Old 10-25-2002, 02:28 PM   #1
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
Default Rich Idle fix!!!
Here is the scenario... I used to have a 1994 Acura Integra with a supercharger running 10psi of boost. I had a walbro 255lph fuel pump, RRFPR, and 330cc injectors. Needless to say the damn thing was running hella fat. There is a company by the name of Endyn that specializez in Jackson racing superchargers so I called them and asked them what to do. They said it is an easy fix. All you have to do is take off the stock fuel pressure reghulator and drill a relief hole so the excess pressure will subside. It is a little hard to explain so I will post a link. This fix is for Honda and acura, but the regulator is almost identical.
I treid this mod on my 2000 Impreza 2.5 RS Turbo and itmade the worl of difference. Idle is smooth, and you can smell a cleaner burning exhaust.. well anyway here is the link.
post any replies.
http://www.theoldone.com/articles/regulator/
Pi7467mp is offline   Reply With Quote
Old 10-25-2002, 04:07 PM   #2
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Or you could buy a cheap SVX regulator......
Midwayman is offline   Reply With Quote
Old 10-25-2002, 04:17 PM   #3
crash
Member#: 1440
05 LGT Wgn; 04 FXT
BDSM -- Birmingham, AL
This subject is one of those that I have not spent much time researching on...
Can someone inform me what exactly the SVX FPR does that the stock impreza one doesn't.
And what kind of condition(s) i should shoot for when it comes to Fuel Pressure at Idle, cruise, and WOT.
Thanks!!!
-Nathan
crash is offline   Reply With Quote
Old 10-25-2002, 04:43 PM   #4
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
The SVX FPR is essentially the RS FPR with a larger hole. Its maxinum flow back to the tank is greater than the stock RS one.
Not having large enough drainback capacity increases idle pressures (usually from a upgraded fuel pump) and can cause idle issues.
Old 10-28-2002, 08:58 AM   #5
svxtrem
Member#: 1008
2006 STI
Steel Grey Metallic
You're right about the return, if you are getting excessive pressure at idle, the SVX regulator will cure it. But...one problem- SVX regulator is set for 36 psi, not 43. So you will lose pressure.
svxtrem is offline   Reply With Quote
Old 10-28-2002, 10:33 AM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
The problem is the larger flow and pressure of the new pump. The stock regulator can't handle it and raises up the pressure 10+ psi. An SVX or even a WRX regulator is meant to handle more flow/pressure, so they will be able to handle it just fine if you upgrade a RS's fuel pump.
ej207 v5 swapped from vf28 to vf34 not runs rich @ idle impreziv25 Subaru Conversions 6 05-24-2007 04:46 PM
1.8->2.2 rich @ idle question drewdogg Subaru Conversions 1 01-20-2006 12:48 PM
insanely rich idle kwiktsi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-03-2005 08:16 AM
Help - stg4 installed, bogging, CEL, RICH idle whiterabbit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 11-17-2003 11:18 PM
Rich idle with Link wcbjr Engine Management & Tuning 16 10-27-2002 08:07 PM
