, how is your car running with the swap? paultg New England Impreza Club Forum -- NESIC 21 12-12-2004 03:16 PM
Just how bad does a Unichip perform on TXS Stage 4 parts? BeavisNuke Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-24-2003 01:27 AM
Link ECU and STI injectors LAWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 07-22-2002 03:24 AM
