Old 07-31-2014, 06:50 PM   #1
COwrxboy
Member#: 282129
2014 GTX3076'd WRX
Default A Few questions about building my motor.
So my 2014 WRX finally blew up! I knew it was coming because I was playing with fire! We put down 485 WHP and 495 WTQ corrected on a stock block with a custom rotated GTX3076 kit. So now it is time to build the block.
Here is what I have talked to a few shops and what they have recommended.
Benson sleeved block and possibly o-ringed if deemed necessary.
ACL Rod and main bearings (standard size)
JE Pistons 100mm with a comp ration of 9.5 or 10.5
New Sti Crankshaft
Carrillo Pro-A Connecting Rods
ARP Hardware
Here is where the questions are. Is that a strong enough rod? Should I be looking at the H-Beams? What are people thoughts on o-ringing? Any other thoughts for me?
I am shooting to max out the GTX 3076 and possibly jump up to the GTX 35 and go even bigger! So seeing 700 hp shouldnt be to hard on e-85
I would like to over build this motor so that I am not running on the ragged edge of its limits so there can be a "bit" of reliablility.
Thanks for looking everyone!
COwrxboy is offline   Reply With Quote
Old 07-31-2014, 06:55 PM   #2
user1029
Member#: 57064
2008 STi IAG built
HTA86, Meth, 272s, Cos IM
Carrillo makes great rods. Go with closed deck, O-ring, and 625 head studs you'll be good for 700hp easy
user1029 is offline   Reply With Quote
Old 07-31-2014, 06:59 PM   #3
silver2007impreza
Member#: 397800
2007 impreza
i perfered the weiscos no piston slap and thicker ring lands
silver2007impreza is offline   Reply With Quote
Old 07-31-2014, 07:01 PM   #4
silver2007impreza
Member#: 397800
2007 impreza
i would go with h beams as well. made 487 whp with them zero problems
Old 07-31-2014, 07:27 PM   #5
user1029
Member#: 57064
2008 STi IAG built
go with Manley I-beams for a whole lot of headroom, if not H-tuff if you were to switch to Manleys
Old 07-31-2014, 07:35 PM   #6
COwrxboy
Member#: 282129
2014 GTX3076'd WRX
I'd like to stick with Carrillo, lots of great results from all of the shops in this area. I was just wondering if the pro-a was enough rod or if I should go with the H rods.
Old 07-31-2014, 08:17 PM   #7
thisisthenewsic
Member#: 156829
05 legacygt,00 OBS
red 95 supercharged nsx
closed deck> sleeved
also seeing 700 on a 3076 is a far stretch. also if doing a closed deck, to 99.75 pistons.
also i wouldn't go with high compression pistons. I've read about testing and low compression made more power.
thisisthenewsic is offline   Reply With Quote
Old 08-03-2014, 04:25 PM   #8
kakarot09
Member#: 182375
08 Sti
Wrbm
I would personally go with the H beams. You're looking to maybe build further using a gtx35 so that will give you the head room. Also, make sure you're blueprinting all the measurements. You listed standard size ACL bearings but sometimes they need to be extra clearance etc.
Compression ratio depends on the fueling. You can make power with good fuel but don't run 10:1 on 91 octane or something.
kakarot09 is offline   Reply With Quote
