Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 10-29-2002, 06:35 PM   #1
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
Default Uppipe leak and my SAFC tune? Need advice.
I had my SAFC dyno tuned this past Saturday and was very displeased with the results (189whp pre-tune, 219whp after tune). I hopped under my car today to change my oil, and noticed I had a big leak in the uppipe at the manifold to uppipe flange.
Now my question, after I fix the leak this weekend, will my SAFC tune be OK?? The guys that tuned it pulled out a considerable amount of fuel since my car was running extremely rich. Should I just set all the values back to 0% till I can get retuned??
Any help is appreciated.
-Anthony
atf78 is offline   Reply With Quote
Old 10-29-2002, 06:52 PM   #2
mlambert
Member#: 13831
you werent happy with 30whp after uppipe and s-afc tune?
just fix the leak and leave the s-afc set like it is
mlambert is offline   Reply With Quote
Old 10-29-2002, 07:21 PM   #3
NotoriousWRX
Member#: 9026
Default Re: Uppipe leak and my SAFC tune? Need advice.
I hope that you mean pleased, because that is probably the cheapest horsepower that you will ever make on this car.
Anyway, the leak may have a have an effect on your AF if it is big enough to alter the spool-up of the turbo. Fix the leak, and if your max boost and behavior remain the same, then you should be OK.
What are your SAFC settings? From what I can remember, the adjustments made were in line with all the other cars that I've seen being tuned.
NotoriousWRX is offline   Reply With Quote
Old 10-29-2002, 07:24 PM   #4
jimb
Member#: 9923
2005 Legacy GT
RIP MBP WRX
220 isn't all that bad. Remember though, the weather was terrible, low pressure and high humidity. You dyno'd kind of low with the unichip as well, maybe a compression test is in order?
jb
jimb is offline   Reply With Quote
Old 10-29-2002, 07:35 PM   #5
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
OK, I shouldn't say displeased with the tuning, but displeased with the base run. 189 is kinda low for the mods I have (catless uppipe, 3" catless downpipe, catback, MBC, intake, Samco IC hoses, MBC at 16psi). I made 205whp on TurboXS Stage 1 so I don't suspect my compression to be a problem.
Guess I'll fix the uppipe leak and see what happens. I have a Dalta Dash on order so hopefully I can do some data logging and check for myself.
-Anthony
Old 10-29-2002, 07:37 PM   #6
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
what type of uppipe did you get?
silver arrow is offline   Reply With Quote
Old 10-29-2002, 07:48 PM   #7
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
silver arrow: It's a Godspeed uppipe.
Alex, my Hi-Throttle settings are as follows:
1K: -2%
2K: -2%
3K: -3%
4K: -6%
5K: -14%
6K: -16%
7K: -16%
8K: -16%
These seem high compared to what you posted Back in this thread. My setup is similar to what you had at that time.
-Anthony
Old 10-29-2002, 08:16 PM   #8
NotoriousWRX
Member#: 9026
3" catless downpipe, catback, intake
Brands? Also, do you have an EGT gauge? If so, what's it reading?
Your settings do seem extreme from 5k RPM and up.
Old 10-29-2002, 08:24 PM   #9
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
PDE downpipe
Apexi WS catback
Greddy Airinx Intake
I have an EGT gauge .. not installed yet though Hopefully this weekend I can get that done.
-Anthony
Old 10-29-2002, 08:46 PM   #10
NotoriousWRX
Member#: 9026
Anthony, I may have some ideas for you, but I would have to look at your car.
Old 10-29-2002, 08:46 PM   #11
RidinLow
Member#: 329
1995 325i
Arctic Gray
I dynoed my car literally right before Anthony's car went on. I have all the same type of mods except for an open intake, which my car doesn't have. And I have 1 cat in the downpipe and 14.5 psi instead of 16.
My car pulled 205 whp before and 230 after. You're only 10 hp behind me, which is still within the factory tolerances... some cars are stronger than others. Unless your peak power was recorded right when you hit full boost, I don't think a small leak in the uppipe would affect your power too much if you're still seeing 16 psi. The leak would probably slow you down because it won't spool the turbo as quickly, but once it's spooled, it's spooled.
And if you just noticed the leak, it was probably very minor!
But yeah, your high rpm settings seem rather extreme. I'm using a Field SFC instead of the Apexi AFC, and I don't lean out over 6%. 8% got me an extra 2 horses along with detonation.
RidinLow is offline   Reply With Quote
Uppipe leak and questions MiracleMan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-12-2007 04:36 PM
Quick thought about uppipe leaks and installs... DTECH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-07-2004 09:00 AM
exhaust leak and wideband O2 tuning. Kwyjibo Engine Management & Tuning 1 12-31-2003 03:33 AM
can an uppipe leak cause my car to feal sluggish? vapore0n Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-18-2003 10:17 AM
boost related noise; not an uppipe leak and only happens with modified boost levels. lstepnio Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-06-2003 06:03 PM
