Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Old 10-30-2002, 02:54 AM   #1
kaos200
Member#: 2692
Default Nice Widebands for tuning
Im going to order a wideband sensor for tuning, and Ive found one, but want to see what people are using? Anything nice and accurate for less than $300?
post whatever you've found though cheap or not and your opinion so people can find this thread in a search.
kaos200 is offline   Reply With Quote
Old 10-30-2002, 04:05 AM   #2
ScoobieSnaX
Member#: 10844
2004 Acura TL Navi
Pearl
I have an FJO unit purchased from Manitoba, Canada for ~$1200CAD. At this price it came with the PC conectivity kit which gives me the ability to connect my Palm or Laptop.
The quality of the unit is top notch. The best in the business IMO.
Where did you find one? The cheapest setup out there I think is the DIY kit. Anything under $300 would most likely be a narrow-band sensor (such as Greddy/HKS/etc).
ScoobieSnaX
ScoobieSnaX is offline   Reply With Quote
Old 10-30-2002, 05:03 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
This is a gross exaggeration. The best A/F meters in the business are produced by Horiba and ETAS and cost several thousand dollars.
If you can find a source for it, the HKS A/F-Knock Amp appears to be an excellent tuning tool. Not only does it utilize the same wideband A/F sensor used by the FJO meter, but it also provides an amplified signal from the WRX's knock sensor that you monitor with headphones. It was discussed, briefly, in this thread:
http://forums.nasioc.com/forums/show...hreadid=210933
Jon [in CT] is offline   Reply With Quote
Old 10-30-2002, 05:39 PM   #4
D_REX
Member#: 8945
MY02 WRX
The FJO unit came highly reccomended to me by a well respected tuner on this board. While it's not the best thing out there it's a good unit w/ decent logging capabilities.
I also looked at the Lambda Boy product. It's basically the same as the Tech Edge / DIY product, but assembled and tested with a sensor. I was recently tipped off to some sensors at a good price for the DIY so I ordered 2 of those today. I think I'm just going to order a kit from Tech Edge and do the assembly myself. It'll end up a pretty cheap, but relatively functional WB O2.
D_REX is offline   Reply With Quote
Old 10-30-2002, 06:41 PM   #5
Jon [in CT]
Member#: 2992
02 WRX Sedan
I was responding to the "best in the business" claim for the FJO and was too terse in my previous post. There is no doubt that the FJO meter is far superior to any meter that relies on a switching 0-1V O2 sensor. I was merely noting that other lab-grade wideband meters are far superior to the FJO if you need precise/known accuracy.
When I first stumbled on the LamdaBoy product a few months ago I, too, thought it was another DIY project knockoff. However, his website now indicates that his product is a digital-based design, instead of the analogue design developed by the DIY project. So the LambdaBoy product might be based on something similar to that described on this page: http://members.iinet.net.au/~metapro...I/DDL/DDL.html. In any event, I don't like the LambdaBoy "display." For more info, see http://www.lambdaboy.com.
TechEdge, which is in Australia, also offers a pre-assembled and tested meter. Make sure you have the sensor in hand, though, before you order it. There's nothing more frustrating than having the meter sitting on your desk, ready to go, and not being able to buy the correct sensor at a reasonable price. For more info on TechEdge, see http://www.techedge.com.au/vehicle/wbo2/default.htm.
Old 10-30-2002, 06:53 PM   #6
D_REX
Member#: 8945
MY02 WRX
I know your on the mailing list, I've seen you post. I ordered today from PartsBin as did lots of other people apparently. I should have sensors (I ordered 2 just in case) in hand by next Wed. I've already got a bung welded into my up pipe. now i just need to order and build the kit
Old 10-30-2002, 07:14 PM   #7
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
What price are you guys getting for the sensor through The Parts Bin?
I saw $139 from NAPA.
Thanks,
Russ
rlavalle is offline   Reply With Quote
Old 10-30-2002, 07:57 PM   #8
Jon [in CT]
Member#: 2992
02 WRX Sedan
Given the recent near-total unavailability, I would pounce on any sensor priced under $150.
Old 10-30-2002, 09:06 PM   #9
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
I want a way to squeeze the voltage down from 0-4v to 0-1v. The link sets its a/f targets based on voltage, so it would be easy to fool it into using a w/b if this was possible.
Midwayman is offline   Reply With Quote
Old 10-30-2002, 09:10 PM   #10
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Talking
And a few link of interest
http://www.tragacs.com/wbo2.html
http://gadgetseller.com/gauges/
http://www.speedshop.org/detail.asp?PRODUCT_ID=NEDT-005
http://www.lambdaboy.com/
edit... check it out a DIY controler for like $25 in parts. (still needs sensor and connectors, etc. Should come in under $200 all said and done)
http://www.diy-efi.org/diy_efi/projects/diy_wb/
Old 10-31-2002, 12:08 AM   #11
yebokmj
Member#: 2213
1995 Impreza w/EJ257
Brilliant Red
Default Greddy A/F
I am using a Greddy A/F it's supposedly a wide band 02 sensor and heated. It gives you a reading in anologe and makes tuning quite easy. It's around the 300 mark not sure exactly where. It's the one on the left in the picture.
