Welcome to the North American Subaru Impreza Owners Club Sunday March 29, 2015
Old 08-18-2014, 01:57 PM   #26
Rob_STI_PNW
Member#: 387796
2015 WRX
RED
yeah and now im looking for another car as a daily, turning my STI into a auto cross car lol
Rob_STI_PNW is offline   Reply With Quote
Old 08-18-2014, 02:05 PM   #27
danger1138
Member#: 279525
04 rex luger!
Originally Posted by subies rule View Post
Pretty sure if you were to look in the owners manual 5w30 is the oil they recomend
Pretty sure if you look in the owners manuel, no where on it does it state to go stage II and add a bunch of aftermarket parts to your car. When you increase power output you must also add a more robust oil to the mixture that will hold up to the extra stress on engine. Owners manuel goes out the window.
Two big idiotic errors you have made.
1)Using Mobil 1 5W-30 oil on a turboed stage II subie.
2) Starting a thread that discusses your warranty fraud plans
danger1138 is online now   Reply With Quote
Old 08-18-2014, 03:48 PM   #28
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
You can't just drop in a shortblock.
1. Either replace or delete the oil cooler
2. Turbo needs to be inspected and/or potentially rebuilt/replaced. 90% of the time after a motor goes, it takes out the turbo as well. The turbo bearings are easily destroyed. I think they are brass or something quite malleable.
3. Cylinder heads need to be completely cleaned out, with all oil gallery plugs removed and brushed out with soap and water. Cleaning up after contamination is a PITA. Also clean the cams and VVT gears. I would send those out to a shop to have them cleaned. make sure they have the alignment tool, otherwise you're just rolling the dice.
4. All oil lines should be cleaned, as well as valve covers etc... anything that can hold the tiny shards of bearing material.
5. Oil pan ... It's not worth using the oil one after a bearing failure. You could pay a shop to ultra sonic clean it, but again ... I'd rather just drop 100$ for peace of mind that my $1500 + investment + time + research doesn't go to waste Speaking from experience... Also might be a good time to replace your oil pickup tube with something a bit sturdier.
6. Clean oil control valve solenoids. Gotta make sure no bearing materials are all up in yo 'ish!
That's all I can think of off the top of my head. I had dirt contamination on my first build, which tore up my bearings. Hope that helps... Don't try to screw the dealership over for your mistake though dude.
BeastianSTI is offline   Reply With Quote
Old 08-18-2014, 04:03 PM   #29
joek92
Member#: 353938
2007 STI WRB
18x8.75 +35 225/40
The feelz man I spuna bearing in my last sti with mobil 1
So the added protection of 5w40 offsets the longer warm up time?
This thread should come with the purchase of every subie:
http://forums.nasioc.com/forums/show...ight=rod+knock
joek92 is offline   Reply With Quote
Old 08-18-2014, 04:23 PM   #30
bluesubie
Member#: 767
04 FXT
Default Spun rod bearing
Originally Posted by LGT257 View Post
Porsche always used mobil 1 from the factory, so that part is a bit confusing considering the boxer engine.
The Mobil1 the OP used is NOT the same Mobil1 as used by Porsche. The M1 that meets Porsche A40 spec is the 0W-40 and is an excellent choice for a turbocharged Subaru.
Modify your car, modify your oil viscosity. Although no oil can fix the nut behind the wheel.
-Dennis
Old 08-26-2014, 07:56 PM   #31
subies rule
Member#: 378860
2010 Wrx sedan
Dark grey
Alright so turns out it was a melted piston... And they will warranty the short block but not the damage done tomthe head
subies rule is offline   Reply With Quote
Old 08-26-2014, 08:02 PM   #32
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
damn it
Old 08-26-2014, 08:08 PM   #33
subies rule
Member#: 378860
2010 Wrx sedan
Dark grey
It will only end up costing me about 200-300$ haha so im happy
Old 08-27-2014, 08:23 AM   #34
LGT257
Member#: 398087
2007 Legacy GT EJ257
Lucky lucky man.
LGT257 is offline   Reply With Quote
Old 08-27-2014, 10:45 AM   #35
subezero
Member#: 207614
2008 WRX Hatch VF52d
SSM
What made you run so lean?
subezero is offline   Reply With Quote
Old 08-27-2014, 11:03 AM   #36
PDX_STI
Member#: 399475
2005 STI
probably the stage 2 without a tune
PDX_STI is offline   Reply With Quote
Old 08-27-2014, 02:50 PM   #37
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
bein real st00pid and thinkin he was all k00 an ****
it'll blow up again...maybe real soon
Old 08-27-2014, 06:53 PM   #38
subies rule
Member#: 378860
2010 Wrx sedan
Dark grey
Cobb intake
Cattless dp
Invidia n1 cattback
Grimmspeed up pipe 38mm ewg with tial ewg
Id1000
Dw65c
Was etuned maybe a bad tune..
Old 08-27-2014, 07:14 PM   #39
Annihilator817
Member#: 296742
'11 WRX, '96 328i,
'92 Civic SiR, '94 Civic
Cobb intake
Cattless dp
Invidia n1 cattback
Id1000
Dw65c
And there you have it.
This is the reason that those of us with a legitimate warranty claim get put through the wringer if we need to use it.
Annihilator817 is offline   Reply With Quote
Old 08-27-2014, 07:20 PM   #40
subies rule
Member#: 378860
2010 Wrx sedan
Dark grey
U gonna cry yourself to sleep over this?
Old 08-27-2014, 09:41 PM   #41
wrxsubaruwrx
Member#: 60415
1973 Gran Torino
Green w rust coloration
You're a classy guy, Nicholas.
wrxsubaruwrx is online now   Reply With Quote
Old 08-28-2014, 02:08 PM   #42
gtbensley
Member#: 167448
2013 2013 wrx hatch
Plasma blue pearl
Thank you for being a stand up guy and having Subaru pay for your mistake.
gtbensley is offline   Reply With Quote
Old 08-28-2014, 02:56 PM   #43
fiorano94
Member#: 307081
14 STi Hatch
Jesus H.
Always happy to see people like you screwing the system.
fiorano94 is offline   Reply With Quote
Old 08-28-2014, 03:22 PM   #44
subies rule
Member#: 378860
2010 Wrx sedan
Dark grey
Watever the dealer ship knows that its been returned to stock and they will still warranty my short block
Old 08-28-2014, 03:35 PM   #45
Rob_STI_PNW
Member#: 387796
2015 WRX
RED
don't think people would be giving you as hard of time if you didn't blatantly come out and say you were committing warranty fraud..
Old 08-28-2014, 03:37 PM   #46
acumenhokie
Member#: 271479
2010 LGT (Stg 4)
2009 FXT (Stg 1)
Is it Otto or Ogilvie that we should send a note to about this thread?
acumenhokie is offline   Reply With Quote
Old 08-28-2014, 03:45 PM   #47
Ruzty1311
Member#: 311911
2012 WRX Limited Sdn
SWP (TP Stg 2)
If the dealership knows what was in there and they STILL warranty it then the DEALERSHIP is the one committing the fraud lol There's some special kind of stupid going on in here.
Pay to play yes, but if you roll the dice and they happen to land on your number then so be it. "It's you guys that screw it up for everybody else!" Oh boo hoo boo boo!! Everyone acts like they have some kind of influence here on someones decisions in life lol!! Those type of comments are futile.
He gambled. He won. Case closed.
Ruzty1311 is offline   Reply With Quote
Old 08-28-2014, 08:22 PM   #48
subies rule
Member#: 378860
2010 Wrx sedan
Dark grey
No comment
