Old 07-31-2014, 12:51 PM   #1
jl-wrx
Member#: 269228
Default Arrow precision or k1 79mm crank
What would be the best crankshaft between the arrow and k1 crank, that can supply enough oil to the bearing to rev to 8 thousand rpm? What I have found from searching is that arrow makes crank for cosworth and roger clark
jl-wrx is offline   Reply With Quote
Old 07-31-2014, 01:39 PM   #2
calebtharrell
Member#: 242113
2004 STi, 2008 STi
Arrow makes the better crank of the two.
calebtharrell is offline   Reply With Quote
Old 07-31-2014, 07:45 PM   #3
user1029
Member#: 57064
2008 STi IAG built
HTA86, Meth, 272s, Cos IM
OEM heat treated crank? Cost 10x less, I'm revving to 8k
user1029 is offline   Reply With Quote
Old 08-01-2014, 09:10 PM   #4
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Arrow or Manley have the lightweight design and cross drilled mains you want. Dont believe k1 has that and is def the heavier of the options.
Crystal_Imprezav is offline   Reply With Quote
Old 08-01-2014, 09:42 PM   #5
DisoDisp
Member#: 187648
2007 WRX
Pleased with the manley, the arrows cost too much...
DisoDisp is offline   Reply With Quote
Old 08-01-2014, 10:56 PM   #6
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
Manley all the way.
fastblueufo is offline   Reply With Quote
Old 08-01-2014, 11:06 PM   #7
Razgeiz
Member#: 358782
2013 STi
On the arrow and Manley cranks does each rod bearing get fed by a separate main or do 2 and 3 still sharing an oil feed? That's my main concern other than that OEM I wouldn't worry about at 8k
Sent from my QMV7A using NASIOC mobile app
Razgeiz is offline   Reply With Quote
Old 08-02-2014, 12:09 AM   #8
BraveSTi
Member#: 262030
How about you look up induction-hardening, nitriding, etc and make your own decision based off of research
BraveSTi is offline   Reply With Quote
Old 08-02-2014, 08:43 AM   #9
alakazoo22
Member#: 230730
05 FXT 18GXTR
black
Off topic..
What is the advantage to get lightweight crank and when you need it ???
alakazoo22 is offline   Reply With Quote
Old 08-02-2014, 09:03 AM   #10
jl-wrx
Member#: 269228
Manley crank are ****, there was an thread on here saying the crank were way out of balance.
Old 08-02-2014, 10:02 AM   #11
mboulton
Member#: 174433
Those were the older versions. The current ones are high quality and very effective. I am using one now without problems and have a second one for a build on my workbench currently.
I see no reason why someone wouldn't use a Manley crank if they want to step outside of OEM cranks.
Mel
mboulton is offline   Reply With Quote
Old 08-02-2014, 02:49 PM   #12
jl-wrx
Member#: 269228
Mel
I got the old version of the manley crank brand new still in the box not sure if I want to use it, i'll be to scared to use it. I will never buy a manley product again
Old 08-02-2014, 04:27 PM   #13
user1029
Member#: 57064
2008 STi IAG built
yeah IAG has snapped their 2.7L stroker old crank. They have undergone revision since then and have become a lot more stout
Old 08-02-2014, 05:41 PM   #14
mboulton
Member#: 174433
I also have a version 1 of the 95mm crank. I would readily use it after checking the balance first. Not planning a destroked motor any longer.
Mel
Old 01-17-2015, 07:06 PM   #15
slide
Member#: 1130
2013 STI Hatch
Back from the dead. Any opinions on the bc crank vs the Manley crank? Going into a motor that I want to spin up to 8500...
Pauter rods, sleeved, Cossie cams, headwork, rotated gtx3576r, e85 id2000's etc etc...
Texas mile in March....
slide is offline   Reply With Quote
Old 01-18-2015, 12:42 AM   #16
wEaK Squad
Member#: 337250
Texas mile? Or TX2K?
I'll have my car at TX2K
wEaK Squad is offline   Reply With Quote
Old 01-18-2015, 12:47 AM   #17
slide
Member#: 1130
2013 STI Hatch
Texasmile.net
