Welcome to the North American Subaru Impreza Owners Club Wednesday April 1, 2015
Old 10-27-2002, 01:40 PM   #1
whiterabbit
Member#: 16755
Default STi gold Brembo's fit on WRX? & Advan RC2 ?
Will these brake calipers fit on WRX rotors? Or do I need to get upgraded rotors as well? If so where do I get those?
Also, they should fit under my Advan RC2 right? 17x8.5 +45mm.
thanks
whiterabbit is offline   Reply With Quote
Old 10-27-2002, 09:33 PM   #2
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
should be no problem
I've seen RC2's on an STi before
ellisnc is offline   Reply With Quote
Old 10-27-2002, 10:21 PM   #3
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
No. The appropriate rotors for the Brembo fronts are 326x30mm and the Brembo rears are 316x20mm. You can source these rotors through DBA(IIRC they make them for Subaru oem.) The fronts will bolt right up with the appropriate rotors. The rears are a huge project.
I dont want to contradict ellis, but I know the 16" RCs have clearance issues with the Subaru STi 4pots. I would really research this one. Its the spoke shape of the RCs that is the problem. 18s I believe would be no prob.
subysouth is offline   Reply With Quote
Old 10-28-2002, 03:15 AM   #4
DBAsteve
Member#: 16839
I've set up a Brembo 326mm x 30mm rotor on a MY99 WRX upright with the Brembo Caliper. No problem. Wheels clearance is an issue though. The rotor has a shorter offset and the caliper is wider.
The rears are under investigation.
Steve
DBAsteve is offline   Reply With Quote
Old 10-28-2002, 06:16 AM   #5
ellisnc
Member#: 4229
2003 S2000
sorry, misread the post... I was thinking he was wondering if the calipers would fit under the rims
that's what I get for posting after autocrossing all day.
almost won Smod though finished 2nd by 33 thousandths and was probably in the top 5 times for the day.
09 sti bumper/fenders fit on wrx? chads09 Interior & Exterior Modification 0 09-08-2009 07:23 PM
sti manifolds dont fit on wrx evo 3ater Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-01-2009 02:05 PM
will evo brembo's work on wrx/sti? Go_Rex_Go Newbies & FAQs 2 01-22-2007 04:48 PM
Will rear brembo's fit on stock wrx wheels? D Money Brakes, Steering & Suspension 11 06-14-2006 04:29 PM
Will 05 STI brembo's fit 02 WRX Don Arm Brakes, Steering & Suspension 6 03-09-2005 09:46 AM
