Welcome to the North American Subaru Impreza Owners Club Saturday November 1, 2014
Old 10-25-2002, 01:06 PM   #1
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Default Rails, injectors + Stg4 tune
Installed my injectors (~1 hour) and rails (~5 hours ) yesterday. I used the TXS stg4 UTEC map...got me going, thanks Nathan. One point of interest to those planning this upgrade (re: rails) I had to pull approximately %15 fuel out across <most> of the fuel map. Goes to show you how crappy the stock fuel system is
BTW, the rails install is not for the faint of heart or newer tuners..it is alot of work / thought.
n2xlr8n is offline   Reply With Quote
Old 10-25-2002, 07:23 PM   #2
WRX-ellent
Member#: 9071
2002 WRB Impreza WRX
FMIC/1820 inside & Link'd
I was looking into upgrading My fuel rails to the Perrin fuel rails. Can you give me tips on what to be prepared for? Thanks...
~joe
WRX-ellent is offline   Reply With Quote
Old 10-26-2002, 02:18 PM   #3
RimRockaz
Member#: 2947
2000 GC6 ej20 swap
fast n furious pt III
Joe,
installing fuel rails is just time consuming. need to drain and flush the fuel system just like doing the brakes.
I have the Perrin Fuel rails but just haven't got a chance to put it in. I am gonna have RedStar to do this job..
RimRockaz is offline   Reply With Quote
Old 10-28-2002, 12:19 PM   #4
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Default Rail install
I bought the Perrins....I am very satisfied with them. What to look for:
The install instructions say to purchase hose. Buy 3/8" fuel and 1/8" vacuum hose instead of the 1/2 and 1/4 they specify.
The factory fuel lines and wiring harness are bolted <underneath> the intake manifold...have a good set of 1/4" sockets and wobbler / extensions. What a design.
The green bracket of death on the driver's side is a piece of cake....not so on the pass side...use said 1/4" drive accesories on the rearward-most bolt under the pass side tgv, hold your mouth just so.. I don't own a service manual, so it was particularly enlightening...and if you happen to do it by yourself in less than 5 hours, you are far better mechanic than I.
WTT: perrin fuel rails+565 cc for stock rails/injectors demartinoink SCIC Private Classifieds 2 05-21-2008 01:55 AM
Ultimate Racing top feed fuel rail injector problems? Ricowrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 10-07-2004 04:59 PM
Swapping fuel rails/injectors? IronMonkeyL255 Subaru Conversions 10 05-30-2004 01:30 AM
Perrin fuel rails/injectors Wombat North Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 05-14-2004 02:27 AM
Need gasket advice for turbo, fuel rail, injectors, etc DocDetroit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-10-2003 10:39 PM
