Old 10-28-2002, 08:34 PM   #1
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
Default My audio project has begun
After several weeks of driving around with the very crappy Subaru "premium" sound system, I finally tore the car apart and decided what to do with it. I started with around 50 sq feet of sound deadening pads throughout all 4 doors and under the back seat. Then, I went ahead and started sealing off the cabin from the trunk. Several layers of SDP's and numerous trips back and forth to cut the baffle down to fit, and I finally have the sub mounted. I went with a single 15" driver, firing through the ski hole in the seat, using the trunk as the enclosure. This configuration allowed me to get extremely musical bass and frequency response flat out below 20Hz while only adding around 50lbs for the actual hardware and still maintaining full useable trunk space.
Next, I'll install the new Pioneer Premier P940 in the dash and a 400W amplifier inder the passenger seat for the sub. For now, I'll use the head unit's amplifier for the front speakers. I found that the factory tweeters in the front don't sound too bad once you bypass the stock crossover capacitor with a high quality 1uF film cap. It really increases the volume, as well as extending the frequency response, both high and low (it lowers the crossover point of the tweeter when you do this). This, combined with generous sound deadening pad application in the front doors, makes the front speakers sound much better. Of course, I'll definitely replace them soon as well. LOL
John
AustinTX is offline   Reply With Quote
Old 10-29-2002, 03:55 AM   #2
well_armed
Member#: 15204
interesting but cool
well_armed is offline   Reply With Quote
Old 10-29-2002, 08:21 AM   #3
idealrides
Member#: 10314
03 WRX 325hp SOLD!
06 Jeep SRT8 - 450hp
nice. Could you post some more pictures of your sub box? Like from behind?
This is my current sub but I'm looking for something else:
idealrides is offline   Reply With Quote
Old 10-29-2002, 08:49 AM   #4
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
I'll Post more pics tonight. I'm using the trunk as the enclosure.
Old 10-29-2002, 09:30 AM   #5
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
ideal rides, what does yours look like from behind?
and i'm basically looking for a way to keep factory head with all new speakers, and maybe getting a sub
ScreaminFast is offline   Reply With Quote
Old 10-29-2002, 10:27 AM   #6
idealrides
Member#: 10314
03 WRX 325hp SOLD!
I custom made that box to fit behind the seat of a pickup truck i used to have, and it happend to be the perfect size to fit under the frame crossmember in the WRX's trunk. It actually fits so tight that it takes a few minutes to get it in or out. And it takes up almost no space in the trunk.
It's only 0.65 cubic feet which is enough for the JL 10W6 but I'm not sure if the JL 10W6 is enough for me! Thats why you see a Boston 15" in this picture.
Old 10-29-2002, 10:48 AM   #7
Mud Pig
Member#: 27611
2007 FJ Cruiser
R.I.P. Mitsubishi Evo
Looks really cool, but how much weight are you adding to your ride? I was thinking of putting in a system, but I'm more performance on the road oriented.
Mud Pig is offline   Reply With Quote
Old 10-29-2002, 01:01 PM   #8
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
I am definitely sensitive to the weight I'm adding, so the total added weight of the sound deadening pads and the sub/baffle/amp total weight will be under 100lbs.
Old 10-29-2002, 11:14 PM   #9
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
Here's a pic from the back:
Old 10-30-2002, 09:46 PM   #10
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
Here's a pic of the tweeter mod. I also realigned it to match the factory grill. It was actually pretty far off. I gave it a slight upward tilt, as well.
Old 10-30-2002, 09:55 PM   #11
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
Here's the front of the sub with the interior installed. Ain't carbon fiber great?!?
Old 10-31-2002, 04:54 PM   #12
PPower
Member#: 22146
2012 Acura TSX wagon
First, what kind of sub is that? Where can I find info?
Second, do you like it free air? Have you considered AP mat? If so, any reason for not using it? Thanks.
PPower is offline   Reply With Quote
Old 10-31-2002, 06:28 PM   #13
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
The sub is an Orion prototype of the original NT subs. I got a few sets when I worked at a shop back in 95.
I haven't actually powered it up yet. I'm waiting on the head unit to arrive in the mail. I prefer infinite baffle configurations, due to the lack of box coloration and resonance. The low frequency capabilities of IB are incredible when implemented correctly. Plus, the total added weight and loss of space are far less! You just need to make the rear deck more rigid and use lots of sound deadening in the trunk to keep flexing and rattles to a minimum.
Old 11-06-2002, 10:08 PM   #14
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
I finally got the head unit installed. It's a Pioneer Premier DEH-P940MP. It's neat. The remote is pretty lame, though. No way would I mount it to the steering wheel. LOL
Old 11-10-2002, 09:08 PM   #15
tdxflex
Member#: 13634
did you fiberglass the mounting surface? i'm wondering if i can fit something like this in my trunk because i have a cusco strut tower bar with v-brace, not much depth or anything unless i maybe mount the sub high so it comes back in the middle of the braces, but then i'd have to remove the braces to fit the enclosure in, and then i dont know if i could put the braces back on! anyone run into something similar? aiming to get either around 1cu ft for a sealed box, or 0.8cu ft for a ported box, but not sure if there's enough room for that much.
tdxflex is offline   Reply With Quote
Old 11-10-2002, 10:42 PM   #16
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
The sub is mounted to a 3/4" MDF board, which is mounted directly to the back of the sheet metal lip behind the seat. There is no enclosure behind the woofer, so it takes up very little space.
Old 11-11-2002, 04:57 PM   #17
cantex
Member#: 9611
Default i have the same setup
i use kicker c10 inifinte baffle sub through the passthrough. check it out...
i would think a 15" sub would not have enough room to move, hitting on the seats.
http://www.sounddomain.com/member_pa...page_id=230895
cantex is offline   Reply With Quote
Old 11-11-2002, 05:02 PM   #18
cantex
Member#: 9611
Old 11-12-2002, 08:47 AM   #19
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
I mounted my woofer from the back of the baffle, so there are no issues with the surround making contact with the seat.
Old 11-12-2002, 11:19 AM   #20
tdxflex
Member#: 13634
that's a good idea to mount it behind. i think i'm going to put a 10" ported box in the pass through, not sure how i'm gonna mount the sub. Probably just use 1/2" mdf for the face, cut the entire diameter of the sub, then make another piece of 1/2" mdf cut with the mounting diameter, screw those together with some liquid nails and i can flush mount the sub. I'll probably make some sort of grill to protect it too, anyone know any good plexiglass shops? i might ask gately audio, but does anyone know any other place?
My Audio Project Teaser -Fiberglass is not light- blah0r Car Audio, Video & Security 15 10-21-2009 05:47 PM
Legacy EJ25 -> EJ20T Project has Begun!! Hoffman Subaru Conversions 15 02-25-2005 06:43 PM
EJ18 wiring diagram...the porscharu project has begun. steve_d Subaru Conversions 14 03-30-2004 03:04 PM
I Got My 2.5 Motor And Fwd L 2.5 Project Has Begun mcu81 Normally Aspirated Powertrain 88 10-30-2002 06:32 PM
The Project Has Begun! Wedge South East Region Forum 8 02-11-2002 07:15 PM
