Old 08-03-2014, 10:32 AM   #1
tomkun
Member#: 244028
2011 base WRX
Default Bilstein Strut clunk
I have a set a bilstein strut paired with rce yellow springs for my 2011 wrx. I bought them used from a member on here, and I've been having problems with a clunking noise coming from the front driver side strut.
After searching around on the forums I found a DIY on how to degrease the struts. I was wondering if I can do this with my bilstein struts?
tomkun is offline   Reply With Quote
Old 08-03-2014, 12:02 PM   #2
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Check your top center nut for the tophat to make sure it's tight
Sent from my SGH-I337M using NASIOC mobile app
trev762 is offline   Reply With Quote
Old 08-03-2014, 01:09 PM   #3
subaru_gc8
Member#: 29292
2004 WRX wagon
when I had my v5 struts on my gm body, i had a clunk coming from the rear and it turned out to be the strut was bad.
subaru_gc8 is online now   Reply With Quote
Old 08-03-2014, 06:38 PM   #4
mitch808
Member#: 10228
2002 Subaru WRX
Strut top as mentioned or sway bar end links
Sent from my Nexus 7 using NASIOC mobile app
mitch808 is offline   Reply With Quote
Old 08-03-2014, 08:28 PM   #5
tomkun
Member#: 244028
2011 base WRX
I'll check on the top strut nut again, but I'm pretty sure its not the end links.
Old 08-04-2014, 07:40 PM   #6
yo vanilla
Member#: 71903
11 Audi A4 6MTQ
13 Mazda CX-5
you never know, i just had a end link nut loosen a little bit, causing a slight clunk. my bet is on something loose. check top nut, top hat nuts (don't overtighten!) sway bars, check tie rods and ball joints if you're still searching after that.
yo vanilla is offline   Reply With Quote
Old 08-21-2014, 04:39 PM   #7
tomkun
Member#: 244028
2011 base WRX
I checked both the sway bar, endlinks and top strut nut but none of those fixed the problem. Im going to regrease struts this weekend, hopefully that solves the problem.
Old 08-21-2014, 07:24 PM   #8
Vaughn Performance
Member#: 170489
I would check all the above mentioned. If you bump the car up and down listen near the strut, if it's loose enough you should be able to replicate the clunking. Even if you can't I would still ensure the tightness of the upper nut.
If you've done all the above and it persists (and are confident it is in fact coming from the strut) I would contact Myles at RCE. I haven't personally disassembled a set of these, I would assume removing the lower nut removes the entire insert from the housing, but I would check with them before doing anything. You would also need to be sure your are greasing the correct area inside the housing, you don't want muck to collect on the shaft that could potentially nick a bushing as the shaft moves in/out.
-Anthony
Vaughn Performance is offline   Reply With Quote
Old 08-21-2014, 08:01 PM   #9
tomkun
Member#: 244028
2011 base WRX
I imagined the bilstein struts are similar to the stock STI struts, but I'll give Myles a call tomorrow to see what he thinking about greasing the struts.
-Anthony
Old 08-24-2014, 08:43 AM   #10
tomkun
Member#: 244028
2011 base WRX
So I took apart the strut yesterday and as soon as I did this whitish liquid came out. There wasn't much grease inside at all, no wonder why it was clunk so bad. I repacked it with Mobile 1 synthetic grease and now theres no noise what so ever.
