Old 10-24-2002, 08:40 PM   #1
reveler
Member#: 25967
2002 WRX Wagon
Default neutral safety switch problems w/MT
Hi,
Have a bit of a problem.
Have a 2002 WRX wagon, Manual Transmission.
Doing a remote start today, found the ECU pinout for the neutral safety switch.
Know I have the right pinout because the wire was showing ground in all 5 gears, changed to 12v in neutral.
Here's the issue. For whatever reason, the wire just decided to not show ground anymore.
Played with it for a few hours, then decided to consult you folks.
What I'm looking to know is, from the switch from the transmission, can someone describe where the power then runs from until it makes its way to the ECU?
I suppose I'm looking for a relay or switch of some sort (which is probably blown).
I was taking out the Subaru stock alarm, and removed the two relay connections above the clutch. Thinking this might be the problem area, I tested. No luck, then put them back in.
Any subee mechanics out there with any ideas?
Thanks in advance.
reveler is offline   Reply With Quote
Old 10-24-2002, 08:56 PM   #2
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
I hope you didn't use a test light, you can easily burn
out sensor switches and transistors that way.
Always use an ohm meter.
Matt
mattjk is offline   Reply With Quote
Old 10-24-2002, 09:02 PM   #3
reveler
Member#: 25967
2002 WRX Wagon
So any ideas on what sensor switches and transistors those might be? I'm just looking for the wire connections to the ECU from the transmission switch...
Car Won't Start / Neutral Safety Switch neurotic Newbies & FAQs 3 12-21-2005 04:49 AM
Neutral safety switch...? adam555 Transmission (AT/MT) & Driveline 10 12-05-2005 11:25 AM
Neutral Safety Switch dfgu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-21-2005 02:23 PM
neutral safety switch code buru6 Service & Maintenance 2 08-16-2004 04:41 PM
MAP sensor dead! Neutral safety switch dead! 1st recorded MAP kill? munkis Normally Aspirated Powertrain 5 07-22-2002 08:09 AM
