Welcome to the North American Subaru Impreza Owners Club Thursday January 29, 2015
Old 10-26-2002, 04:13 AM   #1
legacyej22
Member#: 23385
Default Air Conditioning Removal
Well winter has come and AC has become useless for 6 months, would it do me any good to remove my AC? I guess my real question is, is there anyy adverse side affects to removing the AC compressor to take a bit of extra pull of my crank? Thanks a lot
Josh
legacyej22 is offline   Reply With Quote
Old 10-26-2002, 01:05 PM   #2
awdwagon
Member#: 6585
1997 acura integra
champion white
your a/c compressor actually free wheels when its not in use, so if your bet wasnt on it you could actually spin the compressor pully with your hand and it would keep spinning for a second or two. the power streeting pump is what has drag on the motor cause if you take the belt off and try to spin that it actually take effoert to move and wont spin after you let go. so by taking you a/s out your only saving weight, dont get me wrong when you a/c is on theres drag on the motor but when its off it freewheels.
awdwagon is offline   Reply With Quote
Old 10-26-2002, 03:40 PM   #3
legacyej22
Member#: 23385
Thanks for clearing that up.
Josh
Old 10-26-2002, 08:17 PM   #4
JSiwek
Member#: 14909
Don't forget that defogging your windshield needs the A/C to do a good job. Besides cooling the air, it also takes all of the moisture out of it. If you noticed, when you hit defrost/defog on the selector buttons (the ones that change from head, feet, etc) it automatically turns on the A/C even if you don't have the A/C button pressed. So.... you may not need the cooling in winter, but you will almost definitely need to defog the windshield. My $.02 in addition to awdwagon's probably more useful advice :-)
Jeremy Siwek
JSiwek is offline   Reply With Quote
Old 10-27-2002, 03:13 AM   #5
legacyej22
Member#: 23385
Thanks a lot guys, I obviously didn't think this out too well before I posted!
Josh
Old 10-27-2002, 03:13 AM   #6
itWoRX
Member#: 21305
2002 WRX Sport Wagon
WR blue
Which I think is a drag because it isn't allways needed to keep the windows clear.....it helps when you first get started up or on a not so cold but rainy day (when you cant crack the windows for venting), otherwise, it would be nice if, while on "vent" or "vent and floor" or "floor only" you had a small amout of the heated air drift across the windshield so the compressor won't have to run (and subsiquently shut off when I need a good "quick pedal")...........but, all things considered, if that was the case, some people would never run the compressor (during the cold months) and it needs to run every now and again for lubrication purposes......
itWoRX is offline   Reply With Quote
Fresh (hot) air versus air conditioning? foreSTir Texas Impreza Club Forum -- TXIC 37 08-06-2004 07:38 PM
Air Conditioning weight removal. Corey Normally Aspirated Powertrain 15 05-07-2004 05:24 AM
Air Conditioning Removal whtlegacy Motorsports 27 03-07-2004 02:36 PM
Remove air conditioning? HudsoN456 Normally Aspirated Powertrain 11 03-26-2002 02:14 AM
('93-'01) Air conditioning question... Rally-RS Impreza Forum 0 06-03-2001 01:34 AM
