Old 08-17-2014, 02:01 AM   #26
MedicDG
Member#: 329822
2012 WRX, Sedan
You may need new tires cupping could cause your problem with vibration at freeway speed.
Wheel spacers can also be your problem.
If your wheels are not centered hub that can also cause your problem.
Alignment should be zero toe in all four corners.
Honestly I feel you have a worn suspension part problem. I would start with a worn ball joint. Subaru are known to have ****ty ball joints. Sounds like you are using wider tires with spacers so you can cause your ball joints to wear faster. I don't know how many miles on your car but those are cheap and easy to replace so you may want to think about that.
DG
MedicDG is offline   Reply With Quote
Old 08-17-2014, 02:16 AM   #27
rymaggi
Member#: 253442
DG
The tires aren't that old. Maybe 6k miles.
The wheel spacers are hub centric, the literally pop onto the hub and don't move at all. They didn't vibrate before the car went down for a motor build either.
The wheels also have hub centric rings on them.
My ball joint are white line, and they maybe have 15k miles on them. If that even. Maybe 10k.
The car has 90k miles.
The BC BR coilovers with swift springs have about 20k on them as well. No leaking, no clunking, not harsh. Not signs of being blown at all.
And found out the other day, les Schwab didn't even rotate my tires.... Frustrating.
rymaggi is offline   Reply With Quote
Old 08-17-2014, 02:23 AM   #28
MedicDG
Member#: 329822
2012 WRX, Sedan
Try moving front tires to rear. If vibration in steering wheel goes away and you can feel it in seat it's one of the rear tires.
If you rotate them and vibration in steering wheel is still there I say you got a suspension problem of some sort.
I would do this yourself if you can. I like to do my own work on my car because generally these shops make too many mistakes. I call it piece of mind. Ha
Old 08-17-2014, 02:26 AM   #29
rymaggi
Member#: 253442
Default Steering wheel vibration highway
Yea I definitely like doing my own work too because of this crap. I've just been lazy, I don't have a garage tell September first when I move into my house.
I'll rotate them tomorrow night or Monday and report back.
If vibration is still there, I'm gonna try swapping tires with a buddy.
If problem is STILL there, I'm not sure what to do, take it to subaru maybe, because I've had two shops run through the suspension and they said everything looks and feels fine, and the last thing I wanna do is start just aimlessly buying new parts.
I don't even know what it could be suspension wise, almost everything has been replaced. Coils, sti control arms, anti lift kit, roll center kit, sways, endlinks, v7 hubs that are solid (no play), v7 axles (not making noise)
Old 08-17-2014, 02:29 AM   #30
rymaggi
Member#: 253442
I'm just praying it's not the steering rack.
Old 08-17-2014, 02:30 AM   #31
MedicDG
Member#: 329822
2012 WRX, Sedan
Ya let us know. I think your problem will go away after rotation. If not I say high percentage it going to be a suspension but hey I can be wrong.
Ps another thing u may try is get tires rotated by another shop.
Old 08-17-2014, 05:49 AM   #32
MedicDG
Member#: 329822
2012 WRX, Sedan
Sorry not rotated but tires re balanced by another shop. I find America's Tire does a good job in that area.
Old 08-17-2014, 05:49 AM   #33
MedicDG
Member#: 329822
2012 WRX, Sedan
Ya that would suck....report back Monday. Good luck!
Old 08-17-2014, 12:16 PM   #34
rymaggi
Member#: 253442
Another thing..... So say I rotate them, fixes steering wheel vibration, won't the fronts just cup as well?
Old 08-17-2014, 12:19 PM   #35
Annihilator817
Member#: 296742
2006 BigE Motorsport
WRX
Most likely if you dont fix the underlying issue that is causing the cupping.
Annihilator817 is online now   Reply With Quote
Old 08-17-2014, 12:21 PM   #36
rymaggi
Member#: 253442
What exactly can cause cupping. My toe is at zero now. And it's aligned.
Old 08-17-2014, 12:43 PM   #37
Annihilator817
Member#: 296742
WRX
Blown shocks.
Old 08-17-2014, 01:44 PM   #38
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Lack of rotating tires can also cause cupping. Also bad toe out on the rear can magnify and make it come one faster.
Have you checked your p/s reservoir for air bubbles while running? Might have some clamps that have given up holding an air tight seal but aren't leaking fluid. It really sound like p/s based to me as it comes and goes.
I replaced the seals in my p/s pump and it had this weird shake on the highway that would come and go. This was right after I replaced them and it took about a week to get the air out. But not until I replaced the factory clamps did it finally go away for good. Seems like just moving those lines will sometimes break the seal of the old clamps and you just need to replace them. I would try that. Good luck.
Blingstrom is offline   Reply With Quote
Old 08-17-2014, 04:43 PM   #39
MedicDG
Member#: 329822
2012 WRX, Sedan
It's possible all four tires are not cupped. I feel rotating front to back will give u a idea what to do next.
