Old 10-30-2002, 01:57 PM   #1
schnoog
Member#: 8238
2005 A4
Red
Smile VF-35 vs VF-34 vs VF-30
Hi all,
as the name of this thread would suggest, I have a question concerning the VF-30, VF-34, and VF-35.
How do these 3 compare with each other and what are their characteristics. I want it all.....lag time, flow rate, best boost level, etc. Does anyone have any dyno charts for these??
Frankly I've had a hard time finding info on the web concerning the VF-35. I do know that the VF-34 is the VF-30 with roller bearings.
I plan on using one of these turbos for the race track(not the drag strip).
Thanks!
schnoog is offline   Reply With Quote
Old 10-31-2002, 12:56 PM   #2
SPeeDSiN
Member#: 4667
Black (well kinda)
I was doing the same research today.
From what i have learned so far is that the vf30 and vf35 and very similar, while the vf34 is the more desirable turbo from the type ra.
Please correct me if I am wrong, but wasn't the vf35 introduced to fix some of the problems of shaft breakeage in the vf30?
SPeeDSiN is offline   Reply With Quote
Old 10-31-2002, 01:10 PM   #3
hotsam
Member#: 3862
You can find some turbo descriptions on my page.
hotsam is offline   Reply With Quote
Old 10-31-2002, 04:22 PM   #4
100
Member#: 10034
2002 WRX Wagon
WR Blue. niiiice.
I can't make a decision based on this info. How do I find out how each one will make my WRX behave?
Any idea how much will VF34's cost? Does the VF35 spool faster or slower than the VF34? If they're better than VF30's then how come Vishnu and TurboXS aren't using them? Is a VF30 unichip map optimal for these turbos?
Thanks, and great prices!
PEACE
OUT
100 is offline   Reply With Quote
Old 10-31-2002, 06:36 PM   #5
schnoog
Member#: 8238
2005 A4
Red
I think the VF-35 spools up faster than the 30 and 34. The drawback with the 35 is that it has less high end power.
I wish we could see dyno plots comparing all of these turbos....I'd like to see concrete data that shows the 34 truly does spool up faster than the 30. The price difference is substantial.
Does IHI have a website?
Old 10-31-2002, 08:38 PM   #6
jpm
Member#: 24312
2002 wrx wagon
http://vividracing.com/turbodata.pdf
This link may be helpful but I cannot vouch for it's accuracy.
jpm is offline   Reply With Quote
Old 10-31-2002, 09:15 PM   #7
hotsam
Member#: 3862
Schnoog is right...
The VF35 will spool very quickly, but there is also a drop off in top end power.
MRT has a good technical section on their web site.
Old 10-31-2002, 10:13 PM   #8
Bailey
Member#: 12572
2004 STi
35R is enough
The 30 and 34 are essentially the same turbo, but the 34 is roller bearing and therefore is supposed to spool slightly quicker. Both these turbos will have significantly more lag than stock but have more high end power potential.
The 35 is the same as the 30 but it uses a smaller turbine. So, it will spool quicker than a 30 or 34 but will not be able to flow as much high end.
I recently rode in a friend's WRX with a 35. Using a full catless system and an MBC 15 to 16 psi was achieved around 2900 RPM in 3rd gear full a WOT pull starting at less than 2000 RPM.
I would rank the following IHI turbos in acending order from less lag to most and from least HP to most:
28, 29
34
30 (equal power to 34)
22
Do a search for spool under threads started by austin. He recently posted some data logs that you will be VERY interested in.
Bailey
Bailey is offline   Reply With Quote
VF-34 vs VF-30 vs TD05H 16g line Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 65 01-04-2009 01:24 PM
Anyone have a dyno of a vf-34 vs stock? mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-21-2005 05:22 PM
VF-34 or Sr-30 StarDogChampion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-05-2004 09:32 PM
VF-34 vs. VF-30 Parallax Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 04-18-2004 01:35 PM
VF 35 vs VF 23 johnwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-11-2003 10:07 AM
