Old 08-24-2014, 11:28 AM   #1
Bgordon1635
Member#: 393338
Default Compression test results?
1-110
2-118
3-119
4-118
Car has 163k. Any opinions?
2004 wrx sti 2.5l
Bgordon1635 is offline   Reply With Quote
Old 08-24-2014, 11:35 AM   #2
Bgordon1635
Member#: 393338
Test was done while car was fully warmed up.
Old 08-24-2014, 12:09 PM   #3
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
Those are real low numbers. My buddy has an 05 sti with 80-90k and his numbers are in the 150s. You should start saving for a rebuild.
Next thing you need to do is a leak down and see what % each cyl is leaking.
Brother EddieJ. is online now   Reply With Quote
Old 08-24-2014, 06:35 PM   #4
Bgordon1635
Member#: 393338
Okay, thanks I appreciate the opinions. Guess I need to start saving
Old 08-24-2014, 08:12 PM   #5
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Dead.
Old 08-24-2014, 10:26 PM   #6
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Really helps if you fill out your profile - where are you located? Are you at altitude or sea level? If I measured 110 psi at my house, that would correspond to 131 psi at sea level. (118 would be around 141 psi) Your engine should be around 141-171 psi at sea level, with a max delta of 7psi between cylinders.
Have you done a compression test before? Mistakes in the procedure can yield less than accurate results. Make sure you have the gauge in there snug, the fuel pressure has been vented and fuel pump relay pulled, and all of the spark plugs removed, then crank until you get a stable reading. Make sure you repeat your measurements and that they are consistent.
Altitude Factor
1000 .9711
2000 .9428
3000 .9151
4000 .8881
5000 .8617
6000 .8359
7000 .8106
8000 .7860
how is the car running?
Old 08-27-2014, 10:56 AM   #7
Bgordon1635
Member#: 393338
Runs alright and located in middleburg pa 17842. How would it have to do with alritude
Old 08-27-2014, 03:45 PM   #8
WolfPlayer
Member#: 65054
2005 STI (CGM)
Descooped / Dewinged
My 05sti results for comparison. Compression (Leakdown). Performed by me. Motor was warm (not hot). Almost sea level here.
#1: 155psi (6.7% ... 90psi -> 84psi)
#2: 157psi (5.6% ... 90psi -> 85psi)
#3: 156psi (4.4% ... 90psi -> 86psi)
#4: 160psi (3.3% ... 90psi -> 87psi)
WolfPlayer is offline   Reply With Quote
Old 08-27-2014, 03:48 PM   #9
WolfPlayer
Member#: 65054
2005 STI (CGM)
Originally Posted by Brother EddieJ. View Post
... My buddy has an 05 sti with 80-90k and his numbers are in the 150s ...
lol. I replied to this thread before I even realized you posted.
Old 08-27-2014, 05:16 PM   #10
Bgordon1635
Member#: 393338
Could me just unplugging the injectors instead of pulling the relay out have anything to do with it
Old 08-27-2014, 05:42 PM   #11
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
def seem low mine were pretty much 150 in all 4
BigRob74 is offline   Reply With Quote
Old 08-27-2014, 09:21 PM   #12
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Originally Posted by Bgordon1635 View Post
How would it have to do with altitude
Because the air pressure and density is lower as you go higher in altitude.
Old 08-28-2014, 08:24 PM   #13
nsanteramo
Member#: 388743
Seems low. Mine in the 04 are at or around 150. Nice to see an 04 with 160+!
nsanteramo is offline   Reply With Quote
Old 08-30-2014, 10:25 PM   #14
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
Your compression is fine. As long as they are all close, then you have nothing to worry about. Drive on, and co grass for putting that many miles on one motor.
Sent from my SM-G900V using NASIOC mobile app
ResidentR is offline   Reply With Quote
Old 09-02-2014, 01:51 AM   #15
2012 WRX
Member#: 376227
2012 WRX Hatch
Grey
1-110
2-118
3-119
4-118
2004 wrx sti 2.5l
Is your car running well? No CEL's? If so I would suspect your compression gauge is not accurate.
I hooked my compression gauge up to my Craftsman air compressor and my gauge reads a full 20psi lower than the compressor's gauge. And all these years I thought my motors had low compression...
The point is, if it's running good and the numbers are consistent, your probably ok.
2012 WRX is offline   Reply With Quote
Old 09-02-2014, 08:19 PM   #16
turbo05rex
Member#: 400394
those are some low numbers i would recomend on starting to put a motor together
turbo05rex is offline   Reply With Quote
Old 09-02-2014, 09:03 PM   #17
Leadfootin
Member#: 79441
2011 Outback
red
Leak down the cylinders on a reasonably warm engine otherwise you don't have a clue. Compression is only an indicator if one cylinder is vastly divergent from the rest. Anything over 5% leak should be investigated. Valve leaks can be heard in the intake or exhaust as appropriate. Ring leaks in the crankcase i.e. oil filler. Take a 5% motor down to 1% and the power increase is shocking.
Leadfootin is offline   Reply With Quote
Old 09-03-2014, 10:41 AM   #18
grimnj
Member#: 400660
The big problem I see with jumping to a conclusion is that the numbers are consistent, sure you have 163k, but it's rare that you would see that kind of consistency if there was a big problem.
Concur, leak down, and check another car, known good, to get a baseline on the gauges.
grimnj is offline   Reply With Quote
Old 09-04-2014, 09:22 AM   #19
WolfPlayer
Member#: 65054
2005 STI (CGM)
Na. But, you don't need to do that. You don't need to pull the relay either. To stop fuel from flowing just press the gas peddle all the way to the floor. This triggers the ECU into clear flood mode and the injectors won't fire. For me, I pull the IGN fuse to stop the ignition and I press the peddle to the floor to stop the injectors from firing. Easy peasy lemon squeezy.
Old 09-04-2014, 09:57 AM   #20
JimmyBoyWRX
Member#: 371081
2013 WRX Limited
2006 WRX
IGN relay also disables injectors.
JimmyBoyWRX is offline   Reply With Quote
Old 09-04-2014, 12:53 PM   #21
boost-o-matic
Member#: 248364
2010 Huevos grandes
WRX Dom 1.5XTR E85 silver
Toast...sell it to some unsuspecting fool. =P
boost-o-matic is offline   Reply With Quote
Old 09-04-2014, 12:57 PM   #22
boost-o-matic
Member#: 248364
2010 Huevos grandes
The rule of thumb is no more than 10% diff between cylinders, so you're fine there. 150-180 is normal range. You're definitely low, and losing some performance, but car could keep going ok. I would spend any money on mods though. Lesson learned, don't keep a car this long. A subie with 163k miles is a hot potato. Don't be left holding it when the buzzer goes off! That goes for any high mileage car really...just that these typically don't have much life past 150k from what I see on here.
