Old 10-30-2002, 09:00 PM   #1
RUN4BUX
Member#: 18584
Default How to reset SRS Airbag light????
I had to replace a side sensor and the air bag light is still on. Does anyone know for sure how to reset the system and remove the warning light. I tried disconnecting the battery with no luck. Thanks for any help?
RUN4BUX is offline   Reply With Quote
Old 10-30-2002, 11:00 PM   #2
Weedy
Member#: 12340
2002 WRX 2.5L Hybrid
You have to take it to the dealer to have that all reset from what I understand.
Weedy is offline   Reply With Quote
Old 10-30-2002, 11:12 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
The dealer will want to sell you a new seat (with airbag). You can turn off the light with a 3 ohm resistor substituted in place of the seat's airbag connector.
Jon [in CT] is offline   Reply With Quote
Old 10-31-2002, 02:28 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
john he said he replaced the side impact sensor and needs to clear the code, you can try disconnecting the battery and touching both cables together(works on some systems) otherwise the dealer will need to clear it.
jeremy
Old 10-31-2002, 09:27 AM   #5
555
Member#: 20161
1998 Impreza ST
555
just take off the light
My problem was the clock spring which was a spiral cable turns in the steering wheel
I did it, works fine
555 is offline   Reply With Quote
Old 10-31-2002, 10:54 AM   #6
Jon [in CT]
Member#: 2992
02 WRX Sedan
Originally posted by HndaTch627
john he said he replaced the side impact sensor and needs to clear the code.
Oops.
Try this:
Old 11-01-2002, 09:12 PM   #7
RUN4BUX
Member#: 18584
Thanks ya'll, I'll give your ideas a try and report back.
Old 11-03-2002, 11:46 AM   #8
WRXtreme78
Member#: 7477
Originally posted by Jon [in CT]
Oops.
Try this:
Will this make OTHER airbags deploy?
WRXtreme78 is offline   Reply With Quote
Old 11-03-2002, 06:30 PM   #9
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
No, that is in the factory service manual, it is under the SRS section, and how to clear the airbag light. Your indicator panel lights should just flash, and then no more airbag light.
-Wes
RebelINS is offline   Reply With Quote
Old 11-07-2012, 09:06 AM   #10
rsaz904
Member#: 332548
2013 WRX Limited 5Dr
I tried locating this in my 08 legacy but had trouble. The graphic is a little hard to figure out, has anyone done it? Is it located to the right of the fuse panel?
rsaz904 is offline   Reply With Quote
Old 11-12-2012, 04:24 PM   #11
amiexploited
Member#: 251061
2002 wrx*just sold
& 2015 WRX
You will most likely have to buy a new (or used) airbag ecu. If you can find a trusted source for a used airbag ecu that guarantees no airbags have gone off then it's just a plug and play with secure torx bits under the front part of the center console.
amiexploited is offline   Reply With Quote
Old 11-12-2012, 06:33 PM   #12
rsaz904
Member#: 332548
After much googling, forum hopping, and general research. I've come to the conclusion that in my 08 legacy, and likely 08+ subies in general, there is no diagnosis connector like is shown in the graphic. The system doesn't have a memory, and is self tested upon ignition each time. That is why the code needs to be actively showing when brought to the dealer for diagnosis.
Today, I troubleshooted and repaired what was causing my airbag light to show. I first unbolted the seats, and checked all of the sensor connections underneath. This didn't work, but I eventually noticed that the passenger airbag indicator light near the map lights was not working correctly.
When started, all three lights are supposed to show. "Passenger Airbag" "On" and "Off" stay illuminating during the self test, when the air bag indicator light is on in the cluster. After the self test, the passenger indicator light should show either "off" or "on" depending on whether someone is in the seat.
The "On" light worked correctly, but the "off" light did not illuminate at all, during the self test or after. I then noticed, as I smacked the general area of the lights that the light turned on.
I found a post on a subaru outback forum, which had the same issue, and was able to fix it by re-soldering the resistors on the LED pcb. I did this today, and magically my passenger indicator light is now working properly and my airbag warning light is off like it is supposed to be.
resetting your airbag light vien Interior & Exterior Modification 0 03-04-2010 03:01 PM
Scan tool needed to reset check engine light - Mission Viejo Area subaruracerx Southern California Impreza Club Forum -- SCIC 10 09-21-2009 06:08 PM
SRS Airbag Light stays on during prolonged cold starts. da-chaz Service & Maintenance 4 01-31-2008 01:08 PM
how to turn off airbag light on wrex8788 Interior & Exterior Modification 1 06-21-2007 01:17 AM
SRS Airbag light came on. How do I reset? cybin Service & Maintenance 7 12-20-2003 11:40 PM
