Old 10-27-2002, 12:37 PM   #1
jbogli
Member#: 26006
2002 Impreza WRX
Question HKS Turbo Timer Install
Ok we're in the middle of the install right now. The timer comes on we can fiddle with the settings, we've hooked up all the harness's and the ebrake cable, there is still the brown RPM cable that is not hooked up. When we turn off the car the turbo timer shuts off and the engine does not run. What is going on, what are we missing?
jbogli is offline   Reply With Quote
Old 10-27-2002, 01:32 PM   #2
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
sounds like the ebrake cable isn't functioning correctly....try wiggleing your connection....thats what i did and then my TT works fine....
ScreaminFast is offline   Reply With Quote
Old 10-27-2002, 04:14 PM   #3
tdxflex
Member#: 13634
are you on auto countdown or manual countdown? if you idle long enough in manual countdown it can turn off the car right away, but yeah it sounds like the connection to your ebrake isn't solid.
tdxflex is offline   Reply With Quote
Old 11-02-2002, 11:13 AM   #4
jbogli
Member#: 26006
2002 Impreza WRX
Default Thanks
I will test that out when i get back from england
Old 11-02-2002, 12:28 PM   #5
03 Silver Bullet
Member#: 27222
2o1o Audi S4
Imola Yellow
I had the same problem with mine. You have to make sure that the E-brake Wire is conected to a ground. Its really wierd. When i didn't have the e-brake wire connected to the e-brake, it was attached to a ground in the car.
dc
03 Silver Bullet is offline   Reply With Quote
HKS turbo timer install soloflo Car Audio, Video & Security 2 10-06-2002 04:28 AM
HKS turbo timer install alltractionWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-14-2002 11:15 AM
HKS Turbo Timer Install - Easy? wy_wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-06-2001 11:08 AM
('93-'01) HKS turbo timer installation sj208 Impreza Forum 2 08-07-2001 12:21 AM
