Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 10-29-2002, 12:54 PM   #1
WhiteWRoX
Member#: 19430
2002 WRX Sport Wagon
White blur...
Default How long to install Stoptechs & SS Lines?
I bought some used Stptechs and have stainless steel lines and speed bleaders on the way. A local mechanic said 3 hours, maybe less. Is this too much? I'm thinking of doing it myself but have to buy some wrenches and torque wrench. And the bleeding sounds like a pain solo.
Thoughts?
Thanks, Steve
WhiteWRoX is offline   Reply With Quote
Old 10-29-2002, 01:01 PM   #2
DanMan
Member#: 5009
Not so unreasonable. I usually charge two hours, but for someone who hasn't done it on WRX before, it'll take a little longer.
Dan
DanMan is offline   Reply With Quote
Old 10-29-2002, 02:59 PM   #3
jsarfaty
Member#: 23526
2002 WRX Sedan
2000 Yamaha YZF-R6
Bleeding usually is kind of a pain to do yourself. If you have a nice kit, though, that will make it more manageable. The most important part of the kit to me is the bag with a suction cup that you can suction to the side of your car so you don't have to hold it. But keeping pressure on that brake pedal is still tricky.
__
Josh
jsarfaty is offline   Reply With Quote
Old 10-29-2002, 04:07 PM   #4
I drive a WRX wagon
Member#: 9219
02 IS300 5sp
Did you get the whole stoptech big brake kit or just the rotors? the brakes are pretty easy to work on. If you need tools just borrow some from a friend and have them help you bleed the brakes. 3 hours total time sounds about right since bleeding the brakes can take a while.
I drive a WRX wagon is offline   Reply With Quote
Old 10-29-2002, 04:42 PM   #5
WhiteWRoX
Member#: 19430
White blur...
Default Thanks!
Thanks for all the input.
I purchased the entire kit - rotors, calipers, pads, SS lines, clips, and instructions. I'm just short some tools. It sounds like 2-3 hours is right so I'm probably gonna let my buddy at the shop do it.
-Steve
Old 10-29-2002, 05:45 PM   #6
rkkwan
Member#: 5596
2010 Honda Fit Sport
Just in case you haven't read the 200 posts about people stripping the bolt on the brake-line, make sure you have a 10-mm flare-nut bolt. Because I can guarantee that you will strip it if you don't use one.
-Ray
rkkwan is offline   Reply With Quote
Old 10-29-2002, 06:14 PM   #7
teiva-boy
Member#: 22825
-Ray
Since your putting a guarantee on it. I want some money back from you. I didn't use a flare nut wrench and had no issues. But YMMV and each car is different in the sense that some assmbly line worker had his wheaties one day and felt like superman when tightening those nuts. I just got one that was made on his off day
teiva-boy is offline   Reply With Quote
Old 10-29-2002, 11:56 PM   #8
Steppin Razor
Member#: 24035
2002 GGA 5MT
Seal Gray
he tightened the ones on my car though
Steppin Razor is offline   Reply With Quote
Old 10-30-2002, 12:48 AM   #9
ImprezaWRXDriver
Member#: 7152
2002 Impreza WRX
Traditional Blue and Gold
rkkwan is right about how easy it is to strip the bolts. Those bolts are really easy to strip because they are made out of brass. I have been told that they are easy to strip also. and what is a 10mm flare-nut bolt? Are you referring to using a 10mm wrench to hold that bolt so that it does not strip? I had a friend who is a mechanic do it for me and I told him to take his time on it and he didn't have any problems.
ImprezaWRXDriver is offline   Reply With Quote
Old 10-30-2002, 12:53 AM   #10
tdxflex
Member#: 13634
when i changed out my lines, i noticed that the clips sometimes don't hold the hardline and brake line in place very well, so when you try to undo the 10mm bolt, it twists the whole line and i'm guessing that's how everyone who uses an open end wrench strips the bolt. i used a flare nut wrench, but i think if you can secure the hardline down and keep it from twisting, you can get it off with an open end wrench. but it's only one other tool and i don't see why you wouldn't spend the $5-10 for a more suitable tool.
tdxflex is offline   Reply With Quote
Old 10-30-2002, 01:40 AM   #11
obyone
Member#: 16523
this anymore???
8 + hours just to install the brake lines.
Read about it here.
obyone is offline   Reply With Quote
Old 10-30-2002, 01:45 AM   #12
rkkwan
Member#: 5596
teiva-boy -
ImprezaWRXDriver - A flare-nut wrench makes contact with the bolt on 5 sides, rather than 4 in regular wrenches. You have to manuever a little to get the wrench in place, but is much less likely to strip a bolt.
tdxflex is right. You can secure the line with something else like a vice-grip. But that's going to mar the hardline, and you might still strip or mar the bolt.
-Ray
How much to get frt & Rear lines installed with full fluid flush? waitandbleed92 Brakes, Steering & Suspension 8 04-14-2005 11:04 PM
How long to install EGT, Boost, and Oil Temp for a noob? Irishman Electrical & Lighting 11 10-02-2004 11:05 PM
How long to install Up-pipe, TBE, etc? ringmaster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-23-2004 11:08 AM
How long to install FMIC ? Brewmaster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 04-19-2003 05:54 AM
How long to install your kit DoctorNick Normally Aspirated with bolt-on Forced Induction Powertrain 20 05-27-2002 02:00 PM
