Old 10-25-2002, 10:35 PM   #1
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Default Review - STI/SPT struts & springs VS. Cusco coil overs VS. Stock
Been looking for a softer riding winter set up - 1st went back to stock then just put on the STI/SPT set up - I have the following observations:
Stock - ride - very soft - but not cushy
Handling - OK if not pushed too hard - dives down when hard breaking - lots of mushyness - very vauge when making transitions - - BUT very good on broken pavement or speed bumps
STI/SPT - fits 100% - easy install - - firmer but not harsh ride very liveable as a daily driver
Handling - better on dive when breakling - BUT still rises up in the air and causes the front end to loose traction on very hard acceleration - - much more precise in transitions BUT still some vaugness - - much better roll resistance than stock
Just feels right - - very enjoyable as a daily driver set up - very confortable - feels like about the same level as an "M" series stock BMW
Cusco - fits 100% - just bolt in - - harsh firm as can be ride on any surface other than a smooth highway - - fairly uncomforatable on long trips
Handling - IDEAL - no break dives - no significant lifting of font end under acceleration - - very good roll control - excelent turn in - extreme precise in transitions
Disatvantage - LIMITED wheel travel - - can result in car leaving the ground on very bumpy roads - - it seems that it requires fairly stiff springs to prevent the car from hitting the limits of the limited wheel travel range - - with these units you gain smooth road handling - BUT you sacrifice the rough road capability of the WRX with its stock extreme wheel travel range that just soaks up the bumpy stuff
Conclusion - - I'm enjoying being back to the rally car feel of the stio set up - but realize that the comfort and rough road capacity comes at a sacrifice of ultimate smooth road performance
Final thought - I put about 7 K problem free miles on thge cusco units - there were not rattles - no banging or any problems - they are very high quality units
alfriedesq is offline   Reply With Quote
Old 10-26-2002, 09:04 AM   #2
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Thanks Al, that's good information. Know that some of the difficulties that you're having with the SPT stuff can be fixed with the addition of other STi goodies, like the front control arm bushings, and the complete link setup (lateral/trailing/swaybar) at the rear.
Kevin
gtguy is offline   Reply With Quote
Old 10-26-2002, 11:58 AM   #3
boxerT
Member#: 16311
2004 STi
WR Blue
That is good information Al.
However, as an obviously proud quarter mile racer I would worry that you may not know too much about turning right/left. Perhaps you could brag a little about your road racing/auto-x success more related to your handling information.
boxerT is offline   Reply With Quote
Old 10-26-2002, 05:56 PM   #4
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
I'm running agx's with ver. 5/6 springs - basicly the same thing but slightly stiffer, slightly lower, and adjustable, non-inverted struts. Ride and handling is much better than stock. AGX's are definitely better than stock struts. I have plenty of travel and just the right spring rate for speed on rough roads.
I may pickup some coilovers next year for summer use, but I will retain my current setup for the winter.
Kevin
Red Rocket is offline   Reply With Quote
Old 10-26-2002, 08:50 PM   #5
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Last summer - before my daughter was born - I used to do many auto x's - - in fact I did a few auto x's at the drag strip and then went to the strip afterwards - I did pretty good - I even got a 2nd place SM finish once - but just dont have the time to dedicate anymore and I found it was very very hard on my tires and transmission
Now that the drag season is over I am trying to make it a better running all around car again
BTW - I;d sayt the coil overs would be the best auto cross set up by far - - - The SPT set up would noit be that good for auto X becuase the front end sits so high
Old 10-26-2002, 08:52 PM   #6
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Kevin
I have the complete Group N STI bushing set - sti sway bars and 225 45 17 tires - - - it still is on the soft side for all out performance driving - although its perfect for the commute to work
Old 10-27-2002, 10:13 AM   #7
gtguy
Member#: 2184
The difference between the two, is that the pink STi bits have spherical metal bushings in the lateral and trailing links. That little bit of extra mojo might work for you...it sure did for me.
Kevin
Old 10-27-2002, 12:13 PM   #8
akoshy
Member#: 20931
09 Subaru
Kevin
Yup ! Spherical pivoting metal bushings unlike the fixed bushings of the others.
akoshy is offline   Reply With Quote
Old 10-27-2002, 08:18 PM   #9
02 T-WREX
Member#: 11449
2006 STi
SGM
Hey Kevin,
How much NVH increase was there with the pink bits? I've replaced bushings with spherical metal bushings in my race car, and the resulting NVH would be REALLY annoying in a street car.
Thanks,
Chip
02 T-WREX is offline   Reply With Quote
Sti adjustable struts & springs reviews Haven Brakes, Steering & Suspension 10 01-27-2009 05:32 PM
WTB 04+ STi/WRX Struts & Springs Enjoi SCIC Private Classifieds 11 05-27-2008 09:31 PM
FS: Sti/SPT Struts n Springs for 02 WRX Wagon chazbott Suspension/Brakes/Handling 3 06-07-2007 03:54 AM
02-03 WRX Wagon Struts & Springs. Assembled. i'm going back to stock! :( YinUCSD Private 'Wanted' Classifieds 3 08-02-2005 01:54 AM
STi v8 struts & springs on a 2002-03 WRX SoLiDbReAkZ Brakes, Steering & Suspension 2 05-07-2003 12:06 PM
