Old 07-29-2014, 11:48 PM   #1
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
Default Rich and three misfires! UPDATE 8/9/14
UPDATE: see post #4
Just bought a Tactrix Cable to try to fix my car, but looking for some NASIOC guidance to make sure I'm on the right track!
I'm thinking boost leak, change plugs, and coil packs?
p0172 - System Too Rich
p0301 - Misfire Cylinder 1
p0303 - Misfire Cylinder 3
p0304 - Misfire Cylinder 4
2008 WRX
Perrin catted down pipe
Magnaflow exhaust
Perrin crank pulley
Cobb SF intake/box
FMS top mounted intercooler
Dyno tuned @ Bren Tuning
When boost kicks in/2500+ RPMS car shakes a lot (misfiring). Low RPM's the car is fine. The car has stalled out with clutch in, which is definitely a sign of a leak. Going to smoke test it and fix the boost leaks, then see what happens. I can try logging it and post the results if you guys need it.
Digital Dillon is offline   Reply With Quote
Old 08-01-2014, 08:41 PM   #2
2000FourSilverSTI
Member#: 348633
Check for leaks, tighten everything down good. The smallest leak can cause this type of problem.
If that doesn't fix the problem, change plugs, make sure to gap them correctly.
Goodluck!
2000FourSilverSTI is offline   Reply With Quote
Old 08-01-2014, 08:50 PM   #3
sebi1990
Member#: 362910
2013 Impreza WRX
Have a boost leak test done after that the next option would be replacing spark plugs if you haven't already done so.
sebi1990 is offline   Reply With Quote
Old 08-09-2014, 10:45 PM   #4
Digital Dillon
Member#: 288727
2008 WRX premium
Did the trick with soap and water. The only spot that bubbled was the part circled in the photo (from the passenger side, bellow the intercoolor, connecting to the turbo, towards the front of the car). So... tighten down that clamp and hope it fixes it? If not, new plugs, then new coil packs?
Old 08-10-2014, 09:52 AM   #5
LGT257
Member#: 398087
2007 Legacy GT EJ257
Sounds like a good plan. Try that and report back!
LGT257 is offline   Reply With Quote
Old 08-28-2014, 10:00 PM   #6
mitch808
Member#: 10228
2002 Subaru WRX
Any update?
mitch808 is offline   Reply With Quote
Old 08-29-2014, 10:11 PM   #7
Andrewxxcarlson
Member#: 316415
2006 WRX
Never heard a turbo clamp leak air...
Andrewxxcarlson is offline   Reply With Quote
Old 08-29-2014, 10:42 PM   #8
Digital Dillon
Member#: 288727
2008 WRX premium
Leaking between the turbo and compressor I guess... Maybe time for a vf52? lol, car still can't breath. Snapped about 10 bolts from removing the heat shield and tightening that clamp. Haven't been driving it so I think I'm going to just drop it off at Bren to take care of it.
Old 08-29-2014, 10:46 PM   #9
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
Uhhhhhh yeah this lmao
Sent from my SM-G900P using NASIOC mobile app
BeastianSTI is offline   Reply With Quote
Old 09-03-2014, 12:41 PM   #10
gtbensley
Member#: 167448
2013 2013 wrx hatch
Plasma blue pearl
Actually just saw the same thing on a GTI we have here at the shop. Sounded horrid, found the exhaust part of the compressor had blown the pipe off the exhaust flange where that clamp is. Pretty odd for sure
gtbensley is offline   Reply With Quote
