Old 10-24-2002, 10:30 PM   #1
Jake Steed
Member#: 24756
2002 WRX sedan with
scratch marks and dirt
Default How much boost can you run on stock fuel?
How much boost can one run safely on a VF34 with stock fuel system? Does 1.1BAR sound ok?
Jake Steed is offline   Reply With Quote
Old 10-24-2002, 11:07 PM   #2
tdxflex
Member#: 13634
i tried searching this also, i think the best data for this can be found on TurboXS website when they were comparing the forced performance turbo with and without fuel upgrade. I think they ran 15.4psi. Some have ran 16psi, but I don't have a datalogger that can monitor injector duty cycle, so maybe someone else can elaborate on this.
tdxflex is offline   Reply With Quote
Old 10-24-2002, 11:27 PM   #3
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
I would stick with stock boost unless you have bigger injectors. Your injector duty cycle is pretty much maxed out at 1.1 bar on a VF34
mr2guru is offline   Reply With Quote
Old 10-25-2002, 12:31 AM   #4
d00f
Member#: 6000
2000 GC8 STi V4 swap
BRP
Stock fuel as in pump gas or stock fuel system?
This may not apply to your question but I'm running 20 PSI of boost and since I just got my WBO2 in I found that I'm running 10.3-10.4 AFR at that boost level.
-Michael
d00f is offline   Reply With Quote
Old 10-25-2002, 01:08 AM   #5
Jake Steed
Member#: 24756
2002 WRX sedan with
Stock fuel system.
06 WRX, how much boost can be run on pump gas? riggs Engine Management & Tuning 9 11-23-2005 08:31 AM
How much boost can I run? UTEC, TBE, etc ringmaster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 12-16-2004 04:48 PM
How much boost can you run on a stock WRX? Blue_2K2_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 07-09-2002 10:33 PM
How much boost can i run with low CR pistons? IMPBOY Normally Aspirated with bolt-on Forced Induction Powertrain 9 03-10-2002 10:36 PM
how much boost can i run on my EJ22T fourbanger Legacy Forum 7 09-23-2001 04:20 PM