Joshua
yebokmj is offline   Reply With Quote
Old 10-31-2002, 03:43 PM   #12
Jon [in CT]
Member#: 2992
02 WRX Sedan
Default Re: Greddy A/F
I've read that Greddy doesn't recommend their A/F meter for tuning:
http://www.diy-efi.org/gmecm/archive.../msg00813.html
Old 10-31-2002, 03:56 PM   #13
yebokmj
Member#: 2213
Brilliant Red
Default True but
The reason they suggest that is because it's not nessacerly calibrated 100% perfect. You can recalibrate it if need be after comparing it to a quality one like those used at dynos. I still use if for tuning but in combination with EGT. I would never want to rely on imput from one gague. My EGT is mounted with my boost on the A Pillar.
Old 10-31-2002, 10:29 PM   #14
Jon [in CT]
Member#: 2992
02 WRX Sedan
Default Re: True but
Can you explain exactly how you recalibrate your Greddy? It was my impression that the Greddy had exactly two calibrations, the default 9:1 and the 11:1. I think that Greddy is, in essence, asking you to specify which air/fuel ratio corresponds to a particular sensor voltage in the rich region. As you can clearly see from this graph, a switching 0-1V O2 sensor's voltage is HIGHLY dependent on EGT in the rich region. BTW, this graph's X-axis depicts lambda values. To convert lambda to A/F ratio, multiply by the fuel's stoichiometric A/F ratio.
Old 10-31-2002, 10:35 PM   #15
yebokmj
Member#: 2213
Brilliant Red
Default Mulitlple
I'm not sure how to calibrate it but it says you can in the directions and I don't have them in front of me it's something on the control box not the gauge. I also believe it has 4 setting for what your refering to.
Joshua
Old 10-31-2002, 11:09 PM   #16
Jon [in CT]
Member#: 2992
02 WRX Sedan
Default Re: Mulitlple
What a coincidence. My graph, above, has four EGT profiles. Please let us know more when you find the directions.
Old 11-01-2002, 12:27 AM   #17
nmyeti
Member#: 4980
Joshua
Joshua,
Just a word of warning; one of our customers came in to the shop with a Greddy A/F meter that was at best 2 full A/F points rich in most conditions. At worst it was totally worthless.
I'd stay far away from one of these!
-Nathan
nmyeti is offline   Reply With Quote
Old 11-01-2002, 02:14 AM   #18
yebokmj
Member#: 2213
Brilliant Red
Default Thanks
Okay well as I mentioned I do have an EGT which is what many people tune by alone. I have been using this same gauge for well over a year in combination with EGT with great success on two NA Turboed Impreza engines. I am aware it's not 100% but if you compare it using a scan tool to the readings coming off a factory sensor as I have done, I found it's dead on. Not only that but the gauge does have a warm up feature where it flashes it's lights untill it's up to proper operating temperature. This makes sure your aware that it's not giving a proper reading. I deffinatly would like to get the calibration of it checked though and I do plan to at a dyno day. I would deffinatly go with this over an autometer setup or those other blinking light setups. Thanks for the imput though.
Joshua
Old 11-01-2002, 09:54 PM   #19
roberto arano
Member#: 28311
Default Egortech/egormeter wideband Gar Willis
Any one heard the Egormeter, by EGORTECH?
It's a wideband, I talked to the company and may buy one,but I can't find anyone who actually OWNS one.
roberto arano is offline   Reply With Quote
Old 11-03-2002, 10:09 PM   #20
Jon [in CT]
Member#: 2992
02 WRX Sedan
Default Re: Egortech/egormeter wideband Gar Willis
Roberto, thanks for the post. It prompted me to search around the internet for traces of Garfield Willis, the guy behind EGOR. He dropped out of sight a couple of years ago promising that he would soon be supplying affordable wideband A/F meters. And then nothing, until your post prompted me to search again. And now he has a new website, url=http://www.egortech.com, which doesn't seem to have been updated for quite a while.
First of all, you should read an i-Clup post I submitted because of research prompted by Roberto's post: http://forums.nasioc.com/forums/show...hreadid=269143.
My search has led to these posts, which mostly denigrate the current DIY-WB controller and its developers, but nonetheless, offer food for thought:
http://www.diy-efi.org/mhonarchive/efi332/msg00052.html
http://www.diy-efi.org/mhonarchive/efi332/msg00060.html
And people in i-Club thought I was caustic.
Old 11-05-2002, 12:55 AM   #21
Ryan23
Member#: 15116
2000 Ver6 STi Type-R
EJ257/GT35R
Default Re: Re: Greddy A/F
Originally posted by nmyeti
Joshua,
-Nathan
/Nods. Yep, mine was off and no, it's not a wideband. If you want a real wideband expect to pay for it
Ryan
Ryan23 is offline   Reply With Quote
Old 11-05-2002, 07:33 PM   #22
downshift1
Member#: 15607
I'm not the type
to make angry
I can get FJO wideband setups for pretty cheap (I'm not a vendor, just passing along a good deal ) if anyone is interested PM me.
-Dylan
downshift1 is offline   Reply With Quote
Nice mellow driving tunes thread.......not!!! jason t Vancouver Impreza Club Forum -- VIC 10 12-06-2009 04:49 AM
wideband O2 sensor AFTER a cat acceptable for tuning? rex n effect Engine Management & Tuning 11 12-12-2005 05:52 PM
exhaust leak and wideband O2 tuning. Kwyjibo Engine Management & Tuning 1 12-31-2003 04:33 AM
