Old 08-20-2014, 03:07 PM   #1
cmbezln
Member#: 372000
2011 WRX
Default OK to take off top nut from strut while on car?
I'd imagine the compression from the weight of the car would be more than enough to compress, but want to verify before I do something stupid.
Getting crazy creaking from rear suspension after RCE install and want to throw a washer under the top nut.
cmbezln is offline   Reply With Quote
Old 08-20-2014, 03:19 PM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
yes.
as always, do your best to prevent the shaft from spinning with the nut, as it can damage strut piston seals.
Old 08-21-2014, 10:36 PM   #3
Honest Bob
Member#: 94698
2005 30R Wagon
CGM
The car is the only spring compressor I own.
Honest Bob is offline   Reply With Quote
Old 08-22-2014, 03:31 PM   #4
cmbezln
Member#: 372000
2011 WRX
Originally Posted by ride5000 View Post
yes.
Perfect, thanks a bunch. I plan on torquing it down with an impact wrench on the rear struts, not too tight obviously. Hopefully that should stop it from spinning too much
Old 08-22-2014, 03:32 PM   #5
cmbezln
Member#: 372000
2011 WRX
Ha, so you just take the top nut off and let the spring decompress while you raise the car if you need to swap springs? I never really thought about doing that.
Old 08-22-2014, 06:04 PM   #6
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
Worked on a Benz a couple weeks ago and that was the only way to actually install the springs...
Two tire shops couldn't compress the spring down small enough and get it to align with the top hat.
I can scratch one car manufacturer off the list of cars to own.
mrsaturn7085 is offline   Reply With Quote
