Old 10-26-2002, 12:23 AM   #1
smskier
Member#: 20061
02 Subaru WRX
Default PLEASE help!! trying to get palm to work with utec
ive been trying for about 5 hours to get a vt100 emulator on a palm m100 to work with the utec. i already plugged it in my computer and hyperterm works fine, but for some reason it wont display anything on the palm. ive tried online 1.7 and palmterm and vt100.. im at a loss right now someone help please
smskier is offline   Reply With Quote
Old 10-26-2002, 02:39 AM   #2
smskier
Member#: 20061
02 Subaru WRX
im still stuck and i dont know why come one someone must be using a palm what program you using and what exactly do you do to connect with the palm?
Old 10-26-2002, 03:38 AM   #3
smskier
Member#: 20061
02 Subaru WRX
hello? really frustrating.. i just tried changing the baud rate to 4800 that didnt help
Old 10-26-2002, 04:33 AM   #4
ScoobieSnaX
Member#: 10844
2004 Acura TL Navi
Pearl
I can tell you one thing's for sure.....you're wasting your time with the Palm. Sorry to say but either use a laptop or wait for the UTECLogger
The Palm software just won't work properly for you to datalog and tune your car.
ScoobieSnaX is offline   Reply With Quote
Old 10-26-2002, 04:38 AM   #5
smskier
Member#: 20061
02 Subaru WRX
i dont care about tuning really.. i just want to use the dashboard option and the question was how do i get it working.. not should i use one.. because i cant afford a laptop
Old 10-26-2002, 06:34 AM   #6
TurboXS (Pete)
Member#: 16704
We used a Palm M100 with the UTEC. The software we trialled was Online(tm) (www.markspace.com).
I'm not at work so I am working off my memory at the moment.
1. You will need to make or buy a 9 way D type male to male cross over cable. To build one you need 2 male 9 way D type connectors. Then wire as follows;
Connector 1 ----- Connector 2
Pin 2 --------------- Pin 3
Pin 3 --------------- Pin 2
Pin 5 --------------- Pin 5
2. Setup the Online(tm) software to 4800 baud, 8 bits, 1 stop bit and no parity. Turn off the display to follow the cursor option.
3. Make sure you turn on Online(tm) by tapping LOG IN or ON (not sure about the exact name)
4. If the UTEC is on then enter a "space" or "ESC" or "cntrl-x" to access the home menu
The Palm will work at 19200 baud. It just can't cope with continuous data at this rate.
regards
Pete
(TurboXS)
TurboXS (Pete) is offline   Reply With Quote
Old 10-26-2002, 06:32 PM   #7
ScoobieSnaX
Member#: 10844
2004 Acura TL Navi
Pearl
Old 10-26-2002, 08:39 PM   #8
smskier
Member#: 20061
02 Subaru WRX
ahh that should help thanks a lot.. i was using the cable you gave me with a male gender changer.. perhaps that is what the problem is
Old 10-27-2002, 06:09 AM   #9
smskier
Member#: 20061
02 Subaru WRX
cool got it working.. just went to radio shack and bought a null modem serial adapter and it works fine.. now im in search of some better vt100 software, "VT100" works sorta ok, and so does "Online" except that online doesnt show everything on one screen you have to scroll..
Old 10-27-2002, 06:25 AM   #10
TurboXS (Pete)
Member#: 16704
Glad you got it working.
I don't think you will be able to find a VT100 program for the Palm(tm) that will display the whole screen. The screen on the Palm(tm) is just a bit too small.
Pete
(TurboXS)
Old 11-15-2002, 09:33 PM   #11
rossman
Member#: 6652
2002 wrx
mbp, wingless
Here is an all in one solution possibly? http://www.visorcentral.com/content/...319-15-all.htm
Ross
rossman is offline   Reply With Quote
Old 02-01-2003, 11:59 AM   #12
wrxtuner02
Member#: 22700
TRD FJ Crusier SE
76 MG Midget Special
Somebody please help. here's my setup:
Utec-->Serial cable-->Null modem adapter--->male to male gender changer-->belkin usb/serial hotsync cable-->Visor prism
I'm using online and i think i have a connection becausee it displays weird char sets but no menu. Online setup as follows:
4800 baud, 8 bit. 1 stop bit , no parity, comm through sync port, follow cursor off.
please help me!!!
wrxtuner02 is offline   Reply With Quote
Old 02-03-2003, 03:51 AM   #13
smskier
Member#: 20061
02 Subaru WRX
i havent used that palm in months.. bought a laptop.. but from what i remember just type a letter in to get the connection through.. make sure both the visor and the utec are at the same speed also
Old 02-03-2003, 07:09 AM   #14
TurboXS (Pete)
Member#: 16704
The UTEC default is 19200 baud. This can be set to 4800 but you need to do with your desktop PC running at 19200.
If your baud rates are mismatched this will cause strange characters.
regards
Pete
(TurboXS)
Old 02-03-2003, 03:48 PM   #15
TheMadScientist
Member#: 23717
2005 Big red
For you guys using laptops you might want to check this out.
I got a laptop for less than my palm m130. http://www.wrxhackers.com/modules.ph...iewtopic&t=396
TheMadScientist is offline   Reply With Quote
Please Help!! Trying to gather the final parts for my tune. zx6rr33 Private 'Wanted' Classifieds 7 04-24-2008 10:22 PM
help, I'm trying to get subaru to rebuild my motor on warranty MtlPete Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 05-22-2006 09:56 AM
help troubleshoot: trying to get car to start after motorswap.. MachinesWRX Normally Aspirated Powertrain 5 11-06-2005 09:40 PM
need to get this to my BF and my email doesn't work - so don't respond please Andra Off-Topic 30 10-28-2003 03:50 PM
Trying to blow up my engine with UTEC rlavalle Engine Management & Tuning 8 12-31-2002 04:26 PM
