Old 08-09-2014, 10:52 AM   #1
Jaylay
Member#: 388128
2002 wrx
wrb
Default Coilover adjustment question
I understand that I have to thread the upper lock ring down to adjust ride height. I have the lowest lock ring loosened, but the top will not thread down. They're are two bolts on the coil and I read that I need to loosen the top one to be able to thread down. Can anyone elaborate on this? Thanks
Sent from my SM-N900V using NASIOC mobile app
Jaylay is offline   Reply With Quote
Old 08-09-2014, 12:00 PM   #2
funk32
Member#: 245787
2004 STi
which coilovers do you have?
funk32 is offline   Reply With Quote
Old 08-09-2014, 01:02 PM   #3
jaboyd
Member#: 247304
2011 STI
WR Blue
Generally the 2 lock rings are on the bottom of the spring (top rests against a fixed perch) so yes you usually need to loosen the lower ring before moving the top ring higher to raise height, or lower to drop the height. Where are the 2 bolts located that you're referring to? On some coil-overs the rings have locking set screws in the collar that need to be loosened to rotate the ring.
jaboyd is offline   Reply With Quote
Old 08-09-2014, 02:46 PM   #4
Jaylay
Member#: 388128
2002 wrx
wrb
I'm referring to the instructions in this picture: http://www.meganracing.com/uploadima...2010_14624.jpg if it works lol. I have bc coilovers
Old 08-09-2014, 03:51 PM   #5
leecea
Member#: 37359
2003 WRX
leecea is offline   Reply With Quote
Old 08-09-2014, 06:47 PM   #6
Jaylay
Member#: 388128
2002 wrx
wrb
Originally Posted by leecea View Post
This is what I've been trying to do but I will try again and report back
Old 08-10-2014, 11:24 AM   #7
Jaylay
Member#: 388128
2002 wrx
wrb
Okay they will not budge. Any advice as to where go from here? I've been using pb blaster but it's not working.
Old 08-10-2014, 05:47 PM   #8
hudsonvalleybugeye
Member#: 295068
2001 forester
I know this sounds silly, but are you turning them the right way? You need to hold the top ring with a tool while loosening the bottom "locking" ring. (At the bottom of the spring). Spray down and clean the threads with a brush if need be.
Good luck!
hudsonvalleybugeye is offline   Reply With Quote
Old 08-22-2014, 12:27 PM   #9
Jaylay
Member#: 388128
2002 wrx
wrb
yes i have been doing it correctly. It will not budge and i assume thats due to dirt and debris being down there. Where do i go from here?
Old 08-22-2014, 01:50 PM   #10
sc00by4life
Member#: 97135
put them in a vice and use an air hammer (or a deadblow).
