Old 10-28-2002, 09:47 AM   #1
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Default Best ECU for complete engine swap
When swapping a complete engine and not retaining much of any of the stock characteristics... What are the better ECU's??? Anyone actually done a complete swap without installing that engines ECU first?
I'm considering Tec II/III & Haltech E6K... any others?
I've got a complete EJ22T engine that I will be throughing into my 1997 OBS. I have the stock Legacy Turbo ECU, but only want to use the wiring... not the ECU.
The engine will not be kept stock so it would be no use anyway.
Thanks - Jon
omahasubaru is offline   Reply With Quote
Old 10-28-2002, 11:50 AM   #2
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Well, there is always the other common standalone around here. Link Plus. It'll run it.
Midwayman is offline   Reply With Quote
Old 10-28-2002, 12:48 PM   #3
davidm_sh
Member#: 5994
2004 Impreza WRX STi
Java Black
I would vote for TecIII and STAY AWAY from Link(anything)... or you could try the UTEC... oh wait nevermind .
You probably already know about it but might want to check out www.wrxhackers.com. It's a discussion forum for just WRX ECU's.
davidm_sh is offline   Reply With Quote
Old 10-28-2002, 02:32 PM   #4
Delicious Tuning
Member#: 1990
You could pay twice as much for a Tec III and probably not be able to tune it yourself from the start or even able to get it started at all.
Or you could get something else that could get you up and running much faster, and at half the price. My vote Link Plus.
Though it all comes down to what you want to use the car for? Track use only? Daily driver? What kind of tuning are you looking for.
Delicious Tuning is offline   Reply With Quote
Old 10-28-2002, 02:52 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Hisssssss, hisssss...
Talk about opening a jar of worms.
EVERYTHING has their downsides... what you want to do is what will suit your needs.
You can do it with a TEC, but do you really want to adjust fuel by Volumetric Effeciency settings?
You can do it with a Link, but do you really want to deal with their whacked scales of adjustment?
You can do it with a Haltech, but do you really want to deal with wiring it in yourself or doing your own troubleshooting since the user-based is fairly small?
You can do it with a MoTeC, but do you want to spend that much + see Haltech.
You can do it with an Autronic, see MoTeC.
You can do it with any other standalone, see Haltech.
Personally, I like the Haltech's real-world settings, the Link's PnP-ability, and the TEC's user-base. I like features that the MoTeC has that others don't... well, I'm sure you get the point.
Old 10-28-2002, 05:40 PM   #6
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
You forgot Pectal Nick!
Seriously, Like Nick said everything has its downsides.
Old 10-29-2002, 06:49 AM   #7
JenisonWRX
Member#: 6049
02 WRX & 99 RS
If I was doing an engine swap ... on any car ...
Tec would be my solution
this from a Link owner
JenisonWRX is offline   Reply With Quote
Old 10-30-2002, 02:43 PM   #8
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Your reasons for this conclusion?
I'm swaying to Haltech the more I talk with Nick... the only thing hindering it is the lack of support in the subaru/i-club market. If more and more people gave it a shot and we got more support I think it would be much better than electromotive (what TEC derives from) and is still less money.. No subaru specific kit, but those are overrated anyway
Old 10-30-2002, 04:30 PM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i really wonder if the link nay sayers are people that have delt with the plug in link or the link plus
the reason that i am leaning towards the link plus is the pre-fab harness that are avaiable from the sand rail guys... oh yeah and the base maps for the EJ20G...
haltec e6k is about the same cost 1045+3 bar map sensor + ignitor but no knock control and no base map
the e11 might be the ticket .. if it ever comes out
right now i may use my 1.8 ecu and try and use a e-manage (cheeep!)
in discussion the people have steered me away from the tec2 .. aparently pretty buggy and the tec 3 is just toooo expensive 2400...
Old 10-30-2002, 04:44 PM   #10
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
For the record, I got a 2bar sensor from the junkyard for $10, and you can use the stock ignitors. Pish posh, who needs a base map?
Still, no knock control. But I'm getting a J&S personally, just because I want to make ultra-sure that this one doesn't blow due to detonation.
Old 10-30-2002, 10:44 PM   #11
Gaspipe
Member#: 16897
You forgot the Simple Digital Systems EM-4 in that list of standalone EFI systems.
I used one of the early EM-1 systems on an EFI conversion ported 13B rotary in a 1st gen RX7 a few years ago and it turned out pretty darned quick. I liked it because I could use a pilot's leg board and velcro to attach the programmer to my leg to tune on the fly instead of needing a laptop.
Just another option.
Gaspipe is offline   Reply With Quote
Old 10-31-2002, 11:25 AM   #12
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
I do as I won't be running the Legacy ECU to get a base map data log... oh and don't know if I can get this from anyone else as they are OBD I.
Jaxx,
Can you give me some direcion/link to this sandrail place that offers harnesses and what not for these engines??? I know the harness won't work with my engine either, but the base maps might give me a start and the Link Plus doesn't sound all that bad, as long as it isn't like the Link piggy back.
Old 11-01-2002, 02:45 PM   #13
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yeah
here are two that i know of
outback motorsports 714 994 5222
http://www.sandstallion.com/
also talk to carmodifications.com they are dooing alot of the 2.5rst ecu stuff..
also i-speed.com
link as piggy back?? as a whole link=stand alone ...
i have how ever though about running both ecus ... let the 1.8 ecu control some things and let the link do the fuel map .. like shiv does with the tec setups .. if i cn figure out how he did it
FS: 2004 STI COMPLETE ENGINE SWAP 31K miles with shipping scoobiedoobiedoo Engine/Power/Exhaust 2 04-28-2008 08:29 PM
FS: 2004 STI COMPLETE ENGINE SWAP 31K miles with shipping scoobiedoobiedoo Complete Car Part-Out 1 03-04-2008 09:34 PM
FS NY- 2006 STi Complete engine swap 4k miles turbotoyzz Engine/Power/Exhaust 4 12-05-2007 10:56 PM
v8 jdm sti complete engine swap richy_21 Engine/Power/Exhaust 48 02-22-2007 03:15 PM
WTB: JDM V7...V8 or USDM V8 complete engine swap killawhiterex Private 'Wanted' Classifieds 4 11-15-2005 12:38 PM
