Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 07-06-2014, 08:04 PM   #1
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Default Destroked hybrid. Who has done it?
Like the title says I am looking for people who have destroked a hybrid. I am going to do it so I was looking for results.
Old 07-06-2014, 09:26 PM   #2
Layvon
Member#: 195711
STi 04/05/06/07
Interesting.
Layvon is offline   Reply With Quote
Old 07-06-2014, 09:34 PM   #3
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
I dont see how it would be all that different.
You should still have about the same top end no?
Shortpersonbk is offline   Reply With Quote
Old 07-06-2014, 09:38 PM   #4
colorado_subie
Member#: 395532
hmmm im looking for someone who has done this too i have a sti hybrid swap in my wrx now
colorado_subie is offline   Reply With Quote
Old 07-06-2014, 10:50 PM   #5
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
So you want info on S20 casting heads on a destroked EJ25 block? Modified chambers or not?
Old 07-06-2014, 11:34 PM   #6
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I have a hybrid motor that is built with je hybrid pistons and no head work. It made 375 awhp on pump gas and a 20g. I am now thinking about destroking this motor and using a + 2 rod.
Old 07-07-2014, 08:24 AM   #7
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I have.
Old 07-07-2014, 08:29 AM   #8
Razgeiz
Member#: 358782
2013 STi
Originally Posted by kellygnsd View Post
I have.
And yours is a sexy beast. Just sayin
Razgeiz is offline   Reply With Quote
Old 07-08-2014, 03:14 PM   #9
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I have.
Thanks for the response Kelly. I have been reading your build post today and it looks like a fun build. Those are some nice numbers. How is this engine on 91 as a dd?
Old 07-08-2014, 09:04 PM   #10
2000subie
Member#: 207638
2004 WRX
Yellow
I have as well. No numbers yet though as I haven't broken it in still! But my heads are chamber matched, as are Kelly's correct?
2000subie is offline   Reply With Quote
Old 07-09-2014, 01:03 PM   #11
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Looking for numbers and dyno plots so post them when you get them please.
Old 07-09-2014, 01:27 PM   #12
kellygnsd
Member#: 32669
LINK G4 hybrid STi
The CR is 9.1:1 so it doesn't really like California pump 91. I onlyl run 17 psi on straight pump and it put down 400whp. With just a hint of octane or meth and we added 100whp. A few stations have 100 octane at the pump and the car is really happy with 3 gallons of 100 octane topped off with 91.
I'll be going to a flex fuel setup shortly and I expect to be able to turn up the boost to a comfortable 30 psi for daily use. I expect big #'s when that happens as long as I can hold boost in the upper rpms.
Old 07-09-2014, 08:23 PM   #13
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
So I will be building this engine with less compression so that I can run 91 and still have boost and timing. I also think I will try this with my fp green, bc272,s and run it on e85 for the track. I think I am done with meth. Wish I had 100 oct to play with.
Old 07-15-2014, 11:43 PM   #14
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I know there is a 76 in the Temecula/Murrietta area that has 100 octane at the pump. Certain 76 gas stations and CFN/Downs Energy in Temecula carry 100 Octane VP StreetBlaze.
Old 07-16-2014, 11:27 PM   #15
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
That is only about 6 hours from here, not sure that I could make that work for me.
Old 07-18-2014, 12:33 AM   #16
kellygnsd
Member#: 32669
LINK G4 hybrid STi
My bad, I saw SCIC for region and thought your location was Murietta, CA. I don't even know where Mariposa, CA is
Old 07-18-2014, 10:30 AM   #17
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Mariposa is by Yosemite national park.
Old 07-30-2014, 04:33 PM   #18
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Still looking for dyno results on this build.
Old 07-31-2014, 12:15 PM   #19
Homemade WRX
Member#: 33782
96 bastard child
but which version of the hybrid piston? I'm guessing 8.5:1 because of the 91 octane piss...
Old 08-01-2014, 11:24 PM   #20
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Yes 8.5:1 is right because of piss. I also like to run the lower compression on my turbo motors because that gives you more room to play with timing and boost.
Old 08-04-2014, 12:44 PM   #21
Homemade WRX
Member#: 33782
96 bastard child
Ok, so destroked you're going to be like high 7's or so maybe 8.0. Just run the numbers real quick.
Old 08-04-2014, 11:59 PM   #22
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
With a + 2mm rod I should be at 8.5 still. I just need to find some +2 rods at a good price. Who has them?