Old 08-17-2014, 09:21 PM   #40
vincybadman
Member#: 147686
Just did a jdm sti build and I am having the same exact problem!!! Will be replacing my rotors and Pads to see if it's helps... This is frustrating ...
vincybadman is offline   Reply With Quote
Old 08-17-2014, 09:23 PM   #41
rymaggi
Member#: 253442
It sure is, about to change my oil and rotate my tires. Gonna try n bleed the system of an air if any, and also tighten down the clamps on the two hoses.
Old 08-17-2014, 10:25 PM   #42
rymaggi
Member#: 253442
Zero air in the system. So les Schwab rotated one side of the.... Left the Otherside the way it was.
Briefly checked the suspension bits as I pulled off each tire no play in anything, the axles did shake but hardly anything. Maybe a mm or two. If rotating, the side les Schwab didn't, does not work. I'm going to swap wheels with a buddy. To confirm if it's my tires or not.
If it's not the tires I'm literal lost as to what it could be.
Old 08-17-2014, 11:05 PM   #43
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Unless you have tires that are separating or extremely cupped tires I am not thinking its an issue with the wheels/tires.Balanced or unbalanced wheels don't really come and go. Extreme as in a four or five/32nd difference between the cupped area and full tread. Unless you drove 10k+ miles with an exceptional bad alignment and worn suspension I cant see these tires being that bad. Also your cupped tires would be very noisy when first rotated to the front. Other than CV shaft issues its really hard to think of something else that causes intermittent vibrations.
How long has it been since your p/s pump was replaced? I have drove down the highway with air in the system and I could barely keep the wheel from exiting my hands at 75. And then magically it would be gone... Minutes later I am holding on for dear life. Car maintains straight trajectory but the steering wheel feels like its moving an inch in either direction. This really sounds like what your first post is describing. But I could be wrong.
I also had tried to bleed the air out of the system for an hour to still feel the same symptoms you speak of. Only came to the conclusion that without reclamping the return to reservoir line and reservoir to pump line my on and off steering wheel shake would not go away. Also found it usually takes a good week of driving to bleed it completely. Even after an hour of lock to lock with the front wheels off the ground... Air finds away in.
Old 08-17-2014, 11:35 PM   #44
rymaggi
Member#: 253442
I tried running my hands along the tires, I couldn't really feel the cupping. But the front two did have slight camber wear.
Both lines on the power steering pump were replaced with the new pump. Which happened about 2-3 months ago. The clamps on all the lines are worm clamps. I tightened them down, even though they where decently tight, the hose that attaches to the inlet on the pump has two worm clamps, the clamp on the inner outside, closest too the reservoir, was a little lose, not much. Tightened it down.
I can relate to the dear life situation before the pump. Now it's minor but differently a solid vibration, not something u can barely notice. It moves. It's like the new pump dumbed it down 75%.
Filling the car with oil now, gatta go pick up the o'l lady and my sister, and I'll be hoping on the freeway.
Will report back.
Old 08-17-2014, 11:51 PM   #45
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
I tightened my clamps moderately at first but yeah I changed that after still having some issues. Might go ahead and check the lines on the actual rack as well and if a seal on the rack was bad there should be some fluid in the bellows boot. Should be easy to check.
I went though like a month ordeal after putting in three p/s units before just rebuilding the original one. Changing those clamps and retightening them and so forth. Buying a new line after my old hose tore and then getting new crush washer for the line off the pump. Very agitating.
Reading your post just reminded me of how frustrating it was and I was hopeful some of my own experiences would help you not be tortured by this issue. Good luck. Hope you get it figured out soon.
Old 08-17-2014, 11:59 PM   #46
rymaggi
Member#: 253442
Thanks man. Yea it sucks. I have a fun car and I don't like doing pulls or passing people on the freeway because of it.
For the steering rack, checking the lines, do u mean those two hard lines. Also where and what does the seal look like. And for fluid being in the boots if it's leaking, do u mean literally on the inside of the boots or on the outside but closest to the middle of the car.
Old 08-18-2014, 12:01 AM   #47
rymaggi
Member#: 253442
Also, thanks for everyone's input and help. It's nice when you get positive feedback when dealing with a massive headache of a a problem like this. Greatly appreciate it.
Old 08-18-2014, 03:22 AM   #48
rymaggi
Member#: 253442
Vibration 98% gone. From just rotating one side.
I can still feel it just a smidge but hardly anything at all if any. At all speeds.
Old 08-18-2014, 04:15 AM   #49
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Honestly to me i sounds like a blown front control arm bushing is the underlying cause. Very hard to diagnose. Will cause cupping by itself and stead speed highway vibrations. Will go away under acceleration and braking due to elevated loads on the suspension in one direction changing the load vs. natural frequency of the suspension. I suggest replacing the front control arm bushings as a safety measure to prevent recurrence.
Just my opinion.
P.S. If Les Schwab can't get your alignment any closer than that side to side I'd head to a different shop. The difference side to side would never be ok for my autoX car.
speedyHAM is offline   Reply With Quote
Old 08-18-2014, 08:33 AM   #50
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Seals are within the bellows boots Mon the steering rack so fluid will collect within them. Might see it damp around the clamps as well. I think there are connections from flexible lines on the steering rack to hard lines and I would check those clamps.
