Old 08-03-2014, 04:48 PM   #1
04subielover
Member#: 347637
2004 wrx
Default Help decide CR radio with hybrid on corn
We'll I'm in the process of ordering 99.75 pistons for my hybrid. Either working my head if they are good or working a set of v5 or v6 heads. Will have sti kelford 276/272's with Avcs plugged (got them cheap) either a gtx3076 or precision 5858 on e85 all the time. Will be mostly my daily and looking at Manley pistons with turbo tuff rods. Wondering what CR should I go with. Was thinking maybe 9.8.1. Give me your opinions
Sent from my iPad using NASIOC
04subielover is offline   Reply With Quote
Old 08-03-2014, 05:44 PM   #2
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
keep it stock, subarus dont like high comp ratios.
Bariga is offline   Reply With Quote
Old 08-03-2014, 06:02 PM   #3
DisoDisp
Member#: 187648
2007 WRX
I beg to differ:
Do go higher.
I'm running 10:1 on @ 8374 at 34psi showing 740whp on VD.
Seen cars runnign up to 13:1 on corn making power.
DisoDisp is offline   Reply With Quote
Old 08-05-2014, 09:33 AM   #4
04subielover
Member#: 347637
2004 wrx
Any other input? Was jw cause doesn't a head matched hybrid still bump up the cr?
Old 08-05-2014, 11:35 AM   #5
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
No it does not bump the static CR, it LOWERS the static CR because you are opening up the cc's of the combustion chamber to a larger volume.
2Fast4U1DAY is offline   Reply With Quote
