Welcome to the North American Subaru Impreza Owners Club Saturday February 28, 2015
Old 08-29-2014, 11:16 PM   #1
Xcross
Member#: 398970
2014 wrx
Default Wastegate flutter gone, car feels slower
Got stage 2 protuned and had wastegate flutter for a few days, didn't hear anything pop of that nature but the car has a hard time boosting. It still reaches peak boost but slowly and under take a while to get there. Wastegate flutter is now gone. Pulled the stock tb-IC hose and removed rubber boots. That wasn't the problem so seeing if anyone else has had experience like this and where to check.
Mods: catless dp
Drop in filter
Protune
Xcross is offline   Reply With Quote
Old 08-29-2014, 11:49 PM   #2
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
Mods: catless dp
Drop in filter
Protune
Could be a pre front afr sensor leak. Simply put, an exhaust leak. Or ... u have a leak between the turbo and pistons which is taking longer to build pressure. Imagine trying to blow up a baloon with a leak in it ;-)
Sent from my SM-G900P using NASIOC mobile app
BeastianSTI is offline   Reply With Quote
Old 08-30-2014, 12:16 AM   #3
Xcross
Member#: 398970
2014 wrx
Suggestions on where to test? Will the water and soap test work for this?
Old 08-30-2014, 04:20 PM   #4
BeastianSTI
Member#: 310506
2005 WRX STi
Turbo to intercooler y pipe.
By pass valve to intercooler.
Tmic to throttle body couplers etc
Intake manifold to cylinder head
Intake manifold to tgvs.. that should work. Should hold pressure though too
Old 08-30-2014, 04:36 PM   #5
Xcross
Member#: 398970
2014 wrx
I'll test them this weekend. Where you at in florida?
Old 08-30-2014, 05:12 PM   #6
BeastianSTI
Member#: 310506
2005 WRX STi
Good Ole Tampa haha.
Also ... are you sure that the hoses going from the ewg to boost controller are tight?
Old 08-30-2014, 05:53 PM   #7
Xcross
Member#: 398970
2014 wrx
I'll double tap that too I'm up here in pensecola
Old 08-30-2014, 09:28 PM   #8
MRGierut013
Member#: 328260
2005 STi, 2004 RSX
i-Vtec just kicked in yo!
Why not ask your tuner?
Sent from my HTC VLE_U using NASIOC mobile app
MRGierut013 is offline   Reply With Quote
Old 08-30-2014, 10:36 PM   #9
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
check the bypass valve hoses.the little one is known to come off.
424wrx is offline   Reply With Quote
Old 08-30-2014, 10:50 PM   #10
Xcross
Member#: 398970
2014 wrx
His shop is pretty far away trying to figure it out without having to drive up there
Old 08-30-2014, 11:26 PM   #11
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
your 'wastegate flutter' was likely just the bcs cycling and when ya p0pped the boost leak, ya ran the wgdc out and its just trying to make boost and cant
