Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 07-31-2014, 01:37 PM   #1
Peter_WRX
Member#: 313620
2005 Impreza 2.5 STI
black devil
Default Building 400HP STI
In my stock subaru 2.5 sti 2005 was damaged piston. Now I'm in the process of renovating and preparing the car to the 400hp power. Below is a list of things that have been done in the car. What do you think about my new the setup?
Should I still make additional modifications for this power ?
ENGINE MODIFICATIONS
Manley 99.75 Pistons
Manley H-Beam Rods
Heat Treated Crankshaft (STI 2011+)
Main / Rods bearings ACL RACE
OEM head gaskets
ARP head studs/nuts
11mm oil pump (STI 2011)
Strengthened cylinder walls (aftermarket pegging)
Upgrade to 6 additional straight pins between crank cases (there are only 2 as standard and block may be unstable)
OTHER MODIFICATIONS
Scoobieclinic SC40 turbocharger
(TD05-20G 7cm, comp wheel 53mm / 68mm )
FMIC Autobahn88 CARP027
APS Twin Vent blowoff valve
Silicone turbo inlet Autobahn88
DW 850cc injectors side feed
Walbro 255l/h fuel pump
Setrab 16 Row Oil Cooler
Thank you for all opinions.
Peter_WRX is offline   Reply With Quote
Old 07-31-2014, 02:28 PM   #2
user1029
Member#: 57064
2008 STi IAG built
HTA86, Meth, 272s, Cos IM
Why peg when you can go outfront closed deck? Those cylinders will still crack with pegging. Get Manley I-beams and ARP Age625 studs because you will want more power in the future. Get ID1300cc injectors and walbro 465 for more headroom. 11mm pump not good if you don't have dual AVCS as killerB can explain.
user1029 is online now   Reply With Quote
Old 07-31-2014, 03:56 PM   #3
Peter_WRX
Member#: 313620
black devil
I dont go closed deck so pegs are my sollution for stable cylinders. I can crack cylinder walls at 20-22lb boost on td05 ?
I have installed h-beam rods, standrard arps and 255 fuel pump so i dont want more power at the future.
KillerB is solution for trouble with 11mm pump and single avcs setup ?
Old 07-31-2014, 04:00 PM   #4
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
No, you should use the 10mm with the 2005 STi. The 11mm pushes more volume at slightly less pressure at higher RPMs. This causes oil aeration in our cars. Just stahp
BeastianSTI is offline   Reply With Quote
Old 07-31-2014, 04:05 PM   #5
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
He has an sti with avcs. He will need an 11mm pump and especially if his engine is built to handle 400 or more hp. Have you ever looked at oil pressure on a 10mm in an sti with around .0015 clearance on mains and around .002-.0025 on rods? With 10w30 you get about 12psi at idle and 40psi at 3000 rpm. With those clearances you need all the flow you can get. With an 11mm on 10w30 you get slightly better but with the 11mm it will pump 40w or 50th a lot better than a 10mm will. Thus bringing you pressure up to around 18psi at idle and 55 to 60 at 3000 rpm.
fastblueufo is offline   Reply With Quote
Old 07-31-2014, 08:10 PM   #6
cartoonlife
Member#: 204291
07 UGM STi Ltd
2012 Prius
NO on the 11mm pump unless you have ridiculously opened up those clearances. Everything you've listed is great for 400awhp. Good luck
cartoonlife is offline   Reply With Quote
Old 08-01-2014, 05:32 AM   #7
Peter_WRX
Member#: 313620
black devil
Thank you very much for your feedback.
What about cylinder walls with this power ? May break or not worry about it ?
And what you think about upgrade to 6 additional straight pins between crank cases ?
Killer B Motorsport Oil Baffle Windage Tray is necessary for EJ257 engine ?
Old 08-01-2014, 06:02 AM   #8
Bru1212
Member#: 178770
06 STi
04 FXT
Not necessary but I'd say their pickup tube would be. The windage tray is a "mine as well while your there" kind of thing.
Bru1212 is offline   Reply With Quote
Old 08-01-2014, 01:32 PM   #9
user1029
Member#: 57064
2008 STi IAG built
You won't break the cylinder walls at those power levels. Since you went through the process/mindset of pegging it, you might as well solidify the whole thing into a closed deck is the point I was getting at
Essentially if you closed deck it, get I-beams, get ARP625s, you have a block that can potentially handle up to 900-1000 crank HP, talk about headroom
Old 08-01-2014, 02:47 PM   #10
SDoBB
Member#: 335853
2013 WRX 5 Door
CBS
Originally Posted by Bru1212 View Post
Not necessary but I'd say their pickup tube would be. The windage tray is a "MIGHT as well while your there" kind of thing.
Fixed that for ya.
SDoBB is offline   Reply With Quote
Old 08-02-2014, 12:13 AM   #11
m.bryant
Member#: 310077
2007 Legacy GT SpecB
Not necessary but I'd say their pickup tube would be. The windage tray is a "MIGHT as well while YOU'RE there" kind of thing.
Fixed that for ya.
Fixed that for ya.
m.bryant is offline   Reply With Quote
