Old 10-26-2002, 03:20 AM   #1
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Default larger injectors on 00RS ecu
are any RS-T's running sti injectors??? 560's or something like that is the size I think. Any success? What sort of modifications have been done to make it work?
HamFist is offline   Reply With Quote
Old 10-26-2002, 10:55 AM   #2
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Probably the wrong forum for it but.....
sti injectors wont fit your 2000RS without alot of work. Right now RC engineering is the only company that make an application for your car. unlike the 99 intake manifold, the 2000 has a dual set seat. FWIW you *can* make them work, but milling of the intake manifold is needed.
Midwayman is offline   Reply With Quote
Old 10-26-2002, 12:42 PM   #3
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
mm...ok....they don't HAVE to be sti injectors. Any reviews on either for a 2k rs? On both fronts, How well do they agree with the stock ecu? Getting machine work done isn't a problem. Getting it done correctly is!
Old 10-26-2002, 01:45 PM   #4
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Any other sized injectors will not work with the stock ecu without additional management. Supposedly the greddy e-manage system will allow you to run different injectors.
Essentially to run different injectors you need either standalone management, or a complex piggyback like e-manage and do some machine work unless you get the rc injectors which only require the management.
Maybe if you wait awhile the utec will come out for the RS as well.
Old 10-26-2002, 03:32 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
You can run stock injectors on the stock ECU, but you'll need fuel trimming badly. Then you're using such a radical difference in size, that you'll have massive timing changes to top it.
If one were to try this route with the stock ECU and larger injectors, I would suggest a 2bar sensor (assuming you're going FI), larger injectors, an S-AFC for fine tuning, and a standalone timing management computer (Haltech has one, not sure who else does).
Old 10-26-2002, 04:57 PM   #6
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Hey 8. how well does that 2bar sensor work with teh stock ecu? does it trip any codes? yes. it'll be FI . I've seen extra injectors in action, but would rather put in larger injectors.
Old 10-26-2002, 05:50 PM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
To be honest, I haven't tried a 2bar on the stock ECU with double-size injectors (which'd be 560's), but in rough theory, it'll be somewhere in the ballpark of where it needs to be, just need some fine tuning with the S-AFC.
Really though, if you want drivability in the long run, ability to pass emissions, not throw a CEL, etc, you'd probably be best off with an additional injector or two on a 3d programmable setup, timing controller of some sort (boost based or standalone, and a MAP voltage clamp for the stock MAP sensor. This is originally what I was thinking of doing, but then I went nuts and went full standalone (Haltech E6K) instead. Drivability is now all in the tuning, so I have it down to a fairly smooth drive, but still have tweaking to do as the weather is changing pretty drastically.
Old 10-27-2002, 07:12 AM   #8
HubbieScooby
Member#: 7088
Super Slow
i have a 01 RS and after talking to skywalker...he told me to get the 99 manifold to fit the WRX injectors...so the RC injectors won't require me to have a 99 manifold right?? finding a 99 manifold is almost impossible here on the island
hugh
HubbieScooby is offline   Reply With Quote
Old 10-27-2002, 12:09 PM   #9
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
hugh
Yes. They came out with a 2000+ application about 3 weeks ago. Talk to tom at ludespeed if they dont know what you're asking for.
800cc injectors on stock ecu vf22-wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 04-13-2006 07:11 PM
Sti injectors on Stock ECU tep Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-12-2005 06:16 AM
Larger Injectors on ebay? Sauceboy01 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-08-2004 02:05 PM
larger diameter MAF housing w/larger injectors ride5000 Engine Management & Tuning 5 10-08-2003 11:58 AM
Bigger Injectors on Stock ECU? Sean McElderry Technical Forum Archive 30 07-11-2000 09:37 AM
