Old 07-21-2014, 04:33 AM   #76
The Cowboy
Member#: 302293
Originally Posted by Paul View Post
what are you doing for heads?...hope you have some billet ones
No billet heads yet. But our CNC ported heads will easy flow 1000hp.
The Cowboy is offline   Reply With Quote
Old 07-21-2014, 09:01 PM   #77
0STI6
Member#: 248230
03 JDM STI
R u guys going to test the block at lower power levels or r u bolting on the big turbo and going for the 1000hp off the bat???
0STI6 is offline   Reply With Quote
Old 07-21-2014, 09:13 PM   #78
The Cowboy
Member#: 302293
Yes of course it is a staged testing campaign. All initial tests will be with our current GTX35 set-up.
Once that is maxed we will try one of the new 37's..
Old 07-21-2014, 09:29 PM   #79
Laexreme5
Member#: 315264
2012 WRX
Any idea on when the testing will begin?
Laexreme5 is offline   Reply With Quote
Old 07-21-2014, 10:14 PM   #80
jdogma
Member#: 242350
2013 Carma Wolf EZ30
black
Do you know the weight penalty with the billet block? What will you use as a rev limit with that 83mm crank?
jdogma is offline   Reply With Quote
Old 07-22-2014, 12:23 AM   #81
The Cowboy
Member#: 302293
Will know exact weight limit in a couple weeks when we can weigh one of each at same level of completion..
Rev limit for 83mm crank is exactly the same as with std block. Very dependent on supporting mods and rod ratio chosen.. We generally limit them to around 8900-9000
Old 07-22-2014, 12:23 AM   #82
0STI6
Member#: 248230
03 JDM STI
Thought as much,
Still can't get my brain around the idea of a 1000hp 4 cyl ej motor in a time attack car, if you guys pull it off there's going to be jaws dropping around the world that's for sure.
Old 07-22-2014, 12:24 AM   #83
The Cowboy
Member#: 302293
Hope to do final assembly of first proto-type next week. Probably 3 weeks before we run it though.
Old 07-22-2014, 12:38 AM   #84
vicious_fishes
Member#: 158864
2003 SOHC destroker
for these ridiculous power levels, why not just drop an H6 in?
vicious_fishes is offline   Reply With Quote
Old 07-22-2014, 01:08 AM   #85
banshee04
Member#: 179014
'06 WRX/STi
Built Motor/6766/E85
Go ahead and front me one of these blocks, I'll pull the wastegate line on the 6766, then we will see what this block can handle.
I'm sure it shouldn't have a problem with a few 65+psi spikes
banshee04 is offline   Reply With Quote
Old 07-22-2014, 01:08 AM   #86
The Cowboy
Member#: 302293
Because the cars don't handle well enough to compete on the track with all that weight forward of the front axel.
Old 07-22-2014, 01:11 AM   #87
The Cowboy
Member#: 302293
Front me some cash and the block is yours to abuse as you like.
As good as the block's design is, addressing the many weaknesses in the OEM cast item, I think we all know that accurate tuning and adequate boost control will still be required.
Old 07-24-2014, 07:12 PM   #88
freshsti
Member#: 90099
2005 ewg gt52 sti
cgm
freshsti is offline   Reply With Quote
Old 07-25-2014, 03:35 AM   #89
The Cowboy
Member#: 302293
Originally Posted by freshsti View Post
Yes yes, I'm getting impatient also. Still got problems with no pistons arriving.
Hope to get pistons next week now and will post up some photos of first dummy assemble.
Have a great weekend everyone.
Old 07-30-2014, 02:54 AM   #90
scoobyrex123
Member#: 303380
2004 wrx hybrid
kk now do a H6 and ill be a buyer. Haha
scoobyrex123 is offline   Reply With Quote
Old 07-30-2014, 06:42 AM   #91
vicious_fishes
Member#: 158864
2003 SOHC destroker
...you've popped a sleeve on a standard H6?
there's around a $10,000 difference between this engine and an H6 swap. despite the few kg's more in weight there's no way you couldn't spend $10,000 somewhere else on the car and make up the difference. this is really only an "infinite budget" part.
Old 08-01-2014, 01:13 PM   #92
SomeAssemblyRequired
Member#: 215865
06 WRX TR
SGM
yes yes, look here, your mains won't be going anywhere.
That's what I mean by full span main cradles. It's also pinned and more main case bolts. Have a look at how the OEM main cradles swing in the breeze and then you'll understand why there is movement and nasty irregular wear on your main bearings.
That won't be happening here.
I have a few questions regarding engine lubrication. Will this be running a standard wet sump and oil pump or will it be dry sumped? If not dry sumped with main bearing cradles extending all the way down, where will the windage tray and/or oil pump pick up tube connect to? As I do not see the provisioning on the bottom of the block, unless the machining is not complete in the posted picture. Thanks
SomeAssemblyRequired is offline   Reply With Quote
Old 08-03-2014, 06:33 PM   #93
The Cowboy
Member#: 302293
Yes this product can be set up for std sump and pick up.
Initially we are testing one of each. Although we already know that for any circuit racing, you really need a dry sump set-up to guarantee accurate oiling. We use and recommend the Daily EJ Dry Sump kit.
We do already have a customer car that will be running Cosworth dry sump set-up, which is like a hybrid system combining a Cosworth vacuum/scavenge pump, with the OEM style oil pressure pump. So I guess we can accommodate all needs here. But we're only doing this one like this because the customer already had the cossie system.
Having said all that we strongly recommend the Daily system for all customer engines as we know it works great and has facility to scavenge from the heads as well as the sump, which is a big bonus on circuit driven applications.
Old 08-03-2014, 06:41 PM   #94
The Cowboy
Member#: 302293
Yes H-6's pop sleaves also.
But hey it's horses for courses. This is not for everybody. Just like H-6 transplant is not for everybody..
How about a challenge, can you build a H-6, put it in a GDB and take one of these babies down at the circuit? I'll allow you an infinite budget.
See you in October
Old 08-04-2014, 01:02 AM   #95
manys
Member#: 265277
1999 Outback
Legacy
Probably not many people know this here so I'll just throw it out there that what's also cool about the Autotech STI is that it's a legit Prodrive S10 WRC shell
manys is offline   Reply With Quote
Old 08-04-2014, 01:57 AM   #96
The Cowboy
Member#: 302293
Yes, yes, thanks for the compliment.
Rocking Horse $hit well describes the rareness of these babies
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 08-04-2014, 04:53 PM   #97
vicious_fishes
Member#: 158864
2003 SOHC destroker
See you in October
sigh. you've missed the point. for the sake of keeping the peace i'll leave this alone.
Old 08-05-2014, 09:32 PM   #98
neverstopwheelie
Member#: 397053
Here are the original CNC Renderings.
Current Rendering with final adjustments on this much needed product.
And here is one block half getting there with sleave installed earlier this week.
We hope to be assembling and test fitting the first block inside 2 weeks.
Bring it on
cant wait to see some video of this beast
neverstopwheelie is offline   Reply With Quote
Old 08-06-2014, 12:37 PM   #99
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I thought you guys had already gotten one of these to Ben? Although I haven't gotten an update from him on the WTAC car in a while...?
Edit: Just looked to see where he tagged me in it on the face machine, circa March 2012.
Old 08-06-2014, 05:33 PM   #100
SubasaurusWrex
Member#: 70285
2011 JCW Mini
Midnight Black/Red roof
Such an awesome build! Just one question, wtf is a "sleave"?
SubasaurusWrex is online now   Reply With Quote
