Vancouver Impreza Club
Old 07-03-2014, 09:25 AM   #1
Lino21
Member#: 250306
2003 Impreza WRX
Default timing cover noise
03 wrx, had the timing belt changed about 2 years ago, all of a sudden when the engine is cold my timing belt cover is making noise (sounds like a loud whirling and a bit of rattle) , but if I push on the cover by hand it stops. The noise also goes away after the car warms up.
Anybody have any ideas how concerned I should be, or maybe the cover is just loose?
Lino21 is offline   Reply With Quote
Old 07-03-2014, 01:13 PM   #2
yap
Member#: 209685
2004 STI
which part of the timing cover are you pushing on? is it near the a/c tensioner? maybe it's rubbing the cover
yap is online now   Reply With Quote
Old 07-03-2014, 02:11 PM   #3
Lino21
Member#: 250306
2003 Impreza WRX
Looking at the engine, the left side (intake side) I'm going to try for a video after work
Old 07-05-2014, 02:23 PM   #4
Lino21
Member#: 250306
2003 Impreza WRX
Timing belt cover noise:
thanks for anyone's input in advance
Old 07-05-2014, 06:18 PM   #5
FunkMasta
Member#: 66985
2001 2.5RS sold
2012 2.0 Hatch
dumb question but are your timing cover bolts tight?
FunkMasta is offline   Reply With Quote
Old 07-05-2014, 07:03 PM   #6
Lino21
Member#: 250306
2003 Impreza WRX
Ya I checked Wm, seem to be fine, are there any on the bottom that you can't see?
Old 07-05-2014, 07:17 PM   #7
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
Yes there are bolts on the bottom, in approximately the same locations they are on the top.
If that doesn't fix it maybe check to see if the rubber gasket is intact??
brett192 is offline   Reply With Quote
Old 07-05-2014, 08:01 PM   #8
Lino21
Member#: 250306
2003 Impreza WRX
Thanks, I'm really hoping it's not serious, and that it is just the gasket or a loose bolt. I can't imagine it being serious if I can make it stop by applying such little pressure...
Edit
It's not the bolts, it's something inside rubbing, if I pull on the cover the nouse gets worse, push and it goes away.
